Page 53 of 66 FirstFirst ... 3435051525354555663 ... LastLast
Results 521 to 530 of 653
  1. #521
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Default Re: New Home Begins
    Quote Originally Posted by tkappeler View Post
    Those look to be some manly sized elbows for a residence. Where are they going to be used?
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  2. #522
    Platinum Member tkappeler's Avatar
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by mjncad View Post
    These returns come up in a closet and then split into two places. One is in the great room over the closet and the other leads to the hallway and the elbows are for that branch. Because there are only two returns and it the total CFM is 1300, some big ductwork is needed.
    Tom
    "Opportunity is missed by most people because it is dressed in overalls and looks like work" - Thomas A. Edison
  3. #523
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Dodged a bullet this week. Several bullets actually. We called for the HVAC inspection and the person that does that one also does the framing inspection, so he started the framing in the basement at the same time.
    The good news was that other than needing a little more air sealing muck at three places, the HVAC passed.
    The bad news was with the iJoists in the basement. He was reviewing the sealed engineering plan for the joists vs the actual installation and noticed that one was missing. The joists are 16" on center under the bedrooms and kitchen and larger ones 12" on center under the great room. This was all correct and to plan. In one place under a bedroom, there are two additional ones providing support under a NON-load bearing wall. The framers missed one of the 16" on center joists. Luckily the one under the wall makes the spacing to be 18" on center, not 16". As a result, he needed me to get in touch with the engineering company to see what kind of +/- on spacing is allowable. They came back and provided documentation that every third iJoist can be shifted up to 3" to allow for plumbing or other obstacles.
    New Home Begins-missing-joist-jpg
    That letter allowed me to dodge that bullet.
    The next was related to the blocking that is required between the superior walls and the iJoists that run parallel to the basement walls. The drawing for the basement had different blocking schedule as compared to the engineering drawings for the iJoists alone. The superior drawing showed an additional 2x6 to be nailed under the normal blocking.
    New Home Begins-no-strongback-ijoists-jpg
    This would have meant adding 27 additional 2x6 bracing, including some that would have to go above the ductwork that was just put in.
    I contacted Superior walls and asked about the bracing. He said that the additional bracing is only required if the joists were ordinary dimensional lumber, not iJoists. He provided me with the page/drawing in their guide book that indicates this. I forwarded this information to the inspector and he accepted it provided he gets a letter stating same from Superior, identifying our project specifically.
    I received that letter yesterday and it was provided to the inspector. Second bullet dodged.
    Whew!
    Tom
  4. #524
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    You got lucky there Tom as it sounds like the inspector was reasonable to work with. Now an inspector that does framing and HVAC is an odd mix to me.
  5. #525
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    The floor joist engineer ran the load calculations with the missing joist and all is good. They redrew the plan showing 3, not 4 and it was sealed and turned into the inspector. He came out and inspected the main floor the other day. He wanted additional 2x6' to pick up the heels of the rafters comprising the crickets and he also wanted the top plate penetrations in the garage fireblocked. We did not do them because the garage was unfinished anyway. He indicated that they want the blocking in now as we can slap up drywall anytime without a permit and this way they are assured it is done.
    I won't even ask the obvious question of how would they know if I drill any new holes and don't fireblock right before slapping up drywall.
    He is coming back Monday morning to check on these few items. We should get a clean framing approval then.
    All in all, the inspector said it was a job well done, as good as professional builders, so I feel pretty good.
    We got the stone in the garage and will be drilling two 4' deep holes in the center of the garage to act as piers when filled with concrete during the pour. Hopefully that will be this week.
    I have requested the insulation be done asap. Fireplace goes in on 5/30 unless there is a cancellation or other change in schedule and then it will be done earlier. We are waiting to hear when the drywall can be done (maybe do all of the house except for the fireplace wall to get a head start on it. Kitchen cabinets are being delivered next Friday.
    Tom
  6. #526
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Well, I got all of the items on the list done and the gas line holding the required 10#. As of today, the framing inspection has been approved as has the gas line. I was reviewing the blueprints over the weekend and I noticed that the Simpson MTS30 twist straps connecting the rafters to the walls had the required (14) 10d 3" fasteners on the wall side and the required (14) 10d 1.5" on the rafter side per Simpson's specs. Unfortunately, the architect specified that every hole have a nail. So, yesterday, I was pounding in 21 more nails per strap. Can someone please tell me what difference having 35 nails in the strap at the top of the wall when the wall is secured to the floor with maybe 35 fasteners for the entire wall length?
    On to insulation this week (hopefully) and drywall starts next week. The fireplace gets installed a week from Friday, which will overlap with the drywall.
    We also go the stone spread in the garage and dug two post holes to act as a concrete pier in the middle of the floor. We hope that gets done this week as well.
    New Home Begins-mts30c-gif
    Tom
  7. #527
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    We also got the stone spread in the garage and dug two post holes to act as a concrete pier in the middle of the floor. We hope that gets done this week as well.
    Tom
  8. #528
    Gold Member Ranger Rick's Avatar
    Join Date
    Aug 2007
    Posts
    316
    Louisa, VA East of Charlottesville
    Kubota L3940
    I can sympathize with you but it is better for you to find you need those nail now rather then the building inspector saying you need them. I misinterpreted the repair on the trusses on my pole barn that required two rows on nails in each side of the plywood gusset. I put one row in each two by four and the inspector says that it was supposed to be two rows into each member. So now that the trusses are up I have to get at the end of each truss and add another 50 nails. It should be fun.
    Your house is coming along nicely. Rick
  9. #529
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by Ranger Rick View Post
    sounds like you need one of these. The framers used this and I wish I had bought one. $40.
    New Home Begins-grip-rite-palm-nailer-jpg.
    Tom
  10. #530
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    We now have the following things all being done next week:
    Cabinets delivered - this friday
    Insulation - tuesday
    Load drywall - wednesday
    Begin drywall - thursday - three days to hang it.
    fireplace install - friday
    garage floor and porch somewhere in that week also. What a great time to start working at a new client ... on site ... an hour away. Of course, it's only a one week stint and can work from home again to be around.
    We could be painting by 6/7!!
    Tom
Similar Threads
  1. So it begins with my '91 318
    By notmyj in forum John Deere Lawn & Garden
    Last Post: 01-31-2012, 09:59 AM
  2. Dirt Moving Kubzilla 2, And so it begins...
    By KubZilla in forum Kubota Owning/Operating
    Last Post: 04-21-2011, 02:26 PM
  3. And So It Begins
    By davemhughes in forum Photos
    Last Post: 03-17-2008, 08:30 AM
  4. The Journey Begins
    By Trebor in forum Power Trac
    Last Post: 05-09-2004, 10:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
