davedj1
Sorry, I just realized that pacerron covered it already.
dave
Sometimes my typing over thinks my thinking....LOL
dave
The thing that I still find disturbing is how much money they lose redoing their work. I can't believe that it is cost effective to have cheap guys do lousy work that has to be redone.
Lee
We have some strange attitudes toward residential construction given that a home is often the most expensive product we will ever buy. Poor Peter is (benefiting? ) from the collective experience of many people. And yes, we can nitpick from our armchairs. But suppose that were not the case? Shouldn't Peter or anyone else have an expectation of receiving a quality product when building a home--even if they don't personally know what makes a home a quality product?
But on the opposite side, just blindly following the plan, even when you know its a bad plan isn't a good way to work either...
I guess I did it all wrong
I sanded, stained and urethane my t&g before putting it up
It seemed to work out nicely and I would hate to be on a ladder or scaffolding trying to sand & stain
View attachment 314693View attachment 314694View attachment 314695
You and I know it's a money losing proposition to have to redo shoddy work; but the builders who take the cheap approach are essentially gambling that no one will notice and/or complain when something pukes prematurely due to crappy work. Apparently their gamble pays off enough that they continue cranking out garbage.
The rule to keep in mind in any waste or gravity flow piping is to keep the curves/bends to a minimum and as gentle as possible.
There are elbows known as "Lazy Els" that make a 90 degree turn but over a larger radius with less tendency to clog and easier to clear if they ever do.
Using 2- 45 degree or half els with a straight piece in between accomplishes the same thing, just like the way a downspout leaves the gutter. Had a 90 been used up there and another back at the house you would create certain clogging.
The 3 tight elbows under the Y fitting shown in the picture of, I think Obed's house, is just designing in a big clog area. All those sharp corners could have been eliminated by using two 45 degree joints with a piece of straight between them, making the Y clean out superfluous and the natural flow a lot better.
http://www.tractorbynet.com/forums/attachments/projects/313710d1366310674-building-stick-frame-house-woods
Actually, these 90 degree elbows are the "large radius" type. I have had no clogging issues even though our house is in the middle of the woods. The Y cleanout is just a precaution. All it takes is for a squirrel or rat to get stuck and die inside the pipe to cause a big headache if a cleanout is not easily accessible.
Obed[/QUOTE]
Obed,
I know what you mean. I have barns with large gutters and downspouts.. 4 downspouts handle 6,000+ square ft. of metal roof surface. That size downspout appears to be just perfect for a Starling to build a nest over the hole in the gutter. A heavy storm would wash the nest and sometimes the Starling about halfway down the 14' long downspouts. Taking down the downspout was the only way to get them out. They would pick and toss expanded metal guards from the holes so they could nest. So I had to design my own heavy wire guards secured so they couldn't get them out.
I also make guards with 1/2" holes drilled in them from cottage cheese type lids and secure them to the ground outlet ends and french drain ends with a couple self tapping screws. Keeps the ground pests out.
The animals were here long before we were and they like to keep reminding us that even though we pay the taxes, they still own the place.:confused3:
Ron
