Depmandog
Elite Member
- Joined
- Nov 26, 2010
- Messages
- 2,556
- Location
- Buckner MO, LaPlata MO
- Tractor
- 2005 Kubota L5030 GST; Farmall 706, 756, 806 & 1086
36" away from an unprotected wall. That's for your stove pipe and any stove that's not rated (tagged). Single wall radiant stoves are 36" clearance.
Keep in mind the flue exhaust on a stove may come out the back or the top. If it comes out the top, and you had your chimney preset at 36". - you would have to install a heat shield on the wall (assuming radiant SW stove.) The back of the stove would be closer than 36".
200 SF. Won't take much to heat that. Personally think the floor space a stove would take up makes it impractical. Plus the chimney cost (it's not cheap). As was mentioned - ventless propane wall unit would be perfect.
