Page 24 of 33 FirstFirst ... 1421222324252627 ... LastLast
Results 231 to 240 of 326
  1. #231
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Default Re: Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundatio
    Phase 4 (the roof) is now done. Yaay!! It can rain all it wants, now.
    I finished the ridge vent and ridge cap tonight. It was getting dark again by the time I got done, so no pictures. I plan to spend some quality time in the daylight with a tube of blackjack in hand checking for exposed nails, etc. Then I'll take down my scary ladder and move on to phase 5: doors, windows, and house wrap.
    Actually... I'll probably build the stairs before I tackle the doors and windows.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  2. #232
    Elite Member
    Join Date
    Sep 2008
    Posts
    2,926
    Midwest
    Ford 1210 / Ford 1710
    That has to be a relief to almost be dried in before winter. Great job and keep it up!
  3. #233
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    So, good news... It's been raining here for two days now. I checked the underside of the roof and there are no wet spots. There's a nice drip line on the pasture side of the structure, and the walls are dry. That's a good sign that I installed the roof right.
  4. #234
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Sounds like you timed it right! Being in the dry sure takes the pressure off eh?
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  5. #235
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Quote Originally Posted by MotorSeven View Post
    Yes. Some windows and doors will make it even better.
  6. #236
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    I built some stairs on the North end of the shop (under the shed roof). These stairs took WAY too long to build, but they are done now. I'll add a handrail later. Once the stairs were done I spent some time shuttling tools and materials back into the garage. It was nice to have the stairs.
    The stringers are recycled lumber and the treads are some Trex decking that I picked up for cheap at a yard sale. I barely had enough of the decking. I nailed and glued blocks on the sides of the stringers to support the treads, and the risers are screwed top and bottom to provide additional support. I don't have a stringer in the middle of the stairs. In the spirit of maximizing storage space, I kept the area clear under the stairs for additional storage.
    Attached Thumbnails Attached Thumbnails Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation-root-cellar-outside-stairs-jpg
  7. #237
    Platinum Member GLyford's Avatar
    Join Date
    Feb 2009
    Posts
    917
    MA
    Love the posts. Going to use rail for a handrail?
  8. #238
    Elite Member Depmandog's Avatar
    Join Date
    Nov 2010
    Posts
    2,598
    Buckner MO, LaPlata MO
    2005 Kubota L5030 GST; Farmall 706, 756, 806 & 1086
    Default
    Quote Originally Posted by Iplayfarmer
    One nice thing about building a structure in a rural area is the absence of government intervention. You get to build a building anyway you want. However, I recall from your previous posts your are trying very hard to comply with all applicable building codes. Because of your comment, I felt compelled to share my concerns:
    You are going to need to keep a close eye on your stair treads.
    Per table 2 of the attached link, you will find that the maximum span on the deck boards is 12".
    http://homedepot.trex.com/trex/group...xmd_000929.pdf
    I know you mentioned screwing the risers together / to the treads and that might give you enough support - but I would caution you to pay close attention to possible tread failure especially when the temps start to rise and the plastics began to soften and lose strength.
    Reminds me of story that I was told by a state OSHA inspector (he was a big, big man). He went to a construction site, climbed the 4 steps to enter the job trailer - and the stairs collapsed. He wasn't seriously hurt, but the contractor ended up with a big fine.
    Those stairs might have made it the entire job had this 380 pound man stayed away. Or they might have collapsed when someone else was hauling in something heavy. And eventually they would have failed under normal use.
    I guess the moral to your story - I see a failure potential and felt obliged to give you a heads up.
    Dean
  9. #239
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Default
    Quote Originally Posted by Depmandog
    Thanks for the input. I will keep an eye on the stairs. I had figured that I could add a center stringer if I need to later. The trick will be figuring what to anchor it to at the bottom. I also need to reinforce the bottoms of the stringers.
    These stairs have cost me nothing but time. At worst they are a temporary measure until I figure something else out. At best they work like I hope and serve me well.
  10. #240
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Default
    Quote Originally Posted by GLyford
    It would be cool to put up some narrow gauge type train rails, wouldn't it. I saw some a few years ago at an auction in an old mining community. I wondered what a guy would ever do with it, but now that you mentioned the rail I'm wondering if I should have bid on it.
Similar Threads
  1. Pole building -- Pole technology discussion
    By jimgerken in forum Projects
    Last Post: 05-26-2011, 07:44 PM
  2. Building Pole Shed on Slope
    By Chris611 in forum Rural Living
    Last Post: 08-14-2006, 03:10 PM
  3. I burned my storage building today
    By RSKY in forum Rural Living
    Last Post: 05-03-2006, 02:58 PM
  4. pole barn squareness?
    By mopower440 in forum Projects
    Last Post: 01-14-2004, 12:45 AM
  5. building a root cellar
    By EILEEN in forum Rural Living
    Last Post: 04-25-2001, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
