Page 25 of 240 FirstFirst ... 15222324252627283575125 ... LastLast
Results 241 to 250 of 2392
  1. #241
    Silver Member Scooter78's Avatar
    Join Date
    Mar 2011
    Posts
    141
    West TN
    Yanmar 2310D
    Default
    It's hard to believe this all started with somebody saying he should put in a floor drain in the garage. I agree with MossflowerWoods lets get back to the build.
  2. #242
    Elite Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    3,280
    Beaver Dam Wisconsin then to Hohenwald, TN
    John Deere 3720
    Default Re: Building a stick frame house in the woods in 90 days
    Quote Originally Posted by Obed View Post
    Pete,
    Have you thought about how the gravel under the garage slab will be compacted to prevent significant settling? Of particular note is the depth of the gravel at the area where the garage meets the house? I had this same issue at my house. We did not do it correctly and I may pay for it eventually.
    Attachment 304785
    Obed
    I used 3/4 clear stone Building a stick frame house in the woods in 90 days-104_0484-jpgand my set up was similar to that. I had about 5-6' of it dumped along house walls in the garage and just compacted it with a walk behind plate compactor. The garage floor itself had about 2-3' or so of the same stuff.Building a stick frame house in the woods in 90 days-105_0548-jpg The floor has been fine for 8 years.
    I worked with some excavators that dug holes for 2000 Ton punch presses and had holes 25' deep. They had to fill the perimeter of those big holes around the concrete foundation that full depth and they used that same crushed stone. It was about 2' thick around and all the way up to the concrete floor. Our company engineer made them compact it every couple feet, but he said hardly anyone compacts that because it doesn't compress. I compacted my garage just to be sure, but I don't think I would have had to because it hardly settled out at all.
    The nice thing about clear stone, if you decide to put a drain in later, just drill a hole in the floor and let it drain through the gravel.
    JD 3720 with R4s and bulldozer capabilities.
    X740
    13 Millimeter = 1/2"--------25 Milimeters=1"-----------100 Millimeter = 4"----------1 Meter = 40---------1 Kilometer = 3300' or 5:8 ratio
    A 13mm will but will be just slightly larger than a 1/2" nut.
  3. #243
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by Deere Dude View Post
    There is a Builders Guidline here Superior Walls® Builder Guideline Booklet - Simply Superior™
    I haven't read it all yet but it does cover the overdig in an attached garage situation.
    The first few pages cover most of the questions that have been brought up here.
    SW places all responsibility for any bad building practices and warranty on the franchisee.
    If you Google "Problems with superior walls" you will see that most are related to the installation
    rather than the design of the panels.
  4. #244
    Super Member buckeyefarmer's Avatar
    Join Date
    Jun 2005
    Posts
    7,471
    MD
    Kubota L3940 L5030 MF205-4
    FWIW, I had to put a good bit of gravel under my 2 car garage slab. No compaction, but I did use rebar in the concrete. I have a hairline crack from not putting in a control joint, don't know why the finisher didn't put one in, and I didn't think to ask.
    I love the construction pics.
    2010 - L3940HSTC, QA FEL, BH92
    2010 - Husqvarna YTH24V48LS (the other orange)
    2005 - L5030HST,QA,FEL
    198x - MF 205-4
    1990 - Wheelhorse 212H
    2017-ratchet rake, 2008-KK Tiller, 2006-Pallet forks, 2002-Carryall, 2000-PHD, 1999 - Trailer, 1999-6' rotary mower, 1999-cultivator, 1998-KK Finish Mower, 1998-Blade,1992 - Troybilt tiller, 2 wheel barrows, assorted gardening tools,
    http://www.tractorbynet.com/forums/r...life-farm.html
  5. #245
    Veteran Member pclausen's Avatar
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    JD 5085M, Ford 1700, JD GT235, JD LT166
    Day 32
    Quote Originally Posted by mjncad View Post
    Will you sawcut the control joints, or were they tooled in after you took the pictures? I sure hope you went with sawcut control joints.
    Indeed! They also put some sort of sealant on, which I thought was odd. I wasn't there all day, but this is what it looked like when I popped by after work. Yes, those are water drops from the rain/sleet/ice we had today.
    It will be very interesting to see what it looks like once it all dries up.
    The first bit of lumber for the framing kick off on Monday was dropped off today as well.
    JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
    2002 Silverado Duramax 3500 Crew Cab LT 4x4
    BigTex 22.5K 25' Gooseneck Trailer
  6. #246
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    Quote Originally Posted by jinman View Post
    Pete, in traditional construction, there's a sill plate below the wall studs that's continuous so drywall and eventually moldings can be screwed/nailed anywhere along the bottom surface. With your walls, it seems there is nothing to fasten the drywall to between studs, and moldings will have to be screwed instead of nailed (or maybe glued). Am I correct? Maybe I've missed how that is done with this system.
    Good question Jim. Didn't really think about that yet. I'll ask the builder how that's done. Not that we'll be finishing the basement anytime soon, but you never know. I'm sure there's a good method for doing that with these walls. It seems they thought about everything else!
  7. #247
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    Quote Originally Posted by pacerron View Post
    Cool link! Hadn't stumbled across those guides yet. Excellent material.
  8. #248
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,200
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    My experence with concrete floors over the years is that cracks of some will will appear no matter what efforts are made to control them. But minor cracks are no big deal. A friend in the concrete business told me there are two things certain about concrete---first, it will dry and second, it will crack.
    Your job really looks beautiful but you'll likely still get some minor cracks in the floors. Maybe someone else more knowlegable could add something to this.
    May I be the kind of person my dogs think I am,
  9. #249
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by sixdogs View Post
    He may ( probably will ) get more cracks, possibly starting where some of the pipe risers come through the floor.
    Remember... he has fiber in the concrete, so that may help. It will probably all be covered with carpet or tile someday anyway if he finishes the area, and will have to be corrected at that time..
    I know this house is for his mom but I sure could imagine a vehicle maintenance pit, complete with floor drain, in the over dig
    area of the garage.
  10. #250
    Veteran Member MacLawn's Avatar
    Join Date
    Aug 2007
    Posts
    1,375
    Red Clay Country, GA & Mississippi Prarie
    JD 2210
    Looking good, man!
    "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
    If idiots could fly, this place would be an airport.
    "I wouldn't want to be within 400 or 500 yards of one of them newfangled nuclear bombs when it went off!" WW1 Vet...
Similar Threads
  1. Post frame building slab.....
    By Kenfyoozed in forum Projects
    Last Post: 02-13-2014, 07:04 PM
  2. What is a galvalume frame building?
    By DennisH in forum Projects
    Last Post: 08-18-2011, 05:56 PM
  3. Post Frame building Recommendation
    By scoutcub in forum Projects
    Last Post: 02-16-2011, 11:15 AM
  4. Replies: 0
    Last Post: 11-30-2005, 06:48 PM
  5. Building A Frame For Cab
    By NY_Yankees_Fan in forum Customization
    Last Post: 12-22-2002, 08:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
