Page 28 of 31 FirstFirst ... 1825262728293031 LastLast
Results 271 to 280 of 308
  1. #271
    Join Date
    Feb 2012
    Posts
    537
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Default Re: Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundatio
    You could add, 2x4s flat on wall as spacers for your track mounts, to allow the addition of 1.5" more foam. I wolud go for the added R-value.
    Dave
  2. #272
    Gold Member NormL's Avatar
    Join Date
    May 2011
    Posts
    386
    Manitoba, Canada
    Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
    Do you know the ratings for the torsion springs you want to use? The reason I'm asking is that when I built the overhead door for the garage/shop I built years ago when I lived in Winnipeg, it turned out really well - but shockingly heavy. The springs I had scrounged (remember, I'm a proud cheapskate!) were off a much lighter door. It had been a 9'x11' aluminum overhead. What I built was a 9'x16' wood with Styrofoam inserts. I don't know what the aluminum door weighed but not nearly the 600 or so pounds that wooden one did! You wanna guess how fast I found out how much I didn't know what I was doing?
    Knowing how thoroughly you plan things, you probably have made allowance for this...but just in case.
    I miss Paul Harvey News!
  3. #273
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Massey Ferguson 1215, Toro 266-H, Pennsylvania Panzer, Case 444, Craftsman 14/6
    Quote Originally Posted by NormL View Post
    I calculated the weight based on lumber weight tables. Then I had a garage door guy help me with all the hardware. He gave me two sizes of springs so that I'm more likely to have one that works.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  4. #274
    Join Date
    May 2011
    Posts
    386
    Manitoba, Canada
    Quote Originally Posted by Iplayfarmer View Post
    Ahh! I was right about how you plan carefully. That shop is looking better all the time.
  5. #275
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Default
    Thanks.
  6. #276
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Default
    I cut out the frame for my garage door. I've decided to go with 1.5" for now. If I find that the area around the door is too cold I can make a thicker door later.
    Attached Thumbnails Attached Thumbnails Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation-image-1659912549.jpg
  7. #277
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Default
    Here's the foam core.
    Does anyone have any suggestion on how to cut styrofoam? I've tried a few things and ended up with a serrated kitchen knife.
    Attached Thumbnails Attached Thumbnails Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation-image-526365285.jpg
  8. #278
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    13,592
    Tyler, Texas
    Several, all used and abused.
    I like to use a regular hand saw to cut styrofoam.
    Eddie
  9. #279
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Default
    Thanks, Eddie. I may try that. The kitchen knife cuts okay, it just leaves a rough edge and gets fluff all over the place.
    Here's a picture of the top panel done.
  10. #280
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Oops... Here's the picture.
    Attached Thumbnails Attached Thumbnails Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation-image-850298535.jpg
Similar Threads
  1. Pole building -- Pole technology discussion
    By jimgerken in forum Projects
    Last Post: 05-26-2011, 07:44 PM
  2. Building Pole Shed on Slope
    By Chris611 in forum Rural Living
    Last Post: 08-14-2006, 03:10 PM
  3. I burned my storage building today
    By RSKY in forum Rural Living
    Last Post: 05-03-2006, 02:58 PM
  4. pole barn squareness?
    By mopower440 in forum Projects
    Last Post: 01-14-2004, 12:45 AM
  5. building a root cellar
    By EILEEN in forum Rural Living
    Last Post: 04-25-2001, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
