Page 38 of 66 FirstFirst ... 283536373839404148 ... LastLast
Results 371 to 380 of 653
  1. #371
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Default Re: New Home Begins
    Quote Originally Posted by tkappeler View Post
    The 6x12 rafters are 48" on center. The panels do run horizontal, spanning them and staggered to provide the structural support. Purlins will run vertically perpendicular to the panels.
    Thanks, I can picture it now. Are you getting much snow from the storm, or is it mostly off to your northeast?
  2. #372
    Platinum Member tkappeler's Avatar
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by dave1949 View Post
    We lucked out. The rain was not as hard or much as the weather heads were scaring everyone into. The winds were less too. We only got less than 3" of snow. I have not been to the property yet, and will be heading over there shortly.
    Tom
    "Opportunity is missed by most people because it is dressed in overalls and looks like work" - Thomas A. Edison
  3. #373
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Beautiful morning at the property. Snowfall not too bad. Got some seat time in moving the trash lumber from the garage so we can begin backfilling there this week.
    New Home Begins-p1020748-jpg New Home Begins-p1020756-jpg New Home Begins-p1020757-jpg New Home Begins-p1020758-jpg New Home Begins-p1020759-jpg New Home Begins-p1020761-jpg New Home Begins-p1020762-jpg
    Tom
  4. #374
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    I love the look of the T&G ceiling.
    Obed
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  5. #375
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Rain and snow on Friday and Monday, so no progress until today. The rafter to ridge plates are all in and more than half of the collar tie plates are done. The rafter plates were a real pain since all four plates are through bolted to each other and the rafters are rough cut, so they are slightly different sizes so the alignment is really touchy.
    When they finished the plates, they completed the T&G and started on the Raycore roof panels. In the first pictures below, you can see the panels on edge over the T&G (the gap, over the rafter. Other pictures show the 4 mil poly over the T&G and the panels over that. Nine 9" timberlok's go through each panel (3 per embedded stud), through the T&G and into the rafter.
    Tomorrow, they will finish the panels and then the tarp goes on again as ... you guessed it ... more rain and snow tomorrow night.
    New Home Begins-p1020764-jpg New Home Begins-p1020763-jpg
    New Home Begins-p1020765-jpg New Home Begins-p1020770-jpg New Home Begins-p1020774-jpg New Home Begins-p1020776-jpg New Home Begins-p1020778-jpg New Home Begins-p1020780-jpg
    This one shows the studs embedded in the panels.
    New Home Begins-p1020785-jpg
    Tom
  6. #376
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,844
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Interesting. Will there be a layer of foam over the top of that? Otherwise those studs in the roof panels will be a major thermal bridge. I will be very curious to see how this system works.
    I love the looks of the inside! That is really nice!
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  7. #377
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by dstig1 View Post
    No, there won't be another layer of foam. Yes, i understand the thermal bridging, but it is still far better than a typical attic with stapled up R30 or insufficient or matted down blown in insulation.
    Tom
  8. #378
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Tom, your use of beams and tongue and groove look very familiar to me. I also used foam panels on my roof, but they were not Raycore. For my roof over the T&G, they put OSB sheathing, then traditional felt before laying in the foam. The foam was covered with another layer of OSB and then another felt layer before putting steel roofing U-panels over that. I have had no problems with moisture, condensation, or leaks on my roof. The insulating factor of the foam over T&G seems very good. Attached is a photo of my great room.
    Attached Thumbnails Attached Thumbnails New Home Begins-inside3-jpg
    Jim
  9. #379
    Veteran Member srs's Avatar
    Join Date
    Feb 2004
    Posts
    1,073
    Jarrettsville Maryland
    Kubota B3030 HSDC
    [QUOTE=tkappeler;3189461]
    When they finished the plates, they completed the T&G and started on the Raycore roof panels. [/ATTACH]
    tkappeler, will the installers use any type of spray foam (such as Great Stuff) between the Raycore panels to fill in any gaps, if needed?
    Stanley----Kubota B3030 HSDC
  10. #380
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by jinman View Post
    That looks great!! I wish I could have done a standing seam metal roof but it was just too expensive. About 40% more not counting the lumber for the purlins.
    Tom
Similar Threads
  1. So it begins with my '91 318
    By notmyj in forum John Deere Lawn & Garden
    Last Post: 01-31-2012, 09:59 AM
  2. Dirt Moving Kubzilla 2, And so it begins...
    By KubZilla in forum Kubota Owning/Operating
    Last Post: 04-21-2011, 02:26 PM
  3. And So It Begins
    By davemhughes in forum Photos
    Last Post: 03-17-2008, 08:30 AM
  4. The Journey Begins
    By Trebor in forum Power Trac
    Last Post: 05-09-2004, 10:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
