Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default Re: Storage Shed Restoration
    Quote Originally Posted by cj7 View Post
    Nice!!! Two tractors and a JEEP!!!!
    The Jeep is a customers. It's a 1953 CJ3A. It had a Koenig Ironworks top on it but they wanted it taken off. I did a bunch of work to it, it had been sitting for years. They are going to drive it on their farm.
  2. #12
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I haven't updated in a while cause nothing exciting had really happened. Here are some pictures of what I have been up to.
    Here is a lilac bush that was in the way that I had to move.
    Here is the spot of where the building will be after I moved the lilac bush.
    I cut a bunch of trees out of there. There were 4 trees that were all grown in to one and they were all dead. I think I have cut about a cord and half out of there, I need more skids to stack it on to really tell. Here I am moving brush.
    Here is the spot all cleaned a graded up. I am going to have to rent a stump grinder in the spring, by then I will have more stumps to grind. I like to get my monies worth
    I have already started moving the building but I ran out of daylight. It is a little time consuming to move because it was not a strait push, so I had to carefully turn it with the tractor. Hopefully Monday I will get it to its final resting place. Then I will have to level the building. After that the new siding can be put on and the new door.
  3. #13
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    I got the building moved into place. I used the L4240 to lift it upon the blocks. I have it sitting level. I have blocks sitting under each corner. I want to go back and add some blocks in the middle for extra support. I started putting some siding on it. All I have is just the one side.
  4. #14
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,688
    East TN
    Kub - 2K6, B7800
    Thanks for the pictures
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  5. #15
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by crbr
    No problem I will add more soon hopefully.
  6. #16
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Here are some more pictures. The door is just on there temporally, it still needs to be trimmed out on I am going to put 4 hinges on it. The front of the building of still needs the vent put in the top, it should have been done before the siding was put on. The corners of the building need trimmed out also. I still need to go back and add more cinder block supports underneath of it. I decide to go with one big door this time instead of 2 small ones.
  7. #17
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I finally got a chance to work on it Saturday. I got the door trimmed out and the hinges on it and the vent in the front.
    I was going to use a hasp on the door but I changed my mind. I need to order a latch for it. I still need to add more block under it for support and build a ramp into it. I guess I will put lattice panel or something like that around the bottom. I also need to paint it.
Similar Threads
  1. Storage Shed Move
    By mlauk in forum Trailers & Transportation
    Last Post: 01-19-2010, 04:55 PM
  2. Storage shed ideas got any?
    By deereboy72 in forum John Deere Owning/Operating
    Last Post: 04-18-2009, 09:39 PM
  3. Need storage shed plans.
    By shaley in forum Projects
    Last Post: 07-20-2005, 01:36 PM
  4. Suggestions for storage shed
    By Deliberate1 in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2003, 02:06 PM
  5. Tractor Storage Shed
    By gusg in forum Projects
    Last Post: 07-08-2002, 10:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
