Results 1 to 9 of 9
  1. #1
    Silver Member gcp's Avatar
    Join Date
    Mar 2007
    Posts
    242
    Default Water tank
    I recently purchased this 1200 plus litter tank but I don't know what was kept in it. I'd like to use it as a water tank collector to water the fields so I put chlorox in it and water to help clean it. Is there any other substance you'd recommend that would be more effective?
    It also has this valve which I'd like to connect a water hose to, does anyone know from the looks of it what adapter I'll need? I plan to call the manufacturer in the next couple of days but thought I'd check here first.
    Thank you,
    gcp
  2. #2
    Platinum Member tractorshopper's Avatar
    Join Date
    Dec 2009
    Posts
    954
    Upstate South Carolina
    Kubota BX2380
    Default Re: Water tank
    Don't know about the cleanout, but that hose connection is a cam lock hose common in chemical plants. That end will need the cam lock with two "dog ears" that once you slide the hose over it, they'll be perpendicular to it sticking out and you pull them together (parallel to the hose) to lock the hose in place. Most have a ring on each dog ear that you can zip tie around the hose and through the rings to hold in place. Can't tell the size from the picture, but you may have to have a hose made to fit that end then adaptor to a regular garden hose depending on what you are trying to do with it. Maybe you'll luck up and find the right hose already in existence.
  3. #3
    Join Date
    Dec 2009
    Posts
    954
    Kubota BX2380
    Here, found a picture
    Water tank-cam-hose-jpg
  4. #4
    Veteran Member Combustix's Avatar
    Join Date
    May 2011
    Posts
    1,496
    NW WA
    Kubota B2710
    You did what I would have done, clorox and water to the top and let it sit awhile. I would get a hold of the manufacturer just to find out before I started using it.
  5. #5
    Join Date
    Jul 2003
    Posts
    1,993
    MN
    Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
    Many of those have farm chemicals in them.
    Amonnia is a lot better at nuetralizing & cleaning those out of the tank. There are also some granular products you can get at a farm supply store that will clean out farm chemicals.
    I'd not rust any of that for drinking, but a couple flushes, one sitting over night, wouls be good enough for watering plants.
    --->Paul
  6. #6
    Join Date
    Mar 2007
    Posts
    242
    Will do, thanks a bunch guys!!
    gcp
  7. #7
    Join Date
    Mar 2007
    Posts
    242
    This morning I will empty out the cloroxed water and use Nutra-sol as a second cleaning agent. That should do the trick.
    gcp
  8. #8
    Platinum Member brokenknee's Avatar
    Join Date
    May 2010
    Posts
    569
    South of Moose Lake MN
    I am sure you are already aware of this, but do not mix ammonia and bleach it gives a very nasty result. If you are going to add ammonia make sure all the bleach is thoroughly flushed out.
    "Clarity to Agreement" Dennis Prager
  9. #9
    Join Date
    Mar 2007
    Posts
    242
    You are absolutely correct, no amonia and clorox mix, ever!
    As a matter of fact I emptied out the clorox water to add the Nutra-sol, just in case. Better to be safe than sorry. The Nutra-sol seems to be cleaning all the crud stains inside the tank, an added benifit to all this work! I'll let it seat for a week or two and then water the fields with this mixture.
    gcp
Similar Threads
  1. water tank connections and foundation ?
    By bcarwell in forum Projects
    Last Post: 11-10-2011, 01:02 PM
  2. Water Wagon Tow Capacity
    By NevadaMOGuy in forum Kubota Owning/Operating
    Last Post: 10-15-2011, 03:38 PM
  3. Press. Tank, Press. Switch Question
    By jimainiac in forum Rural Living
    Last Post: 02-11-2007, 06:38 AM
  4. Water Pressure Tank question
    By Shimon in forum Rural Living
    Last Post: 08-29-2006, 04:39 PM
  5. How to properly disinfect your water well......
    By Junkman in forum Rural Living
    Last Post: 07-29-2005, 12:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
