Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
  1. #31
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,667
    East TN
    Kub - 2K6, B7800
    Default Re: Board Fence Build - pictures and a question
    Thanks for the pictures
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  2. #32
    Join Date
    Oct 2009
    Posts
    667
    IL
    Ford 555 TLB, Xtra-Vator, pallet forks; Caterpillar 12 Motor Grader; FABTEK aerial platform
    I use a Milwaukee 10 1/4" circular saw to cut posts in one pass.
  3. #33
    Veteran Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    1,643
    SW VA
    David Brown 885, Kubota RTV 900, Kubota 9540
    Default
    Just an update. Got done with the first two sections today . I'd been too chicken to cut the tops until today. I grabbed the speed square and figured out how tall from the top board the old posts were cut and what angle. Then got the borrowed chain saw and went to work.
    Board Fence Build - pictures and a question-image-3535806194.jpg.
    It turns out I was worrying over nothing. The biggest problem was that I tended to drift down as I cut away from me. Not much but enough that I noticed it. This was corrected by twisting my wrist to counter the weight of the saw.
    Here is more of the tractor.
    Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
  4. #34
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    3,170
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    You got the hang of it now...looks great!
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  5. #35
    Join Date
    Dec 2010
    Posts
    1,643
    SW VA
    Default
    Quote Originally Posted by MotorSeven
    Thanks! By using the baby Sthil 011 I had pretty good control over the saw. I think my bigger 290 Farm Boss would have worn my arm out pretty quick.
    This will defiantly be my preferred method from now on!
  6. #36
    Gold Member MacLawn's Avatar
    Join Date
    Aug 2007
    Posts
    323
    Red Clay Country, GA & Mississippi Prarie
    JD 2210
    Looks good! I was worrying more about how to drive the posts than how to cut them! How did you drive them?
    "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
    "I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
    "I wouldn't want to be within 400 or 500 yards of one of them newfangled nuclear bombs when it went off!" WW1 Vet...
  7. #37
    Join Date
    Dec 2010
    Posts
    1,643
    SW VA
    Default
    Quote Originally Posted by MacLawn
    We used a hydraulic CAT auger with a 4" bit to pilot the holes followed by the Shaver HD10 post driver on my Kubota.
    The last picture shows the set up as described except with the larger bit on the auger. There were a few tricky spots where the bed rock was only 8 or 9 inches under the soil. The larger bit was used to make room for 80# bags of concrete.
  8. #38
    Join Date
    Aug 2005
    Posts
    3,170
    Kioti DK40SE Hydro
    That FEL auger is the cats azz....how much $ do they run ?
  9. #39
    Join Date
    Dec 2010
    Posts
    1,643
    SW VA
    Default
    You aren't kidding!! If my memory serves me correctly they can run from about $2k on up. We usually had it on the skid steer but it will work just fine on the tractor.
  10. #40
    Join Date
    Dec 2010
    Posts
    1,643
    SW VA
    Default
    Well it looks like I'll be replacing another small section in the morning! Someone ran through this fence again yesterday morning, hit and run. It does appear it got their radiator though.
Similar Threads
  1. Replies: 27
    Last Post: 07-08-2012, 09:39 AM
  2. 3 board fence help
    By JD1979 in forum General Lawn & Garden
    Last Post: 06-15-2010, 12:16 PM
  3. Board Fence
    By theboman in forum Projects
    Last Post: 11-21-2009, 10:06 AM
  4. New 3-Board Fence Going up
    By podzie in forum Projects
    Last Post: 10-30-2008, 09:59 PM
  5. Board Fence
    By willy1947 in forum Projects
    Last Post: 11-18-2004, 08:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
