Results 1 to 1 of 1
  1. #1
    Elite Member
    Join Date
    Jun 2005
    Posts
    2,678
    Central NH (God's Country)
    1984 Kubota B7200D (Sold 2015,) 2005 L39 Kubota, 2006 RTV 900 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle
    Default Equipment repairs, Excavator Gum Surgery!
    As I patiently wait for kubota to send parts from Japan, so the dealer can get working to repair the damage from my L39's fire,
    http://www.tractorbynet.com/forums/k...e-bad-but.html
    I am going about making some way too expensive repairs and improvements.
    First I changed the hydraulic oil pump on my ok B7200. If the machine had a real filter vs. a course screen strainer, then I bet the oil pump would not have worn so badly. Don't ask what a new pump cost.
    Next I did some work on the L39's bucket as when I get it back, I have quite a bit of material waiting to be moved.
    http://www.tractorbynet.com/forums/k...et-custom.html
    When I was installing new CAT style teeth on my excavator bucket I noticed a crack on the outboard tooth adapter shank. As it turned out, to some degree all the adapters had cracks.
    It could not possibly be due to all tha easy digging.
    http://www.tractorbynet.com/forums/p...e-weekend.html
    I was quoted over $300 to have a heavy equipment shop to cut out the adapter and weld in a new one, so I figured I would give it a try having it repaired by a local welder.
    I needed to get other work done also including fixing up a favorite old push mower.
    The fellow who showed up was real old school, He used a stick arc welder and gas, not TIG or MIG, but he knew how to weld.
    Aside from welding the adapters, I had side cutters added to the bucket, some new teeth on the end of the thumb, a lift chain hook, and had my excavator's trailer hitch receiver repaired. It was squashed from resting heavy boulders on the pusher blade that were to big to transport with the Kubota.
    A trailer hitch receiver on the pusher blade is great for moving heavy trailers around the property. If I had a big dump trailer, for on site work it would be better than a dump truck.
    In all, I spent about $1,500 on all of the above.
    Without my L39, I then just parked my excavator under a shade tree and pondered just how hard it will be to change the alternator belt or should I just wait till it breaks?
    Attached Thumbnails Attached Thumbnails Equipment repairs, Excavator Gum Surgery!-p1010666-jpg   Equipment repairs, Excavator Gum Surgery!-p1010667-jpg   Equipment repairs, Excavator Gum Surgery!-p1010668-jpg   Equipment repairs, Excavator Gum Surgery!-p1010673-jpg   Equipment repairs, Excavator Gum Surgery!-p1010675-jpg
    Equipment repairs, Excavator Gum Surgery!-p1010676-jpg   Equipment repairs, Excavator Gum Surgery!-p1010677-jpg
Similar Threads
  1. Killing sweet gum trees
    By schoolsout in forum Projects
    Last Post: 08-15-2011, 10:20 PM
  2. Removing sweet gum stumps
    By FarmerCharlie in forum Projects
    Last Post: 08-02-2011, 01:03 PM
  3. Sweet Gum trees
    By TonyF in forum Rural Living
    Last Post: 05-23-2011, 12:25 AM
  4. Mackissic TH122 will this grind up sweet gum balls?
    By erniemotley in forum Attachments
    Last Post: 03-17-2008, 10:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
