Results 31 to 40 of 308
04-15-2012, 06:32 PM #31
Re: Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundatio
thats the way to go iplayfarmer. Afterall we dont have midget sized freinds readily available.
04-16-2012, 12:21 AM #32Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
- Massey Ferguson 1215, Toro 266-H, Pennsylvania Panzer, Case 444, Craftsman 14/6
My kids worked their tails off yesterday. We cleaned up a bunch of old debris that was on the ground around where I needed to dig post holes. They worked together to hold the tape measure while I marked where the holes go. My youngest helped dig the rocks out of the bottom of the holes. My oldest helped her mom weed the raspberries. They all helped me tear down some fencing that was in the way.
They definately earned their dinner that day.From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
04-18-2012, 11:49 AM #33Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
I'm progressing in baby steps. I set most of the anchor bolts last night. I'm much more comfortable with my concrete work than I was with my masonry work.
I ran out of concrete, though. I have one more hole in the bricks to fill. It's the column right next to the door. I'll pick up another couple of bags and do the last of the concrete maybe tomorrow.From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
04-18-2012, 01:06 PM #34Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,309
- Location
- Buckner MO
- Tractor
- 2005 Kubota L5030 GST; Farmall 706
I just noticed you don't have anything other than mortar to bond the new top row of blocks to the existing blocks. I think I would drill some holes into the top course of the old block, insert rebar and fill the cavity with concrete. It would add quite a bit of strength to the structure. Technically, the rebar should be epoxied i(or grouted) n place for max strength.
Hate for a storm to wreck your addition.
My two centsDean
"Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
04-18-2012, 01:48 PM #35Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
Thanks for the input. I think I have it covered, but see the explanation below and tell me if you think I still need to do more...
The old cellar had every third hole filled. The two columns I demolished for the doorway had re-bar in them, so I assume that the others have rebar too. The were old bolts sticking out of the old brick to hold the sill down. I left the old bolts (with nuts) in the concrete and filled around them. My plan is that the old bolts will bond the new concrete to the old and hold it all together.From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
04-18-2012, 05:19 PM #36Veteran Member
- Join Date
- Jul 2009
- Posts
- 1,284
- Location
- IL
- Tractor
- B2710
Too bad the cold war is over, that would make a great bomb shelter. I admire your grit doing so much work to recoup that cellar, I'm tired just reading about it.
B2710, LA402, PHD, 5' Ford 908 bush hog, New Idea manure spreader, dump trailer, 3PT generator, Swisher trail mower, Toro Zmaster ZTR mower
04-18-2012, 07:20 PM #37Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,309
- Location
- Buckner MO
- Tractor
I apologize. Could have swore I went back and looked at your pictures - don't know how I missed that. I guess I might have dozed off and just thought I did!
Originally Posted by Iplayfarmer
I am looking forward to reading about your project! Keep up the good work.Dean
04-18-2012, 07:42 PM #38Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
04-18-2012, 10:17 PM #39Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
Just keeping track of expenses again. I spent another $11 today on concrete.
04-19-2012, 02:11 PM #40Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
Similar Threads
Pole building -- Pole technology discussion
By jimgerken in forum ProjectsReplies: 4Last Post: 05-26-2011, 07:44 PM -
Building Pole Shed on Slope
By Chris611 in forum Rural LivingReplies: 8Last Post: 08-14-2006, 03:10 PM -
I burned my storage building today
By RSKY in forum Rural LivingReplies: 15Last Post: 05-03-2006, 02:58 PM -
pole barn squareness?
By mopower440 in forum ProjectsReplies: 134Last Post: 01-14-2004, 12:45 AM -
building a root cellar
By EILEEN in forum Rural LivingReplies: 2Last Post: 04-25-2001, 07:23 PM
