Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Veteran Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    1,217
    Virginia USA
    Kubota B2920
    Default Re: French Drain - River Rock or Crushed Stone
    We use #57 gravel here, which is 3/4-1" size. We also line/wrap the trench with septic fabric to prevent the soil/clay from infiltrating into the stone. So the steps are:
    1) dig trench
    2) line with septic fabric
    3) drop in about 2-3" of stone
    4) place pipe with perforations on the bottom
    5) cover with more stone up to about 6" below grade
    6) fold over septic paper and roll the seam
    7) cover with top soil to grade
  2. #22
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,805
    NOT HERE
    Default
    I have heard of some people having french drains without the corrugated pipe.
  3. #23
    Join Date
    Dec 2011
    Posts
    1,217
    Virginia USA
    Kubota B2920
    Quote Originally Posted by 94BULLITT View Post
    Definitely. In fact, if the drain runs down a change in elevation in clay soil, you can skip pipe on the upper parts and only use it on the lower half.
    Or if the base soil is sandy and drains well, the french drain can be all stone since it will just direct surface water down to the sand layer, and doesn't necessarily need to move it laterally.
  4. #24
    Join Date
    Oct 2004
    Posts
    202
    Ohio
    Ferguson TO 20, Kubota B3300 TLB
    This was part of a large drain project I did which might show what some others on have described. This was a high end job and worked out very well to protect this really long asphalt drive from future washout. The pipe is 4 inch smooth bore (about 220 feet installed in this part) which is semi flexible and also used schedule 40 to the catch basin, under the concrete trench drains across asphalt drive and across concrete pad up top of the one photo. About one foot of #2 limestone was used on top of the four inch wrap. #57 limestone was used inside the wrap.
    Attached Thumbnails Attached Thumbnails French Drain - River Rock or Crushed Stone-drain-wrap.jpg   French Drain - River Rock or Crushed Stone-completed-drive-w-lower-pour.jpg
  5. #25
    Platinum Member Red Horse's Avatar
    Join Date
    Dec 2010
    Posts
    553
    Bolton, MA
    Deere 655ZTrak, Deere 4720 Cab, 400 X
    Quote Originally Posted by Tompet View Post
    Nice-and it looks like that the drain system you used across the road was one of the precast polymer types? what brand?
  6. #26
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,805
    NOT HERE
    That looks very nice. I need one of those trench drains but I am not sure how to do it with a gravel driveway, I am afraid the plow will hit it in the winter.
  7. #27
    Elite Member
    Join Date
    Sep 2003
    Posts
    3,945
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455
    We've got some with crush some with river rock. For us the river rock was about 1/5 the price of crush when its available. Both work equally well. The river rock is slightly easier to shovel but the tractor scooped both equally well.
  8. #28
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,059
    nicholson, pa
    John Deer Lt160
    The gutters around our house ended about 2' before the ground when we moved in. I extended the gutters, and put in solid pipe from the end of the gutter until the pipe was sloping away from the house.
    (all 4''). Then I put in 2-3'' of stone and compacted it, then put the pipe in covered and compacted, and then added 2'' more of stone and compacted. covered and it has worked great. It carried water away from the house during the last few 100 year storm events we have had.
Similar Threads
  1. Replies: 0
    Last Post: 05-31-2012, 12:29 PM
  2. Crushed stone prices- way up!
    By Skyco in forum Projects
    Last Post: 05-01-2011, 11:45 AM
  3. Moving crushed stone ???
    By Madman_Mark in forum Owning/Operating
    Last Post: 04-27-2004, 06:42 AM
  4. Driveway Base: is 12" Crushed Stone Overkill?
    By keeney in forum Projects
    Last Post: 04-23-2004, 02:51 PM
  5. Cost of crushed stone driveways?
    By MDL in forum Related Topics
    Last Post: 08-26-2002, 08:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
