Results 1 to 8 of 8
04-07-2012, 08:08 PM #1New Member
- Join Date
- Mar 2012
- Posts
- 20
- Location
- Coastal Maine
- Tractor
- Kubota B3300
Shed roof garage addition
I'm planning a shed roof addition to our saltbox garage--about 15 x 30, gravel floor, pole or pier-and-post construction, attached to the back of the garage, pitched roof to pitched roof, to house my new Kubota B3300--and I have a few questions: 1.) Do I need to remove the sod, or can I simply lay a moisture barrier and the gravel over the sod? Assuming the sod must go, how thick should the gravel layer be in Maine? 2.) Can I dig holes for the poles or piers with my new backhoe, or should I buy or rent a posthole digger? What would be the technique with the backhoe--will it dig a hole with a 16" bucket straight down to, say, four feet? 3.) Are 4x4's sufficient for this addition as it will be attached to the garage roof and supported by 8 posts, or should I use 6x6's? Thanks for the advice.
04-07-2012, 08:51 PM #2
Re: Shed roof garage addition
The 4x4s should be fine, especially if you use tin, but even with shingle weight i feel thats plenty. I would not dig with a back hoe, the ground around will be all loose and not compacted as if you dug a post hole, around the hole the post will go in.
Why would you put a moisture barrior down for gravel? I would just put the gravel if you want gravel and then spray roundup (glyphosate) to kill what grows through it.YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
1991 Javalen 17ft w/same year 150 Johnson GT
Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
04-08-2012, 06:57 AM #3Platinum Member
- Join Date
- Sep 2010
- Posts
- 633
- Location
- Eastern Ontario
- Tractor
- Kubota MX5100
Well you're likely to get different responses from different people. Personally, I would remove the sod and dig down whatever is required to get rid of at least the topsoil. I would then fit and pack with gravel and top with '3/4 less' and pack. As for the 4x4's, 15x30 is a large area with a shed roof and snow load. I would prefer 6x6 with at least 2"x8" girders. Digging with your BH will work fine. It is difficult however to get a small hole dug with a BH compared to an posthole digger but I used my BH on all the piers for my garage.
2011 Kubota MX5100, BH92, BH BB72, Walco Bush Hog and Snowblower, Wallenstein 310 Splitter & Forks
04-08-2012, 10:29 AM #4
Sorry i dont even consider snow down here!! I did get as heavy as a snow as we probly will ever get last year no prob on my shed though.
04-08-2012, 02:34 PM #5
I put a shed up last year about the size your planing.Went with 4x6's post and 2 x6's for the rafters 16 in on center.Used 2x10's to hang the rafters.No problem with the snow load even thought we only had 2 good snows.I live in Pa in the Poconos so not as much snow as you get.Here are some pictures.
04-08-2012, 02:48 PM #6
04-09-2012, 12:25 PM #7New Member
- Join Date
- Mar 2012
- Posts
- 20
- Location
- Coastal Maine
- Tractor
- Kubota B3300
Thanks for the replies and cautions. I'll definitely keep the snow load factor in mind.
04-09-2012, 12:51 PM #8Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,491
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
I would kill the grass and then put plastic down and put about 4 in of rock ,gravel, or whatever. You could pour some cement later if desired.
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
Similar Threads
Contractors ??
By B7510HSD in forum ProjectsReplies: 12Last Post: 01-08-2012, 10:18 PM -
"Rainhandler" anyone using it? opinions?
By Richard in forum Rural LivingReplies: 12Last Post: 01-12-2009, 01:11 PM -
Contractor queston: when is "under roof" under roof?
By Richard in forum Rural LivingReplies: 11Last Post: 01-03-2009, 05:37 AM -
Help with a floor in a portable garage
By Mustangous in forum ProjectsReplies: 23Last Post: 07-30-2008, 02:33 AM -
Garage or outbuilding and retaining wall
By 5030tinkerer in forum Rural LivingReplies: 2Last Post: 02-06-2008, 03:02 AM
