dave1949
Super Star Member
Oh yes, my fiance is already drooling over the prospects of a blank canvas for gardens, especially a pond
Well, there you go. It would be useful to draw out a side profile type of thing that lets you map out the amount of fall/slope you have to work with from the lowest foundation french drain level to the stream bed. Figure on about 3/8" fall per foot of run in your pipes. I think that is a reasonable fall rate, others can chime in.
In any case, that will show how deep your pipes would be at a given distance from the house, which should help find the pond location if you want to try for a daylight gravity drain into the pond. A gravity drain to daylight is worth quite a bit in the scheme of things.
