Page 13 of 66 FirstFirst ... 3101112131415162363 ... LastLast
Results 121 to 130 of 653
  1. #121
    Platinum Member tkappeler's Avatar
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Default Re: New Home Begins
    Quote Originally Posted by dave1949 View Post
    That sounds good with the metal studs and all. I haven't seen homes done with pre-cast walls and wondered how the interior finishing works. In my climate, I would add insulation between the studs most likely.
    What do you have planned for exposed exterior portion of the basement walls?
    Nothing initially but it will ultimately get the same stone facade as the fireplace.
    Quote Originally Posted by dstig1 View Post
    I see you are using Superior Walls. I knew a builder that used those a bit around here. The crews struggled a lot with getting everything level enough to be satisfactory. I would double check that the top of wall is flat and fully level before cutting them loose. You will need to drywall over the exposed foam too as it is not fire rated, but it sounds like you plane to finish the space anyways.
    Nice to see progress!
    How long ago was that? I would guess that is more related to the installation crew and not the product. They were used 2 miles up the road this past summer. I will have to contact the builder there and ask about his experience. Thanks for the heads up!!
    Tom
    "Opportunity is missed by most people because it is dressed in overalls and looks like work" - Thomas A. Edison
  2. #122
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,805
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    It was several years back, but the builder was pretty good overall. Around here the way they did Superior walls was to lay a footing of compacted crushed rock, and then set panels on it. No poured footings - always struck me as weird. They said they didn't need it, and I suppose you don't, but it seems like a much better point to start from. They would lock the walls in with the slab, and backfill on the outside. The big complaint was the difficulty in getting all the walls tied together and level/even....so I was told... The results seemed good once they got past that.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  3. #123
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Without a footer, I guess the theory must be if the walls are locked to the slab, and the slab can't sink, the walls can't either?
    Footers for poured or laid walls can be a bit sloppier I suppose than for pre-cast, but I'm with you, I think I would want the footer even if it means they have to take a little more time forming the footer.
  4. #124
    Join Date
    Apr 2010
    Posts
    2,805
    W Wisc
    Well it has a footing - it's just a crushed/compacted stone one instead of poured concrete. After all, a concrete wall sits on the ground at some point, one way or the other... It worked and met bearing load requirements but seemed the hard way to do it to me. But then it didn't require forms or a concrete pour, so I'm guessing that was the draw to the method
    -Dave
  5. #125
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    I thought the lack of a "true" footer might be why they had trouble getting the walls even/level? Do the pre-cast sections have a flared-out section at the bottom that acts like a footer for distributing weight?
  6. #126
    Join Date
    Apr 2010
    Posts
    2,805
    W Wisc
    These didn't. They looked like plain vertical panels with "studs" cast into the interior side as part of the structure. Like this:
    Interactive R-5 Wall Detail
    In fact, you will note in the detail it shows it on crushed rock...
    -Dave
  7. #127
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    As the OP, and having done a lot of research before committing to the Superior Walls, I can add what I learned. I too was skeptical about a crushed stone footing. What I learned is that the weight is distributed outward at an approximate 45 degree angle from the direct point load of the wall. This means that a 10" thick wall section will bear on a 18" base for a 4" thick base (4" exterior + 10" wall + 4" interior). An 8" thick crushed stone footing will distribute the weight over 8 + 10 + 8 = 26" wide. Superior provides charts for the thickness of the stone base based on expected loads.
    The stone used is 3/8" clean crushed stone and is mechanically compacted (twice in one direction and twice in the opposite direction) to lock in the stone. Adjustments are made to reset the proper elevation after compaction.
    The walls are then directly placed on the stone, bolted together, checked for plumb and level, repeat.
    One claimed benefit of this process is that there is less hydrostatic pressure against the wall from ground water as the water can naturally flow through the footing and be picked up by your french drain.
    The reasons I am using a poured footing instead of the stone (at least for the house itself, the garage will use the stone method) are two-fold: 1) The soil composition and it's load bearing ability, given the higher water table, was unknown during the design phase and the architect was not comfortable with the unknown and the ability of the gravel to NOT sink down further and 2) if there is a failure due to settling of the gravel, then the result can be water infiltration into the house.
    One downside of the footing is that I now will have a french drain on the outside, carry the water through the footing to the interior only to pump it outside again.
    Tom
  8. #128
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    There is a "bond beam" on the horizontal (top and bottom) edges so that the loads are carried on a flat surface bottom and a solid sill plate surface topside.
    Tom
  9. #129
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Thanks for the link. For sure, those would be lighter than poured or laid block. That would reduce the need for a footer in decent bearing soils it seems. It just doesn't seem right.
    Back about 1987 a friend of mine had a ranch house built using crushed rock footer, then full basement walls made of 2x10 studded wall with a top and bottom plate, sheathed in plywood on the exterior side--all pressure treated. He got divorced, so I lost track of how well that worked out over time.
  10. #130
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Here is a cross section (in blue) of a superior wall. You can see the top and bottom bond beams as well as the ribs that make the effective weight bearing surface the full 10 1/4". I shaded the ribs in the silver color.
    New Home Begins-superior-walls-cross-section-png
    Tom
Similar Threads
  1. So it begins with my '91 318
    By notmyj in forum John Deere Lawn & Garden
    Last Post: 01-31-2012, 10:59 AM
  2. Dirt Moving Kubzilla 2, And so it begins...
    By KubZilla in forum Kubota Owning/Operating
    Last Post: 04-21-2011, 03:26 PM
  3. And So It Begins
    By davemhughes in forum Photos
    Last Post: 03-17-2008, 09:30 AM
  4. The Journey Begins
    By Trebor in forum Power Trac
    Last Post: 05-09-2004, 11:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
