hkhi
Hoping someone has run into this problem and can share their experience. I'm breaking ground on a 40x56 pole barn in upstate NY. Plan is for 12 foot walls, using 6x6's every 8 feet, and heavy duty attic trusses in the 40 ft direction with no internal supports. We're in the hills, and our ground consists of 18-24 inches of clay/dirt on top of shale. I'm using a MF1440v with a MF backhoe so the first 2 feet isn't bad, but removing a quarter inch of shale with each pass after that isn't going to work to get down 48 inches below our frost line.
If I don't want to pay several thousand dollars to have 20+ holes drilled through the shale for the 6x6's, and I don't want to put in a complete foundation with footing, what are my options? Can I sit the poles on footer blocks directly on the shale and compensate for the poles only being 2 feet in the ground with extra diagonal bracing in between the 6x6's ? Or is sheathing the whole building in osb required to get the same stability as a buried pole?
If it helps, I also have a TSC Countyline auger for my Massey, but I haven't found a rock auger attachment that's compatible.
Thanks,
-H.
Thanks,
-H.
