Results 1 to 9 of 9
  1. #1
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    599
    MICHIGAN
    JOHN DEERE 2320
    Default Tow strap / chain safety / adding protection
    Had one serious close call years ago pulling a car out of an impound yard to take to a bodyshop for repairs helping out a local policeman.
    the car was frozen in the mud and would not start.
    We used my 4x4 to free the car from the frozen mud it had been sitting in.
    he had hooked the strap to the frame and as i pulled slowly forward the hook cut and tore thru the steel frame and hit the back of my pickup 2 inches down from the top of the tailgate.
    we never though the grab hook would pull thru the steel frame.
    some times you cannot get close to the log and must drag it up out of a low spot etc...
    then lift the log off the ground so it will not catch when pulling.
    i have also used a 3" wide keeper tow strap with clevis to grab ahold of logs and when pulling removed 5-6 feet of bark from the log letting the strap and clevis slide off the log that had no limbs.
    i probably should hav cut a notch in the lod for a more solid bite.
    live and learn.
    the few extra minutes to cut a notch for a chain or strap to bit into might save a life.
    i am adding some rear protection to the back of my tractor.
    a solid piece of metal on the bottom of the rops.
    then i was going to frame in a piece of expaned metal, heavy mesh steel or punched sheet steel to mount to the rops.
    tom
    ideas anyone?
    any picturesTow strap / chain safety / adding protection-new-tractor-309.jpgTow strap / chain safety / adding protection-new-tractor-310.jpgTow strap / chain safety / adding protection-new-tractor-311.jpgTow strap / chain safety / adding protection-new-tractor-313.jpg of what you have done?
  2. #2
    bcp
    bcp is online now
    Join Date
    Jul 2009
    Posts
    2,231
    SW WA
    Kubota BX2360
    Default Re: Tow strap / chain safety / adding protection
    Quote Originally Posted by BIG DOOLEY View Post
    Some grab hooks have a nearly sharp wedge shape where it would meet the frame.
    Tow strap / chain safety / adding protection-h5-16_med.jpg
    Others are lots more rounded.
    Tow strap / chain safety / adding protection-152135836_h_a331_clevis_grab_hook_s.jpg
  3. #3
    Join Date
    Jan 2004
    Posts
    195
    Northern California
    TS1610
    I remember a story about hook like those posted by BCP. I use those on a steel chain when pulling with my Tractor. I you use a steel cable or nylon rope if the hook come off it becomes a projectile. The story I remember is someone cutting a tree with use cable with a hook on the end to control the direction the tree was going to fall. It didn't work. The cable broke and the hook hit him in the neck. It almost killed him.
    When I use the nylon tow straps I only use the tow strap. I have had nylon strap break or come loose.
  4. #4
    Gold Member
    Join Date
    Mar 2012
    Posts
    327
    NSW Australia
    Tractors16-600hp Farm & Earthmoving Equip, Trucks etc.
    Quote Originally Posted by bcp View Post
    Click image for larger version.
    A grab hook is designed solely for the purpose of linking back onto the pulling or lifting chain, attaching a grab hook directly to any item you're wishing to retrieve is tempting undesirable outcomes......
  5. #5
    Join Date
    Sep 2012
    Posts
    171
    Ottawa Ontario
    Kubota B3300SU
    Chain pulling thru the frame of the car is not a surprise, especially if it was a unibody car. Watch any reputable tow truck operator, they always hook AROUND something: frame, suspension arm, axle etc.
    As far as pulling the logs using a chain or logging cable is way better than using a nylon strap -- straps are not designed for this use. The width of the strap will significantly reduce the friction applied to the log (in psi) allowing the slip. If using a chain you need to use a slide hook at the log end to allow the chain to tighten against the log. If using cable, you need a proper logging clip (not sure the proper name) not a hook on the end as a hook directly on the cable is asking for the cable to break.
    Cutting a notch in the log is a bandaid solution for not using the proper equipment.
  6. #6
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    614
    Gainesville, Fl area Gator Country
    New Holland TC40D HST 4WD FEL/BH
    I like the way you have the radio installed.
    Mahindra 4525 2WD
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
  7. #7
    Join Date
    Oct 2010
    Posts
    151
    Santa Cruz, Ca
    BCS735/720 Ford1200
    With a cable you want to use "choker" as from Wire Rope Cat Chokers for Logging Rigging from WRS, Cat Chokers feature a nub on one end with an eye on the other and a micro-midget choker hook in the middle.
  8. #8
    Join Date
    Sep 2012
    Posts
    171
    Ottawa Ontario
    Kubota B3300SU
    Quote Originally Posted by beeforty View Post
    That's exactly what I was referring to for cable. Thanks, now I know where to find it if I ever need one.
  9. #9
    BHD
    BHD is online now
    Join Date
    Feb 2007
    Posts
    673
    make sure what you have the line secured to is proper as well,
    The tractor dealer in our small town had two employees moving a tractor or trying to pull start it, (do not remember exactly what they were doing), but in the process of pulling it or towing it, a bolt that they had the tow rope fastened to the towed tractor, gave way and the tow rope propelled the bolt through the back of the cab, in one eye of the tractor driver and the bolt lodged behind the other eye, He did survive the accident, but not his eye sight.
Similar Threads
  1. How do you chain/strap down your BX tractors
    By Builder in forum Kubota Owning/Operating
    Last Post: 08-20-2011, 07:21 AM
  2. chain and strap storage?
    By HiTechTed in forum Customization
    Last Post: 03-20-2011, 09:30 PM
  3. tow rope, recovery strap or chain?
    By tractorman1234 in forum Rural Living
    Last Post: 01-13-2009, 12:46 PM
  4. Tow Strap Cinch Bone
    By Diamondpilot in forum Trailers & Transportation
    Last Post: 12-15-2008, 01:34 PM
  5. tow strap or chain?
    By sendero in forum Owning/Operating
    Last Post: 07-26-2003, 06:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
