Page 3 of 9 FirstFirst 123456 ... LastLast
Results 21 to 30 of 85
  1. #21
    Platinum Member tractorshopper's Avatar
    Join Date
    Dec 2009
    Posts
    934
    Upstate South Carolina
    Kubota BX2380
    Default Re: New Dairy
    Wow, beautiful barn and entire setting!
  2. #22
    Gold Member
    Join Date
    Oct 2008
    Posts
    287
    Southern Maine
    now that the basic structure of the barn is up, here is what it will look like when finished. we went ahead and covered the entire roof with ice and water shield (even though it is a cold roof) and then will put lifetime architectural shingles on top of that. the siding and trim will all be done in hardie plank. although i am sure i would never have to worry about it, i had all of the walls strapped with 1x3 and then covered with another layer of OSB to create a drainage plane (aka cold walls). the windows are all marvin windows and the large ones on the side, to give a sense of scale, are 11'x11'. the house that you can just see on the hill behind the barn was built as part of the project too.
    here is picture looking down on the back. the bump out on the back is a tanker bay for loading/unloading our 8500 gallon tri-axle and i opted to build a shed roof over where all of the utility equipment will be installed. i have never been a fan of roof mounted equipment and there is nothing worse than trying to fix something in the rain.
    fire away with any questions.
    Attached Thumbnails Attached Thumbnails New Dairy-kates-butter-jpg   New Dairy-395383_2491919257925_1251069118_31914120_645369899_n-jpg   New Dairy-hillphoto-jpg
    JD 4210 Hydro, Curtis Cab, 420 Loader, 447 Backhoe, 5' Frontier Rotary Cutter, Maschio 50" Tiller, JD 60" 261 RFM, 59" Snowblower
    JD 455, 60" Mowing Deck, Triple Bag Rear Mounted MCS, 47" Snowblower, Original Tractor Cab
  3. #23
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,952
    nicholson, pa
    John Deer 318
    Wow thats a barn!!!!
  4. #24
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Quote Originally Posted by pilot-werx View Post
    Where's the cows?
    That is sure one "Taj Mahal" dairy barn. Nice!
    Now, about the 100% clay pond that's spring fed. . . I'm so green with envy I can't stand it.
    Jim
  5. #25
    Gold Member
    Join Date
    Oct 2008
    Posts
    287
    Southern Maine
    Interesting evolution of the the pond.... The fire chief wanted me to bury a 40,000 gallon tank in the parking lot so there would be water onsite should there be a fire. After running the numbers, I asked my excavation contractor what the cost would be to dig out the pond, which I knew was all in clay. It was a 10th of the cost of the buried tank and the town thought it was a great idea. The pond was actually designed by a state fisheries employee. What you do not see is the smaller pond that is connected to the large pond with a 4" pipe. During a heavy rain, the maximum amount of water that will flow into the pond is whatever will fit through the pipe. the rest overflows into a swale that goes around the pond. since last fall, it has been a steady flow of 7000 gallons of spring water a day...
  6. #26
    Gold Member
    Join Date
    Oct 2008
    Posts
    287
    Southern Maine
    here is an aerial picture and you can see the smaller pond that feeds the larger one. the other pond by the building is the storm-water pond....
    Attached Thumbnails Attached Thumbnails New Dairy-plant-jpg
  7. #27
    Gold Member
    Join Date
    Jul 2009
    Posts
    434
    Central Illinois
    JD 4120
    Don't forget the equipotential ground plane.
  8. #28
    Join Date
    Feb 2010
    Posts
    161
    N. IL
    Kioti CK 27 shuttle
    That looks like one heck of a setup. Will you be able to see over the peak of the barn from your house? I imagine it would make for quite the view. Do you plan on stocking any of the ponds?
  9. #29
    Gold Member Ranger Rick's Avatar
    Join Date
    Aug 2007
    Posts
    315
    Louisa, VA East of Charlottesville
    Kubota L3940
    That is a beautiful barn. How big is it?
    Rick
  10. #30
    Super Member
    Join Date
    Apr 2000
    Posts
    5,673
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    Don't let my wife see that barn she would want to use it as a house. Very first class.
    MarkV
Similar Threads
  1. skidsteer attachments for dairy
    By slimdairylate in forum Private Party Ads
    Last Post: 11-20-2011, 11:02 AM
  2. Starting a dairy farm
    By Waldershrek in forum Related Topics
    Last Post: 12-09-2009, 12:57 PM
  3. Scruton Dairy owner killed by Harrow Sunday
    By plowking in forum Safety
    Last Post: 06-03-2008, 09:52 PM
  4. Cellar under old brick dairy barn? (no tractors)
    By besserheimerpha in forum Projects
    Last Post: 02-02-2006, 07:33 AM
  5. Replies: 19
    Last Post: 02-09-2004, 10:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
