Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Join Date
    Jul 2009
    Posts
    1,793
    IL
    B2710
    Default Re: Shop stove oil drip
    I've never heard of this, seems kind of dangerous. Oil burns about 400F, way lower than the top of that stove gets with a good fire. But if everyone is doing it, maybe it's safer than it seems. I would think the oil should be injected from the side or front where it's not quite so hot, and have some way of isolating the fuel from the heat of the stove.
    There's also nasty stuff in motor oil like heavy metals, do those end up in the ash or going up the chimney?
    Kubota B2710, John Deere X738 snowblower, Toro Zmaster ZTR, King Kutter bush hog, New Idea manure spreader, Swisher trail mower.
    Lincoln Square Wave 200, Lincoln 225 AC/DC, Harris Oxy/Ac.
  2. #12
    Join Date
    Mar 2010
    Posts
    131
    My waste oil consists of motor oil, atf and gear oil so I think anything that burns with a relatively high flash point would work!
  3. #13
    Join Date
    Mar 2010
    Posts
    131
    Quote Originally Posted by BeezFun View Post
    It's not like you are just dumping massive amounts of oil onto the fire. It's a controlled drip/drop that burns completely. There is no visible change in the chimney smoke or ash accumulation. I suppose if you could inject the oil in an atomization it would be even better combustion and I'm sure produce much more heat than the stove/piping could safely handle.
  4. #14
    Gold Member
    Join Date
    Oct 2009
    Posts
    257
    land of living sky
    B434 ,V 700 and 1086
    If it comes out of the ground and a few chemical engineers get done adding their stuff goddness nows what is in it ,the bases of an air tight stove is to create the secondary burn ,that is where the cleaning comes in to meet EPA standards and get your high energy efficiencies,the polutants are burned there and inside those stoves when that burn is working good it is so hot that even Sam McGee couldn't stand it ,all you have to do is open the door to add wood and you feel it ,don't worry about polutants they get burned.
  5. #15
    Gold Member
    Join Date
    Oct 2009
    Posts
    257
    land of living sky
    Ironically the stove pipe isn't exceptionally hot ,I use a double wall pipe and the top 3 feet isn't much more than to warm to touch comfortably,I only burn wood ,mostly scrap.
  6. #16
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,942
    Central Ohio
    Kubota MX5100
    Very nice job.
    I have one on my barrel stove. I had an old 20 or 30 (can remember now) gallon air tank. I mountend it vertical on the post closes to the stove and a ball valve with some old steel brake line and I was in business.
    Its like killing two birds with one stone......getting rid of old oil AND adding heat.
    To answer some of the other questions......
    With the ball valve (or his needle valve) the adjustment is infinite. Anywhere from off to full stream. Sometimes when getting a fire first going, I will open it all the way to aid. And then back it down once I get the fire going.
    And yes, it does really add alot of heat.
    Oil types....all kinds. Anything that goes into my oil pan, goes into the fire. Hydraulic, transmission, motor oil, gear lube, brake fluid, you name it.
    I've never had a problem with the top of the stove getting too hot for the oil not to work. I think it has something to do with room temp oil constantly running down the tube keeping it cool. IE..stove gets hot, but tube dont get so hot.
    Stihlrunner, I would offer one sugestion to you though:
    Put the valve at the tank and not at the stove. That way it isnt too hot to adjust. Or even just the radiant heat off the top of the stove on the back of your hand. Also, when you close it off, you are probabally boiling the oil in the tube above the valve, and that may give you fits. With the valve at the tank, when you shut it off, the line clears out.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #17
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,019
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    SR thanks for posting this. I researched them a few years ago then got busy with other things. I am now going to scrounge up a tank and modify my stove in the shop like you did and save some wood.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  8. #18
    Join Date
    Mar 2010
    Posts
    131
    Thanks for the input. I do have a ball valve at the tank, mainly to turn off the supply when I leave the shop without messing up the needle valve adjustment. However I have found the needle valve needs to be adjusted anyway when the oil is cold and then needs to be metered a bit after shop heats up.
    I agree on location of needle valve on hindsight I would have put it inline or up higher but it isn't unbearable where it is.
  9. #19
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,543
    Greenwood Co., SC
    Yanmar YM2000
    If this was a problem they would not be allowed to leagally produce and sell "waste oil furnaces" for shops. You can buy a commercially produced and sold unit that will do just this. I dont think i would want to have my face in the smoke consistantly but wifts and such not a problem i would not think, and just wash your hands after handling the ash, and i would not throw ash on my property, i would bag and take to the dump.
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  10. #20
    Join Date
    Apr 2006
    Posts
    2,159
    western NC
    Ventrac, Steiner
    We used to do this with a barrel stove also. The oil tank was a 5gal bucket with the top cut out. This made pouring the used oil in the tank pretty easy from a drain pan. We would put the biggest stick of wood we could find or fit into the stove and let the oil drip onto it. One stick of wood would last a couple of days. I dont remember much ash, altho I am sure there was some. I guess when burning mostly oil there shouldnt be much ash to dispose of.
Similar Threads
  1. Building a waste oil burning stove for my shop
    By LetsRoll in forum Build-It Yourself
    Last Post: 01-29-2011, 12:55 PM
  2. Installing Pellet Stove in Shop
    By Luremaker in forum Rural Living
    Last Post: 12-02-2008, 08:45 PM
  3. Installing Pellet Stove in Shop
    By Luremaker in forum Related Topics
    Last Post: 11-29-2008, 02:10 PM
  4. Do you have a shop wood stove?
    By keving in forum Buying/Pricing/Comparisons
    Last Post: 09-14-2008, 09:10 PM
  5. wood stove in shop
    By mechanic in forum Rural Living
    Last Post: 12-15-2007, 07:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
