Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    BHD
    BHD is online now
    Join Date
    Feb 2007
    Posts
    673
    Default Re: Accessories my new air compressor
    when piping the air compressor, notice the line take off the top of the line, and there are drip legs on all out lets,
    by draining the machine daily and by following the piping diagram in the picture, you will nearly eliminate the majority of the moisture in the compressed air, the large tank you looking at helps as well as the air going into it is cooled and the moisture condensed,
    BIG DOOLEY has some excellent pictures but a few changes in the piping would help a lot on the potential moisture content of the air,
    Attached Thumbnails Attached Thumbnails Accessorize my new air compressor-air-pipeing.jpg
  2. #12
    Join Date
    May 2005
    Posts
    1,003
    Balls Creek, NC
    New Holland 1720
    Default Re: Accessorize my new air compressor
    What everyone on here has said is correct...
    I am in the process of adding an inline water condensate trap to my system...
    The air dryer is the best option but the most expensive...
    The schematic shown is correct in configuring the line from the tank...
    This will trap the majority of water out of your lines...
  3. #13
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    599
    MICHIGAN
    JOHN DEERE 2320
    I guess this thread stuck in my mind today.
    I decided to unbolt my compressor from the floor after dinner and I added a 1/4" drain line to remove moisture from the tank.
    No more crawling under the tank with rags wiping up the mess.
    I ran the line into a plastic jug.
    Attachment 292033
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
Similar Threads
  1. air compressor
    By mechanic in forum Owning/Operating
    Last Post: 04-10-2012, 12:47 AM
  2. Air Compressor
    By Turbys_1700 in forum Parts/Repairs
    Last Post: 11-16-2011, 09:50 AM
  3. Air Compressor
    By clee4020 in forum Attachments
    Last Post: 08-22-2011, 11:00 AM
  4. NEED ID ON OLD AIR COMPRESSOR
    By keller34 in forum Related Topics
    Last Post: 05-05-2010, 06:41 PM
  5. Used air compressor value...
    By Turbys_1700 in forum Projects
    Last Post: 04-28-2009, 07:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
