Results 261 to 270 of 308
11-21-2012, 11:57 PM #261Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
- Massey Ferguson 1215, Toro 266-H, Pennsylvania Panzer, Case 444, Craftsman 14/6
Re: Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundatio
This Thanksgiving I'm thankful for a little free time to work on the workshop. I installed the second door and I installed a window. Dinner isn't until 4:00 tomorrow, so I may get some stuff done in the morning.
From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
11-23-2012, 12:02 AM #262Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
Today went really well. I got all of the windows installed. I ran out of flashing tape on the last window. After I get the flashing tape I'll finish taping up the last window. I also need to get some metal flashing for the door to the basement. It is HUGE to have the windows in. Here are some pictures of inside and out.
The next step is to make the garage style door and get it installed. Then I'll take some time off to finish up some projects on the house.From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
11-24-2012, 06:42 PM #263Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
I need some help thinking through the pros and cons of how to insulate my garage door. My plan includes a wooden frame with an insulated core and a skin of 1/4" plywood. I have some styrofoam pieces that are 1.5" thick (pictured). I figure I have 3 options...
1) Make the core 1.5 inches thick and use a single layer of styrofoam: Overall door thickness = 2". Overall R-value = 7
2) Double the styrofoam and make the core 3 inches thick: Overall Door thickness = 3.5". Overall R-value = 14.
3) Buy something else completely and make it as thick as I want.
How cumbersome will a 3.5" door be? Is it worth the extra R-value? Is it worth the extra money to buy a different core?From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
11-24-2012, 11:13 PM #264Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,312
- Location
- Buckner MO
- Tractor
- 2005 Kubota L5030 GST; Farmall 706
Refresh my memory on the door size, and if you want it to be a sectional overhead, a one piece lift up, a one or two piece slider or double door outward opening hinged door.
Originally Posted by Iplayfarmer
Dean
"Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
11-25-2012, 08:45 AM #265Elite Member
- Join Date
- Aug 2005
- Posts
- 3,170
- Location
- NE TENN (Hancock Co)
- Tractor
- Kioti DK40SE Hydro
I'd go 3.5.
2008 KIOTI DK40Se Hydro
1978 Sling Blade/wood handle
11-25-2012, 02:14 PM #266Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
The door is 6' wide X 7' high. It is in three sections, and it will roll up on garage door style tracks. I have a two different torsion springs to choose from so that I can have the right size.
11-25-2012, 06:09 PM #267Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
In doing a little of my own research I found this article... Energy-Efficient Garage Doors | GreenBuildingAdvisor.com
The take home message as I see it is that no matter what kind of insulation I use, the more important part is sealing up the door against air leaks.From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
11-25-2012, 11:02 PM #268Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,312
- Location
- Buckner MO
- Tractor
I concur! My building has 2 insulated overhead garage doors 10'x12', and one barn slider - insulated that I fabricated on site - 16'x 14'. The overhead doors seal pretty well (commercial). My slider leaks air. No more than I use it, I should never had built it. In fact, I keep it covered with plastic (north side of the building) to keep the drafts down.
You can see partially see my slider covered with plastic. Pay no mind to my boy. We were just having some guy time this weekend as he was home from college.Dean
11-26-2012, 12:18 AM #269Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
11-26-2012, 07:19 AM #270Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,312
- Location
- Buckner MO
- Tractor
I only have 1" polystyrene insulation board, which is comparable to what's in the commercial overhead doors.
The weatherstripping between the sections sounds like a good idea. I have seen some wooden doors with a routered mating profile between the sections also.
Personally, I don't think I would get carried away trying to make this door super thick. If you wander from standard sizing, your track would need to stand off from the wall more.Dean
Similar Threads
Pole building -- Pole technology discussion
By jimgerken in forum ProjectsReplies: 4Last Post: 05-26-2011, 07:44 PM -
Building Pole Shed on Slope
By Chris611 in forum Rural LivingReplies: 8Last Post: 08-14-2006, 03:10 PM -
I burned my storage building today
By RSKY in forum Rural LivingReplies: 15Last Post: 05-03-2006, 02:58 PM -
pole barn squareness?
By mopower440 in forum ProjectsReplies: 134Last Post: 01-14-2004, 12:45 AM -
building a root cellar
By EILEEN in forum Rural LivingReplies: 2Last Post: 04-25-2001, 07:23 PM
