Page 7 of 9 FirstFirst ... 456789 LastLast
Results 61 to 70 of 81
  1. #61
    Elite Member schoolsout's Avatar
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Massey Ferguson 1533
    Default Re: It has finally begun...
    Got the roof on last week...been slammed at the job lately, but here are a few pics. Plumbing has been roughed in and concrete guy should be coming this weekend...I hope.
    Power company is starting to go backwards on us now...saying it's more expensive to run power and the "new boss" is more of a stickler. It has finally begun...-dscn1170-jpgIt has finally begun...-dscn1187-jpgIt has finally begun...-dscn1186-jpg
    __________________________________________________ _______
    "The greatest shortcoming of the human race is our inability to understand the exponential function." -
    Prof. Al Bartlett
    Any person is entitled to their own opinion, but not to their own facts and outcomes. So one may believe as they will, but will be held accountable by the numbers for their beliefs. At the end of the day, life is a school of probability. Jesse via Jesse's Cafe Americain
  2. #62
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Went back out in 100+ temps yesterday and planted another acre. This pic is of bird seed planted about 5 weeks ago. Any sunflower that was growing is now gone. Deer and turkey have been milling about in it lately. Part of this is planted on the new ground and apparently, the birdseed doesn't like much fertilizer...burned some earlier plantings with 12-12-12. The stuff growing sporadically that was spread by equipment when we had the area cleared is growing quite well (the sorghum we planted on perimeter of cleared field).
    It has finally begun...-seed1-jpgIt has finally begun...-seed2-jpg
    Prof. Al Bartlett
  3. #63
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Power company is giving us a hard time...should have gone ahead and done the power last year, but it was about $6500.
    Now, since it is just a shed at this point, they want to see the plans for the house (which we don't really have as we weren't permitting it (just permitted the pole shed as dimensions wouldn't change and doubt anyone will ever check it out) to make sure we aren't just doing a shed. Problem is, even if we had plans and a permit, we planned on finishing this longer than the 6 months given for a permit before a CO is needed.
    May just do a generator (for well and a few lights when needed) until we can get the walls up and show them it isn't just a "shed."
    Prof. Al Bartlett
  4. #64
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Have you kicked around solar? It's come way down in price, then you could thumb you nose at the power company and their $6500. No way would I pay that to hook up.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  5. #65
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Quote Originally Posted by MotorSeven View Post
    I'll definitely do solar out there later on when (assuming I do) build a "real" house. My goal is to get as much from the land as I can regarding food, water, power, etc.
    The cost of the power is high because it needs to be run 500' or so underground from what I can tell. We are also seeing what the difference would be with it running above ground on poles (I'd rather have it underground, but wouldn't mind the poles because where they would be located is along the edge of the ~8 acre field and it should attract doves). I think the main hiccup with the power company is they are on a more strict budget as they are working on some nuke projects (SCE&G).
    Prof. Al Bartlett
  6. #66
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Power is in the process. Mostly above ground. Well will be drilled once power is out there. Also, have quote on materials/labor for enclosing building.
    Recently, have planted 14 pear/plum/apple trees (hope they do ok), 5 pecans (one got mauled by a buck where about a foot of bark all around was rubbed off. It's still kicking, but wonder if it will ultimately make it?), 2 loquats, 2 figs and have some other pecans/pin oaks/etc to finish up.
    Prof. Al Bartlett
  7. #67
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Power is hooked up.
    Went out today to get 4 live oaks in the ground (local nursery is liquidating a bunch of 4-6"+ caliper trees for $50/ea), but only managed one before rain started and temp started to drop. May snow/sleet a bit tonight here so who knows...will try again tomorrow.
    It has finally begun...-tree1-jpgIt has finally begun...-tree2-jpgIt has finally begun...-tree3-jpg
    Prof. Al Bartlett
  8. #68
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,688
    East TN
    Kub - 2K6, B7800
    Thanks for the picture
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  9. #69
    Join Date
    Feb 2011
    Posts
    4,378
    Awendaw, SC
    Few pics from the past 2 or so weeks. Pops managed to get the tractor stuck pretty good. Was disking around cell tower and found exactly where power company laid cable when they ran power to our shed. It had rained a lot just before this, too.
    It has finally begun...-stuck1-jpgIt has finally begun...-stuck2-jpgIt has finally begun...-stuck3-jpgIt has finally begun...-stuck4-jpgIt has finally begun...-stuck5-jpgIt has finally begun...-stuck6-jpg
    It has finally begun...-tractor-1-jpgIt has finally begun...-tractor-2-jpg
    Prof. Al Bartlett
  10. #70
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,239
    Southern Maryland
    Kubota BX24
    That tractor is REALLY stuck! Holy crap!
    Deano
    2006 BX24, 6' Modern Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!!, Agri-Fab drop spreader.
Similar Threads
  1. Finally; finally; finally I get my L3130
    By texbaylea in forum Kubota Buying/Pricing
    Last Post: 07-30-2004, 10:29 PM
  2. Finally Pulled The Trigger
    By lablovers in forum Kioti Buying/Pricing
    Last Post: 03-05-2004, 12:15 PM
  3. Finally got the backhoe
    By grandad in forum Photos
    Last Post: 02-19-2004, 10:51 PM
  4. FINALLY PULLED THE TRIGGER
    By bobmayo in forum Buying/Pricing/Comparisons
    Last Post: 11-20-2003, 08:47 PM
  5. TC18 finally showed up!
    By AndyM in forum New Holland Buying/Pricing
    Last Post: 09-22-2003, 09:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
