Results 11 to 20 of 95
04-06-2012, 03:26 AM #11Platinum Member
- Join Date
- Jun 2010
- Posts
- 862
- Location
- Annapolis Valley, Nova Scotia
- Tractor
- MF 135 Z134 Continental, MF 1660 Cab
Re: my deck/patio project
Going to be a nice size, are you planning to step the levels at all or keep it all the same height?
04-06-2012 03:26 AM # ADS
04-06-2012, 06:30 AM #12
04-06-2012, 12:43 PM #13Gold Member
- Join Date
- Nov 2007
- Posts
- 490
- Location
- South Carolina
Are you going to have a roof over it?
I want to do about the same thing, but I want to run a roof over it perpendicular to our main roof's ridge line and I want the deck/patio to have the same type roof as the house has rather than a flat roof.
My thinking is if I tied it into our house's roof I could possibly vault the living room's cieling at the same time (likely a pipe dream though).
Any thoughts on this.
PS it looks great.IHC 424 Diesel
Ford 917 Flail Mower
04-06-2012, 06:41 PM #14Silver Member
- Join Date
- Nov 2011
- Posts
- 113
- Tractor
- kubota B1750HST4x4
question
did you coat the 6x6 posts with anything before encasing in concrete?
will the posts last a long time if sitting underground in concrete?
I'm in the process of planning a deck that I will then mount a quonset hut onto, and am trying to research the best procedure for the foundation.
04-06-2012, 08:45 PM #15
1993 Bolens 1468: 38" snow blower,front blade and 42"MMM
2007 MF GC2310 TLB: 60" MMM
04-06-2012, 08:47 PM #16Silver Member
- Join Date
- Mar 2010
- Posts
- 130
- Location
- East Texas
I am doing basically what you have in mind. I have a workshop (30x40) with an outside concrete slab 20x18. I have spent many years working out there in the hot sun. So I am adding a roof that will tie into the shop. From the air it will have a T shape. It will have 4/12 pitch to match the shop roof. I set my last support pipe in concrete today. Debating starting a thread on it and a shed I am going to build.
My limited knowledge about setting wooden posts is that there are 2 recommended ways. One is pour a footing for the post and use a post anchor to attach the post to the footing. The other is dig your post hole and pour about 4" of gravel into the hole, level, set post, pour another couple of inches of gravel then concrete. Also make the bottom of the hole wider than the vertical sides.
I have use both methods. For a flat roof over my back patio I went with anchor method. For a carport off of the work shop I set PT 4x4 in concrete. That was in 1990. I have not experienced any problems.
04-06-2012, 08:51 PM #17
depending on your codes,you may not be allowed to concrete around the post.
In my case,I drilled a 40" hole and mixed 1, 80# bag of concrete per hole and poured it in the hole.After it dries, you drop the post in the hole and the concrete acts as a footer.
I have heard of people using a rubber type boot around the post before placing it in the hole.
They should last 25 years + without a problem.1993 Bolens 1468: 38" snow blower,front blade and 42"MMM
04-06-2012, 08:59 PM #18
Moving along
I got off to a late start tonight (my helper was late getting to my house).
but I did get quite a bit done.the support beam is in and some of the floor joist.
Tomorrow I will be laying down the plastic and gravel and setting the rest of the floor joist.
They are calling for rain Sunday ,so I will get the day off
that is all for today.1993 Bolens 1468: 38" snow blower,front blade and 42"MMM
04-06-2012, 09:05 PM #19
04-06-2012, 11:09 PM #20Super Star Member
- Join Date
- May 2003
- Posts
- 13,665
- Location
- Tyler, Texas
- Tractor
- Several, all used and abused.
Using a properly attached ledger board will give the deck more strength then a free standing deck. The mass of the existing building creates a solid, unmoving side to the deck. It just about eliminates racking on decks that are just a few feet above grade, and there is no twisting like you see in free standing decks. You will have a stronger deck, with less material.
While your points of having to deal with inspections and insurance have some validity, all that really means is that they are going to make sure that it's built to a minimum standard.
Free standing decks are used on mobile homes around here because there isn't a good way to secure a ledger board to the side of them.
EddieLink to my thread creating Lake Marabou. http://www.tractorbynet.com/forums/p...ting-lake.html
Link to my thread on Oscar, my pet pig. http://www.tractorbynet.com/forums/r...-now-what.html
http://www.facebook.com/#!/EdwardDavidWalker
Similar Threads
My Pond Project
By ETD66SS in forum ProjectsReplies: 113Last Post: 03-29-2012, 10:19 AM -
B5200 Project tractor contined. Turbo time.
By ripplefct in forum Kubota Owning/OperatingReplies: 23Last Post: 03-24-2008, 05:33 PM -
Landscaping Project...perfect for a BX
By KeithInSpace in forum Kubota Owning/OperatingReplies: 9Last Post: 07-11-2007, 11:33 AM -
Project #1 of 3
By NoTrespassing in forum ProjectsReplies: 23Last Post: 09-29-2004, 09:03 PM -
Culvert Project
By Harv in forum ProjectsReplies: 72Last Post: 04-04-2001, 02:47 AM
