Page 6 of 66 FirstFirst ... 34567891656 ... LastLast
Results 51 to 60 of 653
  1. #51
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,841
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Default Re: New Home Begins
    Dig a hole down to well below grade where the soil tends to drain better. Line with filter fabric and fill with clean rocks in the 1-2-3" range (no fines). Fill up to the grade and cap it. You want to keep fines out so it doesn't plug up over time. Then you pipe drainage water into it (usually with the pipes buried and terminating in the pit higher up towards the surface) and it drains away below. It is a simple solution for handling runoff water that works well when you have no slope to send the water away, or cannot do so due to some rule or other condition.
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  2. #52
    Platinum Member tkappeler's Avatar
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Quote Originally Posted by dstig1 View Post
    Interesting. How well would that work if the water table is only 4' down? that is why we are only digging down that far and putting the basement up out of the ground.
    Tom
    "Opportunity is missed by most people because it is dressed in overalls and looks like work" - Thomas A. Edison
  3. #53
    Join Date
    Aug 2012
    Posts
    985
    Hartford, SD
    Kubota L3400F
    Quote Originally Posted by tkappeler View Post
    That is a good plan because you will never win a battle against groundwater. Sump pumps may keep it at bay but someday they will fail and your basement will be flooded. I am 100% certain of this outcome.
  4. #54
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    With an 1800 square foot basement, I have planning on two sumps in opposite corners, separate circuits, generator backup on both
    Tom
  5. #55
    Join Date
    Apr 2010
    Posts
    2,841
    W Wisc
    Ah well a high water table shoots that plan. Looks like you are out of other options and just need to bring it into the sumps and pump it out as originally discussed.
    What is your contingency if you strike water before you get down 4' for the foundation? You should bounce that one off the excavator/contractor as it is a real possibility. There are other options for shallow frost protected footings that can work with much less digging:
    Tomorrow
    This is for our area, but you should be able to find similar.
    -Dave
  6. #56
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    Tomorrow
    The perk tests included digging two test holes down 11' per county monitored procedures. This was done in spring which traditionally has the highest water level. The septic guy expected it to be in the 2' range, so almost 4' was great.
    As for contingency plans, the existing house is on a crawl space and is in OK shape as far as water is concerned and it's been vacant for at least 12 years. One new home a few doors down built completely on existing grade and brought in 6' of fill around the basement walls to completely raise it out of the ground. I really do not want to go that route if possible as the water runoff issues become significant with what would be a 6' drop in only 30' to the sides.
    Tom
  7. #57
    Elite Member Obed's Avatar
    Join Date
    Dec 2006
    Posts
    2,649
    East TN
    John Deere 4210 FEL BH
    With only a 4' deep water table, I'm a little surprised you are building a basement. You are going to have to walk up a lot of steps every time you enter the house just to get to the kitchen. Unloading a car full of groceries means a lot of trips up the stairs. Of course, to each his own. I see lots of houses with steps to the main floor, but normally in hilly terrains. I rarely see that in flat areas unless the area is in a flood zone.
    John Deere 4210 (28 HP) FEL, BH, 6' Box Blade, Loader Forks
    At Home In the Woods
  8. #58
    Join Date
    Jun 2012
    Posts
    628
    Hainesport, NJ
    TYM T293
    It's been awhile with little progress as the permit process in NJ is arduous.
    sealed Blueprints (12 pages) - check
    sealed truss shop drawings - check
    TJI IJoist subfloor plan - check
    sealed surveys - check
    building application - check
    electrical application - check
    plumbing application - check
    cut sheets for heater and A/C - check
    cut sheets for fireplace - check
    cut sheets for wall systems - check
    mechanical plan - check
    plumbing Plan - check
    electrical plan - check
    sealed proposed foundation survey - check
    well approval from state and county - check
    signed applications by all foundation, basement wall system and framing subs - check
    septic plan approved by county - IN PROCESS
    architect's review of truss and floor system - IN PROCESS
    If all goes well, the last two items will be this week.
    [edit] I am so grateful that the township accepts email and I can forward all non-sealed items to them and they print to the permit package. This saved a lot of driving to the township. [edit]
    In addition, the demo of the old house, which we were originally going to have done in spring, is now scheduled for this Monday, 11/12 as the demo company feels the old home is too close to the new footprint and they want to be able to navigate all around. So the basement walls are now pushed back to 11/29.
    Next photos will be the demo of the old house next week. Finally!!
    Tom
  9. #59
    Join Date
    Aug 2012
    Posts
    985
    Hartford, SD
    Kubota L3400F
    "architect's review of truss and floor system"
    Thanks for the laugh...that is precious!
  10. #60
    Platinum Member ENG18LT's Avatar
    Join Date
    Jan 2012
    Posts
    616
    Syracuse and Warsaw, NY
    Mahindra 5530 4wd
    Quote Originally Posted by sdkubota View Post
    I too had a laugh on that one too. Some architects are...well, full of themselves.
    Lee
    Long road home
    Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
Similar Threads
  1. So it begins with my '91 318
    By notmyj in forum John Deere Lawn & Garden
    Last Post: 01-31-2012, 09:59 AM
  2. Dirt Moving Kubzilla 2, And so it begins...
    By KubZilla in forum Kubota Owning/Operating
    Last Post: 04-21-2011, 02:26 PM
  3. And So It Begins
    By davemhughes in forum Photos
    Last Post: 03-17-2008, 08:30 AM
  4. The Journey Begins
    By Trebor in forum Power Trac
    Last Post: 05-09-2004, 10:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
