Page 22 of 239 FirstFirst ... 12192021222324253272122 ... LastLast
Results 211 to 220 of 2389
  1. #211
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    Default Re: Building a stick frame house in the woods in 90 days
    you just need to provide a less resistance channel for water to go to. Just apply dimpled membrane to the walls on outside and then you can backfill with clay.Building a stick frame house in the woods in 90 days-membrane-gif
  2. #212
    Join Date
    Jul 2010
    Posts
    2,391
    Pacific Northwest
    Drains in garage floors here are illegal. They do not want the oils and antifreeze going down a drain.
    2007 Kubota L3130, LA723 FEL
    Land Pride FDR1672 rear finish mower, Frontier RB1172, Koyker KB60 BH
    Pallet forks, Golf cart canopy bolted to ROPS, 9" & 12" PHD
    2016 Ferris IS700Z 52" Briggs 27hp commercial turf series
  3. #213
    Veteran Member srs's Avatar
    Join Date
    Feb 2004
    Posts
    1,072
    Jarrettsville Maryland
    Kubota B3030 HSDC
    Quote Originally Posted by hawkeye08 View Post
    hawkeye, I hear what you are saying but if you park your vehicle outside or if the garage floor slopes toward the garage door and your vehicle leaks the oils, antifreeze, etc. they still end up leaking into the soil. I assume the inspecting agency is thinking the concrete garage floor will absorb the oils.
    Stanley----Kubota B3030 HSDC
  4. #214
    Join Date
    Feb 2004
    Posts
    1,072
    Kubota B3030 HSDC
    Quote Originally Posted by radioman View Post
    The dimpled membrane is a great idea!
  5. #215
    Join Date
    Jul 2010
    Posts
    2,391
    Pacific Northwest
    We get snow and rain here, so vehicles come in shop and garage with snow and water dripping off. We slope the floors towards the door and it runs out for the most part. Several neighbors have drains and hid the drain during inspections. They are also the same folks that think nothing of letting spills (oil when changing oil, etc) go down the drain. I rather properly dispose of my fluids and put up with not having a drain for the water to drain away. I am not a fanatic but do know where my well water comes from.
    I have no issues with the water draining somewhere along with incidental other fluids....
  6. #216
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Quote Originally Posted by Ranger Rick View Post
    One way to relieve any water pressure against the walls of your foundation is to use a foundation drainage mat attached to the foundation wall. When I built my house we have clay soils and our neighbors had wet basements so I used it. It is a dimpled heavy plastic barrier that allows any water near the foundation to just drop to the drain at the bottom of the wall. We then just back filled with the subsoil. In 17 years I have had no water in the basement and when it rains the sump pump is doing its job. Just an alternative to the many tons of gravel that others have suggested. Rick
    Hmm. Learning something new there. Thanks. And thanks for the illustrations RadioMan.
  7. #217
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    One day for the foundation is amazing, this will sure speed things up. What a great veiw you have there, the walk out basement will be nice also. Great job on the pic's.
    Dave
  8. #218
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    It's sort of silly. Conscientious people will do the right thing. The others will dump it somewhere anyways. What happens to the salt and silty sand that runs off the road surfaces in spring? It ends up in the water drainages and ground water. So, if it melts off your car, goes down the drain and then to the ground, same difference.
    I have heard of requirements to send garage drains into the septic or sewer system. Bad for the septic, and could well end up being spread as sludge on fields if sent to the sewer/treatment plant. Come to think of it, that is where septic tank pumpings go also.
    I have a jug of used antifreeze from the tractor that I have sort of worked at finding out how to properly dispose of, for two years now.
  9. #219
    Veteran Member pclausen's Avatar
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    JD 5085M, Ford 1700, JD GT235, JD LT166
    Keep all the good advice coming! I don't mind it one bit. I'm sure I'm already on the builders "not friend" list, although he still calls me boss man anytime we talk. lol
    There will be a secondary drain on the high side of the house that will divert water around to the lower side and exit 50' or so away through a underground pipe on the downhill side of the house.
    All downspouts will be connected and run through a seperate underground pipe that will also exit 50' away from the house.
    This is in addition to the already installed drain system along the outside perimeter of the basement walls, that also exist 50' away from the house. This system is tied into the floor drain in the center of the drain fields.
    This should keep almost all water away from the house except maybe during extreme storms with high windows that will splash water directly on the walls of the house.
    The Superior Wall product comes with a 10 year guarantee against any moisture/water issues, as long as it is installed as per their instuctions, which this house is.
    All that said, I will ask the builder what he things about backfilling with river rocks and if he would charge me more for that. I really think that having those 3 independent drain systems will cover and prevent 99% of all water from ever reaching the basement walls in the first place.
    JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
    2002 Silverado Duramax 3500 Crew Cab LT 4x4
    BigTex 22.5K 25' Gooseneck Trailer
  10. #220
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    I suspect that a lot more antifreeze and oil makes it into the ground from cars being worked out out in the open (i.e. shadetree mechanics) than what might come from floor drains in garages...
Similar Threads
  1. Post frame building slab.....
    By Kenfyoozed in forum Projects
    Last Post: 02-13-2014, 08:04 PM
  2. What is a galvalume frame building?
    By DennisH in forum Projects
    Last Post: 08-18-2011, 06:56 PM
  3. Post Frame building Recommendation
    By scoutcub in forum Projects
    Last Post: 02-16-2011, 12:15 PM
  4. Replies: 0
    Last Post: 11-30-2005, 07:48 PM
  5. Building A Frame For Cab
    By NY_Yankees_Fan in forum Customization
    Last Post: 12-22-2002, 09:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
