Page 31 of 33 FirstFirst ... 21282930313233 LastLast
Results 301 to 310 of 326
  1. #301
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Massey Ferguson 1215, Toro 266-H, Farmall Cub, Farmall A
    Default Re: Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundatio
    I finished up some projects for SWMBO and I should get some time now to put up the siding. It's well aclimated now, since it's been sitting on the trailer in front of the garage for a month.
    A few questions...
    How big of a deal is it to use galvanized vs. stainless nails? I can't find stainless anywhere around me, but I live in a pretty arid climate. Is it just humid and coastal areas that have problems with stains from the galvanized nails?
    Should I use furring strips to create and air gap under the siding? That's an extra step. It's not a lot of extra cost, but it may put my siding out proud of the window trim and the door jambs.
    I'd love to hear thoughts on it.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  2. #302
    Platinum Member GLyford's Avatar
    Join Date
    Feb 2009
    Posts
    922
    MA
    My gut feeling is no furring strips needed, and go with the galvanized, that's how my house was done 30 years ago. I'm just now dealing with a few split or cupped clapboards, but no rot. On the other hand, most of the cornerboards are junk, but they were untreated and never primed on the back. Since they were put up over tarpaper the house itself under them is fine. I replaced some a few years ago with treated, but they don't hold paint very well. The latest I've used the PVC trim boards (couple different brands, no preference).
  3. #303
    Elite Member Depmandog's Avatar
    Join Date
    Nov 2010
    Posts
    2,598
    Buckner MO, LaPlata MO
    2005 Kubota L5030 GST; Farmall 706, 756, 806 & 1086
    Default
    Here is a link that you will find useful. Galvanized nails are fine.
    http://www.wrcla.org/cedarspecs/installing/nails.asp
    They also show proper nailing techniques a bit later in the website.
    I have bevel cedar on my house. I used red rosin paper underneath.
    Dean
  4. #304
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    Default
    Well, they have stainless screws and nails. I seem them at lowes. if you don't care about rust streaks in 2 to 5 years, then by all means use cheaper galvanized nails.are you painting over everything? That would help.
  5. #305
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Quote Originally Posted by radioman View Post
    I'm going with stain vs. paint. I've been to every hardware store I know in 3 towns. No stainless siding nails. I know people do siding around here, but they must not use stainless nails. I've already bought the galvanized nails. I'll just have to take my chances.
  6. #306
    Gold Member
    Join Date
    Aug 2007
    Posts
    347
    southeastern PA
    Kubota BX2200, Gravely mower
    Around here they attach siding using aluminum nails. No worry about rust stains.
  7. #307
    Join Date
    Nov 2010
    Posts
    2,598
    Default
    Here is a hint that will save you some time and frustration...if that cedar siding was anything like mine (very dry and easy to split).
    Nailing my 6" beveled edge cedar siding required me to pre drill every nail hole. So I made a drilling jig using a straight 1x6. Very carefully laid out the nailing pattern so I could use it from either end. On the bottom of the 1x I attached thin ply scraps as stops to reference the siding bottom.
    The last nail nearest the corner board would require me to drill that one in-place, so I made a small pocket jig for that hole.
    Most of the siding I installed by myself, so the pre drilling made it easy to hang the long boards..allowing me to start in the middle of a long piece without having to have a third hand.
    Dean
  8. #308
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Quote Originally Posted by Depmandog View Post
    Great Advice. I'll be hanging most of this myself, so any little bit helps.
  9. #309
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Default
    I have hung the first of the siding on the shop. It took a while getting everything ready (trim, etc.), but once I started hanging siding it's going pretty fast. I took the picture early this evening. I've done a little more since then.
    Attached Thumbnails Attached Thumbnails Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation-image-4262123713-jpg
  10. #310
    Join Date
    Jul 2005
    Posts
    5,238
    Idaho
    Followup picture showing the other 4 pieces of siding that I put up Saturday evening...
    I'm hoping for some more time tonight to put up more siding.
    Attached Thumbnails Attached Thumbnails Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation-workshop-siding-2-jpg
Similar Threads
  1. Pole building -- Pole technology discussion
    By jimgerken in forum Projects
    Last Post: 05-26-2011, 07:44 PM
  2. Building Pole Shed on Slope
    By Chris611 in forum Rural Living
    Last Post: 08-14-2006, 03:10 PM
  3. I burned my storage building today
    By RSKY in forum Rural Living
    Last Post: 05-03-2006, 02:58 PM
  4. pole barn squareness?
    By mopower440 in forum Projects
    Last Post: 01-14-2004, 12:45 AM
  5. building a root cellar
    By EILEEN in forum Rural Living
    Last Post: 04-25-2001, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
