Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
  1. #11
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    614
    Gainesville, Fl area Gator Country
    New Holland TC40D HST 4WD FEL/BH
    Default Re: Board Fence Build - pictures and a question
    Using a standard circular saw should be able to make a true cut by using a speed square to guide the saw plate. Since you drove the posts to nearly the finished height it is not like you are going to have a large heavy piece of wood falling after the cut.
    While it is true a standard saw will not cut all the way in one pass, it should cut deep enough that the remaining depth could be finished off with the reciprocating saw without making such a "large mess".
    With the tools I already have, this is the way I would do what you need done.
    Mahindra 4525 2WD
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
  2. #12
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    3,170
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    I do them with a chainsaw, but I realize that is not for everybody since it's real easy to make a mistake.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  3. #13
    Join Date
    Jul 2005
    Posts
    1,259
    Southwest VA
    if you've got a worm drive saw you can buy an attachment that looks like a chain saw and allows for deep accurate cuts. look at prazi beam cutters.
    looks like they have them for top handle saws as well.
  4. #14
    Veteran Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    1,644
    SW VA
    David Brown 885, Kubota RTV 900, Kubota 9540
    Default
    Thank you all for your replies.
    I called around yesterday morning to try and rent a big circular saw. Apparently you can't do that. I went to buy one, nobody had one.
    After much consideration, encouragement from one of the guys helping and a trial run on a scrap block of wood I've decided that a chain saw isn't as bad of and idea as once believed.
    Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
  5. #15
    Platinum Member CBW1999's Avatar
    Join Date
    May 2008
    Posts
    856
    Northern Vermont on the 45th parallel
    Kubota 7510, Toro Groundsmaster 217D
    looks good. maybe use a hand rasp to get rid of any ridges and call it good? beats sanding-
    I thank God everyday for all of the blessings he has given me- especially for the one's I do not recognize or see!
  6. #16
    Join Date
    Dec 2010
    Posts
    1,644
    SW VA
    Default
    Double Double
  7. #17
    Join Date
    Aug 2005
    Posts
    3,170
    Kioti DK40SE Hydro
    Good grief...now we are getting D e l a y e d double posts.
    Anyway, yes, chainsaw...keep it real sharp(always right?), use a speed square to mark your lines on 3 sides. Take your time lining up the saw then follow the line. You might want to go slow(half throttle), but wide open will make a smoother cut.
  8. #18
    Join Date
    Dec 2010
    Posts
    1,644
    SW VA
    Default
    Quote Originally Posted by MotorSeven
    I think it double posted when I pulled the app back up on my phone. Why? And it will show some people's profiles but not others. Why? At least it's a free app!
    I think I'll borrow my friends 011 Sthil. It's a little baby with a top handle and should be much easier to control at shoulder height than my Farm Boss.
    When I made my test run I clamped a 3' piece in my vice outside, marked the top and one side with my speed square and went to work.
    It really didn't rip the grain as bad as I thought it would.
    I also spoke to a guy who worked for the now defunct company that built the original fence. (The one I needed to copy). That's the way they did it. I asked him how they got consistent angles and height on the tops and he laughed and said "Do 8 or 10 thousand and you'll figure it out"
  9. #19
    Join Date
    Dec 2010
    Posts
    1,644
    SW VA
    Default
    Well guys here it is as of yesterday. Don't be bashful, tell me what you think!
    I haven't cut the tops yet. On my way to do that right now after I go buy more lumber for the 2nd phase.
    The owners brother/caretaker of the property seems happy and so am I.
  10. #20
    Join Date
    Dec 2010
    Posts
    1,644
    SW VA
    Default
    Quote Originally Posted by Verticaltrx
    What kind of post driver did you use? I've always had trouble with driving square posts and having them turn when they go in.
    As for cutting the posts, most of the big tool mfg's make a 10-12" circular saw. I've used a Milwaukee before and it was a really nice saw, cuts through 4x4 and 4x6 posts in one pass and 6x6 in two.
    I have a Shaver HD10. I must admit I have a few tricks to keep them from twisting. Starting with a 4" pilot hole is a must.
Similar Threads
  1. Replies: 27
    Last Post: 07-08-2012, 09:39 AM
  2. 3 board fence help
    By JD1979 in forum General Lawn & Garden
    Last Post: 06-15-2010, 12:16 PM
  3. Board Fence
    By theboman in forum Projects
    Last Post: 11-21-2009, 10:06 AM
  4. New 3-Board Fence Going up
    By podzie in forum Projects
    Last Post: 10-30-2008, 09:59 PM
  5. Board Fence
    By willy1947 in forum Projects
    Last Post: 11-18-2004, 08:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
