hunterridgefarm
- Joined
- Jul 12, 2005
- Messages
- 2,132
- Location
- Western NC
- Tractor
- Kubota L3130DT, Kubota L185DT, JD LX277
Make sure that your FEL can safely lift the trusses into position after building them. Once built, they will be heavy and moving them around will be problematic by yourself. Doing it alone, I do not think a ridgeboard will work in your case. You would have to frame up some temporary supports just to hold the ridgeboard while you build the trusses in place and getting it level over that distance will be a problem. If you pre-frame the trusses, get the first one stood up and level and put up some temporary supports to keep it that way. Then space out the next one and add a temporary bridge to the first truss with a 2x4 while nailing it down. Keep adding trusses and 2x4's to keep the trusses upright and spaced properly at the top. One method I use is to take an 8 foot 2x4, and add to one end a 21 inch 2x4 piece, leaving 3 inches of the 8 footer exposed. With this tacked in place to the proceeding truss, it allows you to get the 24 inch spacing without a lot of effort, important since you are working alone. I then add a standard 2x4 to hold it there and move my spacing 2x4 to the next truss. A cordless screw gun works great for this. Remove the temporary bridges as you add roof sheets.
Ridge board and rafters - no question. Having gone both ways with small garages, I think the ridge board and stick build would be easier when working alone than trusses. All you need to do is erect a temporary vertical post on each end to locate the ridge board and then you only have to handle one rafter at a time. Even a 16 foot truss will do great damage if it slips and flips on you.
Since you are going to have attic storage. You can build the "floor" and lay most of the flooring before you put up the rafters. Working from that raised platform makes stick building the roof almost fun. I've done it this way before with a full hip roof and it makes it an easy one man job. I would suggest you go to at least 2x8 for the floor joists. I would also put both the rafters and joists on 16 inch centers. That allows you to use the nominal 1/2 inch sheathing and will give you a lot more support. I did a garage overhead storage with 2x6, 16 inch centers on a 12 foot span and it was OK but marginal. Seemed to me like it was a little bouncy. When you get done, you will never remember the few extra dollars you spent on framing lumber.
The best way to get overhead storage would be ridge board with rafters. What's your reason for using trusses instead?
I agree with this.
Why over complicate this with trusses? Its a small building. just buy 7 2x12's and lay them across the top of your walls, then set your ridge board and cut your rafters. Seems like a cheap and easy way to get it done.
Eddie
You can go smaller, but at 16 feet, you will have some sag. I wouldn't go with 2x6's. They will sag over that span from just their own weight. 2x8s might too. Should be fine with 2x10's, but if you price the difference for 7 2x10s compared to 7 2x12s, I don't think it's enough money to be a big deal.
Eddie
