Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 72
  1. #21
    Gold Member
    Join Date
    Jun 2012
    Posts
    421
    Sno WA
    JD 950
    Default Re: I Beam for structural support
    Quote Originally Posted by LD1 View Post
    And based on THAT, you would need a w16x40 to get the stress and deflection down to an acceptable level
    That's kind of what i thought he would end up at, something at least 36#/ft. And it will need a number of web-stiffeners, and the connections should be given careful consideration.
    The roof load is what kills. If you could find a way to convert them to trusses as someone else mentioned....it would take a MUCH smaller beam to 30' clearspan for only using a 1-ton hoist. You could actually drop that down to a w10x15 beam for the hoist.
    I don't know the answer here, but an engineer may want to upsize the trolley beam even more to account for movement of the trolley, any extra safety margins due to the fact the entire assembly is now an overhead-lifting device and deflection primarily normal to the beam in a horizontal plane.
    But none of this is meant to argue with you LD, you clearly show the ability to understand the issue(s) and come up with a fine first-order quantitative answer. It is meant to show that someone with a understanding of the standards is needed here. A 30' clearspan is huge. I used to build POS Butler buildings for a POS steel-erector, and some of the building steel we needed to put in to header-off normal rather modest building elements could shock you.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    LD1
    LD1 is online now
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,669
    Central Ohio
    Kubota l3400
    Supporting the roof is the biggest killer here. Cause there are too many unknowns associated with that. Snow load? What was it designed for? Wind forces? etc. Sizing a beam for a given load on a trolley is easy. But 30' clearspan supporting a good portion of the roof...... cannot be done online with any degree of accuracy.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  4. #23
    Gold Member
    Join Date
    Jun 2012
    Posts
    421
    Sno WA
    JD 950
    I'll accept your answer in full, LD.
    The OP needs to look downward too. He has taken four point loads down to two. Are the existing foundations strong enough? Are they even on foundations? He mentioned that the existing building is a pole barn. They do some weird things with those sometimes, including burying ground contact posts with no concrete foundation
  5. #24
    Elite Member Shield Arc's Avatar
    Join Date
    Jan 2009
    Posts
    2,782
    Figuring the picking points of jelly donuts.
    John Deere, 4200
    In this situation I wouldn't even look at an I-beam / S-shape. They will get very tall before getting any real load capacity! I would look at wide flanges, and rip an S-shape and weld it to the bottom of the wide flange for the trolley to run on. That is what a structural engineer suggested to me for my 24-foot span bridge crane.
    Attached Thumbnails Attached Thumbnails I Beam for structural support-hoists.jpg   I Beam for structural support-truck.jpg   I Beam for structural support-welds.jpg
    Miller Dynasty 300.
    Lincoln V350-Pro w/pulse
    LF-72
    Lincoln SG Spool gun
    Lincoln LN-25.
    Everlast PowerArc 200.
    5 Lincoln SA-200s.
    1800 Ellis saw
    Hypertherm Powermax 1250, CNC table.
    PROFAX Welding Positioner.
    JD2 model 3
  6. #25
    Gold Member
    Join Date
    Jun 2012
    Posts
    421
    Sno WA
    JD 950
    Your shop is close to putting MARCO to shame
  7. #26
    LD1
    LD1 is online now
    Join Date
    Apr 2008
    Posts
    7,669
    Central Ohio
    Kubota l3400
    Does that for real have a SWL of 80 tons??? Cause it dont look anywhere near stout enough. Heck, our 15ton crane at work is massive in comparison. The two beams it rides on (above and not suspended) are 36" depth and span 30'. The hoist itself is on beams at least as big as the one you have labled 80T, AND there are TWO of them AND only spanning 15'.
    Not saying it wouldnt do it, just skeptical is all.
    Ford 5500 Backhoe
    JD 261 3PH mower
    Dolmar 7900
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  8. #27
    Join Date
    Jan 2009
    Posts
    2,782
    John Deere, 4200
    Quote Originally Posted by Rock knocker View Post
    OK, I'll bit, what is MARCO?
    No! Those were two beams in a spreader bar I used to set precast utility vaults on an aircraft carrier pier I worked on.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  9. #28
    LD1
    LD1 is online now
    Join Date
    Apr 2008
    Posts
    7,669
    Central Ohio
    Kubota l3400
    Quote Originally Posted by Shield Arc View Post
    Thats kinda what I figured. Scrap re-used from something else. I just was unsure how to ask (and almost didnt) for fear of starting a pizzing match
    Have you calculated or know what IS a SWL for that?
    Doing what you did makes it a bit harder to figure...with adding a cut section to the bottom.
    Ford 5500 Backhoe
    JD 261 3PH mower
    Dolmar 7900
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  10. #29
    Join Date
    Jan 2009
    Posts
    2,782
    John Deere, 4200
    According to my engineer buddy, center of the span beam which is a W 12x87 is the strongest point of the crane, with a SWL of 2-tons, with a 5 to 1 safety factor. The weakest point is between posts in the center of one of the rails which are S 12x31.8, SWL of 1-ton.
    I designed the crane, but my buddy approved everything but the welding. He said if I couldn't handle that he'd kick my ***.
    Miller Dynasty 300.
    LF-72
    Lincoln LN-25.
    5 Lincoln SA-200s.
    1800 Ellis saw
    JD2 model 3
  11. #30
    LD1
    LD1 is online now
    Join Date
    Apr 2008
    Posts
    7,669
    Central Ohio
    Kubota l3400
    I trust him not to double check everything but that does make sense. That main beam is huge compared to the two carrier beams. He's saying that those are the weakest links, and just looking at it, is probabally right.
    But the welds.......
    Ford 5500 Backhoe
    JD 261 3PH mower
    Dolmar 7900
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
Similar Threads
  1. Box-beam or I-beam question
    By Aussiebushman in forum Build-It Yourself
    Last Post: 11-03-2010, 06:59 PM
  2. Calling all structural engineers
    By wroughtn_harv in forum Related Topics
    Last Post: 06-02-2010, 01:44 PM
  3. Need structural advice for tractor shed.
    By N80 in forum Projects
    Last Post: 06-01-2006, 03:31 PM
  4. Your farm/ranch support you or do you support it?
    By 63DH8 in forum Rural Living
    Last Post: 12-31-2005, 11:18 PM
  5. Log Splitter - I beam or box beam
    By Anonymous Poster in forum Build-It Yourself
    Last Post: 03-03-2003, 10:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
