Results 111 to 120 of 122
01-19-2013, 06:31 PM #111Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
Get your self several long extention cords long enough to reach the breaker panel. Plug in to an outlet in the house an use it to power a lamp or something. Flip breakers 'till lamp goes out, and that's the breaker for that outlet. If you can't get enough extention cords, use a radio set loud enough to hear from the panel. Use two set to diferent stations.
Originally Posted by SlowPocono
For celing lights, you can get a screw in adaptor at most hardware stores that will allow you to plug in a two prong plug.Dan H.
01-19-2013, 06:36 PM #112Gold Member
- Join Date
- Sep 2012
- Posts
- 338
- Location
- north shore MA.
...and when you are done, label the outlet covers with the breaker number. On the back of the cover if the Mrs. wont stand for labels visable.
Dan H.
01-19-2013, 07:10 PM #113Member
- Join Date
- Dec 2012
- Posts
- 37
- Location
- Ontario Canada
- Tractor
- Kubota M7040
Re: Generator and electricity flow
Digital Circuit Breaker Finder-ET300 at The Home Depot
I dont know how to paste a link properly but Home Depot sells a Klein circuit breaker finder for approx. $40. You plug the transmitter into a receptacle and scan the breaker panel with a receiver until you find the breaker you are looking for. It makes the job you are wanting to do very easy and you will soon have friends wanting to trace circuits in their homes.
Dave M7040
01-19-2013, 10:45 PM #114Silver Member
- Join Date
- Oct 2010
- Posts
- 108
- Location
- Northern Virginia
- Tractor
- JD 6430Prem, JD 6400, JD 5500, JD4710, 955, 455
Howdy SlowPocono,
I am glad you got it all together. As you see, anyone can hook your generator up safely even if you not there. Or disconnect it and flip the main back on.
I use little orange and blue little dot stickers. I usually leave all 15amp breakers on (usually all lights), I just switch between running pump, then running hot water heater, then pump to shower. I do not turn off the electric stove breaker... no sense, I am on generator, and I can not run everything. You would be suprised at how many things can run in the house. You just need to watch when you run the big draw things (well pump, hot water heater)
2 people tracking down circuit breakers is always easier too.
good luck
MikeLater Mike ~~~
JD green here
tractors and implements
01-20-2013, 08:22 AM #115Gold Member
- Join Date
- Apr 2010
- Posts
- 329
That's always been a puzzler for me. With all of the other rules and regulations associated with a panel, why is circuit labeling sort of *allowed* to be all over the place? Of course changes and upgrades made somewhere along the way could render what the original installer did, (and what the inspector signed off on), as being perhaps less relevant, but still....It has been discovered that many of the circuit breakers are mislabeled
Our house was built in the late 70's. The breakers were labeled with a dull pencil....using made-up abbreviations....in handwriting that rivals the "prescription script" of an elderly doctor.
01-20-2013, 09:32 AM #116Platinum Member
- Join Date
- Oct 2005
- Posts
- 731
- Location
- Southern Indiana
- Tractor
- Kubota/B7800
01-20-2013, 05:51 PM #117Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,448
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Your setup is just about what I have. I went back and painted all the breakers I want to turn off with red paint so its easy to figure out at 3am when the power is out.
The only big draw breaker I leave on other than the 30 amp well pump is the 50 amp stove. I have used just one or two burners with no issues.
We have propane hot water and heat so that is not a issue.
Chris
01-20-2013, 05:56 PM #118Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,448
- Location
- Daleville, IN
- Tractor
Not sure why all the pics are rotated?
Chris
01-20-2013, 06:21 PM #119Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,448
- Location
- Daleville, IN
- Tractor
Lets try again.
Chris
01-20-2013, 06:33 PM #120Gold Member
- Join Date
- Apr 2011
- Posts
- 310
- Tractor
- none
So just to be clear, NEC is ok with the interlock breaker system?
Similar Threads
Electricity rates
By Bob Ha in forum Rural LivingReplies: 59Last Post: 05-04-2012, 07:21 PM -
not getting electricity
By marler in forum Kioti Owning/OperatingReplies: 4Last Post: 10-25-2011, 09:32 PM -
Saving electricity
By rgood in forum Rural LivingReplies: 32Last Post: 03-13-2009, 02:30 AM -
I have electricity!!
By JoeR in forum Kubota Owning/OperatingReplies: 9Last Post: 08-16-2004, 10:44 PM -
New Improved Electricity
By Anonymous Poster in forum Related TopicsReplies: 0Last Post: 02-03-2002, 03:14 AM
