Results 31 to 40 of 252
12-31-2011, 12:40 PM #31Elite Member
- Join Date
- Jul 2003
- Posts
- 4,636
- Location
- central Texas, Lee County
- Tractor
- Kubota L5030 HST, Farmall A
Re: Circular paver driveway
Eddie, the bendable metal frame for the curbing was 40'X6" ( and 8-16" wide). It took a pallet (42 bags) for each section. I used many pallets, I lost count, the curbing took 1 bag per foot. I mixed two bags at a time in my mixer and the 40 foot pour takes 2 hours. The set up, measuring/framing/leveling, took several days for each 40'.
Kyle, The dog did not behave. I had to put up a temporary fence after each pour. On the last pour she jumped the fence, after I had gone in for the night, and it has about 20 permanent dog paws indentions.Last edited by txdon; 01-01-2012 at 02:20 AM.
TXDon
12-31-2011, 02:03 PM #32Elite Member
- Join Date
- Apr 2006
- Posts
- 4,517
- Location
- Wise county Texas
- Tractor
- Kioti DK 35 now
Don, did mixing it that way make it cheaper? I can sure see how it could be considered a "cardio" workout though
I admire your tenacity, (the Porch area looks great too!)Dennis
Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market conditions, the Light at the End of the Tunnel has been turned off.
12-31-2011, 02:14 PM #33
Looks better and better
** Kubota **
Psalms 86
John 1:12-13
Duraflap / Kaydenco not worth a hoot for service or products.
"Google" is a proper noun, not a verb.
If you mean what you say, then say what you mean, or just don't say anything
01-01-2012, 02:19 AM #34Elite Member
- Join Date
- Jul 2003
- Posts
- 4,636
- Location
- Tractor
Western, I didn't compare prices. I had only 40' of metal framing and that is all I could pour at one time and that would not be enough for a truck.
Here are some pics that show the difference between my drive way pavers (thicker) that require 1/4" spacing and Lowe's sidewalk pavers (thinner) that have side protrusions and the a beveled top that require no spacing.
The last picture is the front porch with the 1/4" spacing driveway pavers filled with polymer sand that has solidified.TXDon
01-01-2012, 09:26 AM #35
01-01-2012, 10:32 AM #36
I see the paver difference now, Don. Still not quite sure why the ones you're using couldn't be jammed tight against each - Would the corners break? Sand wouldn't fill in between them?
Anyway, we also did a big concrete job with bags: 11 pallets worth! (from Home Depot)
My dad wanted to pour a driveway extension, & there was no way for a concrete truck to access it without driving on & probably breaking the existing concrete drive ... & he didn't want to hire a concrete pumper, I guess since we're DIY kinda guys ... so we used my electric mixer. We strapped the mixer to my dad's FEL. Mix 3 bags at a time, then drive the tractor to the dump spot & un-curl the loader to dump it. Took many, many trips of that, but worked fine.Please consider donating to the Cystic Fibrosis Foundation
Kubota 3940
01-01-2012, 11:06 AM #37Gold Member
- Join Date
- Jan 2007
- Posts
- 379
- Location
- Shoreline WA, Athol ID
- Tractor
- Kubota L-35
01-01-2012, 11:15 AM #38Elite Member
- Join Date
- Oct 2003
- Posts
- 2,762
- Location
- the Steernbos (Holland)
- Tractor
- Zetor 3011, Zetor 5718
pavers are much more common here in Holland, we tend to lay 100m2 of pavers per man, per day. Just farmers doing their own pavement...
In your circular driveway, i would just begin on the outside radius and lay on the inside of each previous pass, putting in halves or 3/4 where necessary to remain the overlap between the rows. When laying circular as well, laying 15.000 pavers of guess 10x20cm (4x8") is no more than 30 man-days.... so with 2 people laying and 3 on the wheelbarrow to tip them as closely to the worksite as possible (so the men laying never have to get off their hands and feet unless for coffee break) we'd do it with family and friends (which have to milk cows or feed cattle in the morning and evening, so short days) in 6 workdays.
You do get sore, but rather being sore and getting things done with a bunch of friends and family whilst having a beer at the end of each workday, than spending 10 weeks on the same boring job, alone...
Free scrap is a good investment !!!
“The worst enemy of life, freedom and the common decencies is total anarchy; their second worst enemy is total efficiency” · Aldous Huxley
__________________
1967 Zetor 3011, restoration in progress: Technically new, just needs the cosmetics..
1973 Zetor 5718, home made loader
1998 Volvo S70 TDI
2007 Volvo 440 1.9 TD based dirt buggy, needs time !
01-01-2012, 11:54 AM #39Elite Member
- Join Date
- Jul 2003
- Posts
- 4,636
- Location
- Tractor
Renze, I was just thinking trying to think of the best place to start and will be using your method.
GT2, I believe that is a correct observation! The Driveway (Acme) pavers are clay based.
Beepington - That is exactly right, the edges would break, or cause a tripping hazard if not perfectly aligned and there would be no space for sand when they fit that tight. The 1/4" sand space becomes the bevel.
Kyle, you got that right! She hates snakes, just like Eddie.TXDon
01-01-2012, 12:45 PM #40Veteran Member
- Join Date
- Jun 2011
- Posts
- 1,383
- Tractor
- CNH 4020
Don, I see you have rebar in your curb. Do you have some verticals in the pour every once in a while that go down into your sandy ground or are you
depending on the weight of the concrete to control lateral shifting and or frost heave?
A vehicle's weight operating in that tight curve will create a lot of force toward the outside. Your doing a great job and the design goes very well with your house.
Ron
Similar Threads
Gravel driveway help.
By mjncad in forum ProjectsReplies: 15Last Post: 09-25-2010, 01:21 AM -
Major Driveway Project, Opinions Please
By dnels0n in forum AttachmentsReplies: 23Last Post: 08-17-2010, 08:09 AM -
Steep gravel driveway advice
By scoutcub in forum ProjectsReplies: 13Last Post: 07-21-2010, 11:16 AM -
Building a Gravel Driveway
By dfeck in forum Rural LivingReplies: 5Last Post: 06-17-2004, 11:17 AM -
Gravel Driveway Re-hab
By WVBill in forum ProjectsReplies: 38Last Post: 02-08-2001, 04:44 PM
