Page 166 of 240 FirstFirst ... 66116156163164165166167168169176216 ... LastLast
Results 1,651 to 1,660 of 2391
  1. #1651
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,112
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Default Re: Building a stick frame house in the woods in 90 days
    That is good looking lawn prep work. Actually, it's beautiful.
    For future note, till with the rear flap all the way down and till very slow. I bury acres and acres of rocks every year with zero issues and none, or few popping up. I would think too fast of a ground speed would lift the rocks. I use 1.0 or 1.1 mph at 540 pto and it works great.
    But who cares...your job came out great.
    May I be the kind of person my dogs think I am,
  2. #1652
    Join Date
    Jan 2012
    Posts
    1,422
    Ma
    Kubota b2920
    Lawn looks really good! How did you pick up all the rocks? Just rake them into a pile and load by hand, or did you do something else? Did you have any issues with roots tilling near the trees?
  3. #1653
    Veteran Member pclausen's Avatar
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    JD 5085M, Ford 1700, JD GT235, JD LT166
    Thanks!
    I'm tilling using 540E pto speed (engine at 1700 rpm), and I'm in first gear. Speedometer indicates I'm traveling at 0.9 mph, so that as slow as I can go while maintaining 540 rpm. My rear flap is not fixed in a given position, it is free to float as I do not have the rod that allows you to set the height. If I locked it into a low position, don't you think I would bang it up when a rock tries to escape?
    JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
    2002 Silverado Duramax 3500 Crew Cab LT 4x4
    BigTex 22.5K 25' Gooseneck Trailer
  4. #1654
    Super Member Pixguy's Avatar
    Join Date
    Oct 2010
    Posts
    8,030
    By the Lake, NH
    2011 MF 2410 TLB
    Great lawn Peter, I love the look of the house and lawn when your back was to the woods. Keep up the good work.
    "Any man who thinks he can be happy and prosperous by letting the government take care of him, better take a closer look at the American Indian"
    Henry Ford
  5. #1655
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    Quote Originally Posted by tractchores View Post
    After the first pass with the tiller, I used the rake to drag what was brought to the surface (and what was already there) down to the lower end. After 4 or 5 "drags", and would then pull what was collected into the corner. Then I would do the next 4 or 5 "drags" and repeat. After that, with 2 more passes with the tiller, I would drive the lawnmower with the card attached, in straight lines and stop every 50 feet or some, and pick up all rocks and sticks by hand. I probably filled up the cart 6 times with this method. I then did a final pass with the tiller, manually picked up everything again (went much quicker this time), and then did a final rake from top to bottom in straight lines. Tomorrow morning, I'll do one more round of manually picking debris, and make a final pass in a couple of spots that are not quite even yet.
    I picked up a 24" x 48" lawn roller from TSC this morning that I filled with water. It weigh about 930 lbs. Once I get the seed and fertilizer down, I plan to make passes with it from top to bottom much like I did with the rake, and then straw everything. The straw blower has still not shown up, so I might be spreading those 50 bales by hand.
  6. #1656
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by pclausen View Post
    Hopefully you have a PTO driven broadcast spreader for the lime, fertilizer, and seed.
    The trough kind that are pulled behind a lawn tractor and are wheel driven are no good in my opinion since they take way too long and leave too much product in the spots where you turn.
    If you spread all that straw by hand you'll need another week off to recover. Better get Stu to motor down tonight so he can help you all day tomorrow.
    Sorry Stu, Just had to volunteer you.
    Ron
  7. #1657
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Quote Originally Posted by pacerron View Post
    mjncad,
    Home inspector certification in Virginia was developed in 2001 and enacted in 2003.
    State Home Inspector Regulatory Legislation | ASHI, American Society of Home Inspectors
    Care must be exercised, in any case. A $300,000 + home is a big investment.
    Ron
    As much as I dislike Gummint intrusion, I think home inspectors should be licensed in Colorado. I've had a couple of home sales go south due to incompetent inspectors and uninformed buyers. I'm protected from a bad haircut that will grow out in a couple of weeks; but not from some boob who can screw up a home deal in nothing flat.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  8. #1658
    Join Date
    Oct 2008
    Posts
    1,186
    Mid. Coast Maine
    7610 hst
    I see switches and outlets are still not installed ?? When are the electricians coming back???
  9. #1659
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by hr3 View Post
    I would hope they wait till after the plasterboard is patched, sanded, and painted the final time. Light fixtures, sockets, and tile joints covered with PB mud dust and paint on the mounting screw
    tabs of plugs and switches wastes a lot of time removing and looks like a shoddy job if they don't. All the do over work is going to require a lot of time for someone to clean the house with more than just a shop vac before move in day. Hopefully the contractor has somebody on staff that will do a top to bottom cleaning before the house is turned over for move in.
    The homeowner or hired help is usually left with removing those pesky stickers from the windows and cleaning them inside and out but with all the fascia redo, concrete stain that will now probably have to be painted over, possible siding and sliding door removal and other things on the list near the home, even cleaning the windows ahead of those items is a waste of time.
  10. #1660
    Veteran Member srs's Avatar
    Join Date
    Feb 2004
    Posts
    1,073
    Jarrettsville Maryland
    Kubota B3030 HSDC
    Building a stick frame house in the woods in 90 days-t2-jpgBuilding a stick frame house in the woods in 90 days-t1-jpgBuilding a stick frame house in the woods in 90 days-t3-jpg
    I know I'm late with posting these pictures but did not know if the buckling aluminum fascia was resolved. These pictures are from my 9 year old house so please excuse that they need cleaning. I took the photos from the ground looking up. My installer never face nailed the fascia. He bent the aluminum on a 12' long brake, then slipped the fascia up under a lip near the roof shingles. On the short part of the bend he drilled holes to attach the fascia to the soffit using white aluminum rivets. It made for a very clean install (pardon the pun cause it's dirty now) and I don't have any buckling of any panels. Hopefully the pictures will make it more clear then my explanation. Stanley
    Stanley----Kubota B3030 HSDC
Similar Threads
  1. Post frame building slab.....
    By Kenfyoozed in forum Projects
    Last Post: 02-13-2014, 07:04 PM
  2. What is a galvalume frame building?
    By DennisH in forum Projects
    Last Post: 08-18-2011, 05:56 PM
  3. Post Frame building Recommendation
    By scoutcub in forum Projects
    Last Post: 02-16-2011, 11:15 AM
  4. Replies: 0
    Last Post: 11-30-2005, 06:48 PM
  5. Building A Frame For Cab
    By NY_Yankees_Fan in forum Customization
    Last Post: 12-22-2002, 08:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
