Page 12 of 54 FirstFirst ... 2910111213141522 ... LastLast
Results 111 to 120 of 531
  1. #111
    Gold Member tkappeler's Avatar
    Join Date
    Jun 2012
    Posts
    358
    Hainesport, NJ
    TYM T293
    Default Re: New Home Begins
    Excavation day today. The basement is only going down between 2'7" on the high side and 1' on the low side due to the water table. This is after the 1' of top soil was removed from the existing grade. The garage footing needs to be raised 15" to top of footing so a few trucks of fill brought in and compacted.
    Not too many pictures but it is progress. Footings will be marked and dug tomorrow. There is an outside chance for the pour to occur on Friday, depending on inspector's availability, but most likely Monday.
    New Home Begins-imag0603.jpg New Home Begins-imag0604.jpg New Home Begins-p1020034.jpg New Home Begins-p1020035.jpg New Home Begins-p1020041.jpg New Home Begins-p1020042.jpg
    Tom
  2. #112
    Super Member dave1949's Avatar
    Join Date
    Apr 2009
    Posts
    5,914
    Industry, Maine
    New Holland TC40
    Good to see progress being made, I'm sure that's a nice feeling.
    What sort of basement walls will you have, precast? How tall is the concrete going to be? How high will the finished grade be around the basement wall? Seems like you have plenty of opportunity for good surface drainage away from the house.
    “It is a great thing to know the season for speech and the season for silence” ― Seneca (4 BC - 65 AD)
  3. #113
    Join Date
    Jun 2012
    Posts
    358
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by dave1949 View Post
    The basement walls are indeed precast. They are 9' tall. Given that due to the higher-than-preferred water table, we can only go down about so far. The soil does drain pretty well as there was no standing water this morning with a full day of rain yesterday. The finished floor will be about 7' above current grade and we will build up the driveway 42" over the 140' driveway.
    Tom
  4. #114
    Super Member Robert_in_NY's Avatar
    Join Date
    Aug 2001
    Posts
    8,212
    Silver Creek, NY
    Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
    May I ask why your building an above ground basement? Since you can't bury the basement down in the ground like a traditional basement then what purpose is there to going with concrete walls 7' high? I would think a standard footer would be more cost effective and just built a two story house without having a large concrete wall or huge stair case to lead up to your "first" floor so to speak.
    God must love stupid people; He made so many
  5. #115
    Join Date
    Jun 2012
    Posts
    358
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by Robert_in_NY View Post
    We do not expect to have huge steps up to the one floor as we will build up the grade over the 140' front yard. It will be pretty gradual. As for the living area, we want to be on one floor. It is not important now but will be as we move beyond our 50s.
    The precast was a better, stronger option although a little more expensive than poured walls. Since energy efficiency codes require insulation on basement walls, the precast saved me a step and time is money.
    The cost of full walls, surprisingly; was not significantly more expensive than doing a crawl space. Plus we plan on using the basement for a home business and hangout space for my daughter and other visiting grown children.
    Tom
  6. #116
    Join Date
    Apr 2009
    Posts
    5,914
    Industry, Maine
    New Holland TC40
    Quote Originally Posted by tkappeler View Post
    That makes sense. Without intending to offend anyone, I think crawlspaces are an idea that should go away - never to be seen or heard from again
    Where you have pre-cast exposed on the lower level interior, that shouldn't be too hard to get a reasonable finish directly on the concrete. I have plastered poured concrete interior walls and that has worked out okay so far, 6 years. But, pre-cast should be a much smoother surface than poured. I did a lot of chipping, grinding and brick block rubbing to prep for the plaster.
    What is the R-value rating for your pre-cast walls?
  7. #117
    Join Date
    Aug 2001
    Posts
    8,212
    Silver Creek, NY
    That makes sense, building the ground up that much will be a fun project but it will help hide the basement walls so as to not look too out of place. I wasn't suggesting a crawl space, just a standard footer and pour the ground floor then stick build from the footer on up. You could still do the same with the ground floor that you planned to do with the "basement" just it would be wood framing instead of the precast concrete walls.
  8. #118
    Join Date
    Jun 2012
    Posts
    358
    Hainesport, NJ
    TYM T293
    The walls have an R-10 rating, which is the current requirement per code. The new codes that will go into effect next year will require more than that. I am not sure if it is R-16 or R-19 for all basement walls.
    Finishing the walls is pretty easy as the ribs have steel faces similar to metal studs. Thus, you can put additional insulation to the cavities and then simply screw the drywall up to the exposed ends of the precast ribs.
    Tom
  9. #119
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,911
    W Wisc
    Kubota L3130
    I see you are using Superior Walls. I knew a builder that used those a bit around here. The crews struggled a lot with getting everything level enough to be satisfactory. I would double check that the top of wall is flat and fully level before cutting them loose. You will need to drywall over the exposed foam too as it is not fire rated, but it sounds like you plane to finish the space anyways.
    Nice to see progress!
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  10. #120
    Join Date
    Apr 2009
    Posts
    5,914
    Industry, Maine
    New Holland TC40
    That sounds good with the metal studs and all. I haven't seen homes done with pre-cast walls and wondered how the interior finishing works. In my climate, I would add insulation between the studs most likely.
    What do you have planned for exposed exterior portion of the basement walls?
Similar Threads
  1. So it begins with my '91 318
    By notmyj in forum John Deere Lawn & Garden
    Last Post: 01-31-2012, 09:59 AM
  2. Dirt Moving Kubzilla 2, And so it begins...
    By KubZilla in forum Kubota Owning/Operating
    Last Post: 04-21-2011, 02:26 PM
  3. And So It Begins
    By davemhughes in forum Photos
    Last Post: 03-17-2008, 08:30 AM
  4. The Journey Begins
    By Trebor in forum Power Trac
    Last Post: 05-09-2004, 10:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
