Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Jan 2011
    Posts
    115
    Philippi WV
    farmall cub John Deere 310 Backhoe Loader Ventrac 4131
    Default Re: Want to add on to my pole barn!
    I would be cautious about taking the siding off of the wall if your trusses are sitting on it. The siding gives a lot of strength to that wall, especially the corners. A large cut in door might be the way to go. I am not an engineer but I feel you would lose a lot of strength removing all of your siding.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Mar 2008
    Posts
    541
    Colorado
    TN55
    There are a LOT of pole barn projects in here. Do your sidewalls have girts? (Horizontal frame material -- probably wood.) How about purlins? (Same idea, but for the roof.)
    They are what keeps the walls from 'racking', though the siding/roofing helps. You can always do what is done on many houses: put a panel of OSB/plywood on the corners or better yet, put an angled brace from the corners. You will also need to know what gage the metal on your barn is. Metal Sales has some good PDF instruction packages on the fittings required, as well as steps needed. Doors are generally best placed on the gable ends, as snow can't slide off the roof in front of the door. Or rain on your head.
    Bigger question: how much roof surface do you have? Snow is your enemy here, as it all adds up when it slides onto the new roof.
  4. #13
    Silver Member joeyd's Avatar
    Join Date
    Jul 2010
    Posts
    192
    North Idaho
    TYM 353HST
    I'm not sure how you want to tie on to your existing building but I also have thought about it. I found these pics on another thread awhile back, I hope they give you some ideas. You might try searching the threads for "pole barn lean to" or something similar.
    337371-lean-to%20rafters.JPG 337373-Lean-to%20framed.JPG 340260-Dscn1021.jpg
    Isa 43:2-3
  5. #14
    New Member
    Join Date
    Dec 2012
    Posts
    4
    Crawfordsville, Indiana
    Kubota
    Default
    Im going to start soon! I really like the lean to that they are building in the pictures you posted! I think i may enclose the whole thing! We will decide as we go!
  6. #15
    Silver Member kentuckydiesel's Avatar
    Join Date
    May 2004
    Posts
    133
    You might want to consider this roof option: Clayton & Lambert Image Gallery
    That's my grandparent's barn in the picture. Originally used for the combine and such, now converted into a horse barn. I also used it for my front porch roof. 15' clear-span on the standard panels.
    -Phillip
    SPIDER TRACTOR: '95 John Deere 5200 MFWD making around 60hp--12.4-24 8ply Goodyear R1 front tires--18.4-26 10ply Goodyear R2 fluid filled rear tires--Tires are set 8' 2" wide for maximum stability on hills--540 Loader with forks and custom fabricated bucket.
  7. #16
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,529
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I have done this twice. My barn started its life as a 40x30' with 12' ceilings. Should have went 14' to start with but thats another story.
    The first extension was done the year after I finished. I added on a 12' extension down the whole 30' side. Its 12' tall on the barn side and 8' tall on the outside. I had gravel but hated it and poured concrete 5 years later. $2000 total cost.
    Last year I blew out the back of the barn. I did 20' of the original 30x40' barn. I went 12' again so now its 42' deep in that part. I did gravel again but within 3 months hated the dust and poured concrete. Total again was about $2000.
    Chris
    Attached Thumbnails Attached Thumbnails Want to add on to my pole barn!-forumrunner_20130208_174126.png
  8. #17
    Join Date
    Jan 2007
    Posts
    12,529
    Daleville, IN
    Default
    Here is the first extension.
    Chris
    Attached Thumbnails Attached Thumbnails Want to add on to my pole barn!-forumrunner_20130208_174321.png
Similar Threads
  1. Pole Barn vs Metal Barn....pros and cons?
    By markmc in forum Projects
    Last Post: 07-27-2010, 05:12 AM
  2. Pole Barn add on to existing garage
    By George2615 in forum Projects
    Last Post: 11-08-2009, 02:41 PM
  3. Pole Barn, Pole Question
    By HoustonBrama in forum Projects
    Last Post: 07-27-2008, 05:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
