Results 731 to 740 of 2391
03-25-2013, 09:07 AM #731
- Join Date
- Dec 2007
- Posts
- 10,118
- Location
- Central Ohio
- Tractor
- JD 5520, 790- Kub L4300, B7800, MX5100, M7040
Re: Building a stick frame house in the woods in 90 days
We have an attached two car garage on our house built 12 years ago. It has 2 x 4 exterior walls and we insulated it with fiberglass batting and put up sheetrock. It was really more of a "weather lock" to prevent opening doors to the outside. Anyway, it has no heat source but pulls enough from the two sides that are against the house to make it pretty comfortable to work in as long as it's not bitterly cold outside. While I thought I would need some heat, it's not uncomfortable to work in a place that's a little on the cool side.
May I be the kind of person my dogs think I am,
03-25-2013, 12:19 PM #732
- Join Date
- Jun 2008
- Posts
- 10,903
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
All my plumbing is copper and insulated and underground. I have a small pump located at the hot water tank that circulates the hot water from a header to all locations so it is instantly hot, well almost, it has to run from the header to the faucet about 4 feet normally. I would for sure insulate the lines with closed cell foam (cheap) and have the plumber run a recirc line for all the hot water ( a little added cost but not too much at this point) and add a recirc pump. Water costs more than the electricity to run the little pump when you have to run a couple gallons to get it hot before use every time and water costs are rising everywhere you have city water supply.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
03-25-2013, 12:32 PM #733
- Join Date
- Aug 2007
- Posts
- 1,366
- Location
- Red Clay Country, GA & Mississippi Prarie
- Tractor
- JD 2210
Again, yep, insulate ALL your water pipes! I also second sealing so mice can't get in - it can be done, I also did that to my house - no crits inside, except me hound of course.
"He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
If idiots could fly, this place would be an airport.
"I wouldn't want to be within 400 or 500 yards of one of them newfangled nuclear bombs when it went off!" WW1 Vet...
03-25-2013, 01:13 PM #734
- Join Date
- Jun 2011
- Posts
- 2,323
- Tractor
- CNH 4020
Pete,
Haven't seen any tub or shower bases in the bathrooms to date. Are they both going to be custom made in place?
Ron
03-25-2013, 01:56 PM #735
- Join Date
- May 2008
- Posts
- 1,442
- Location
- Nelson County, VA
- Tractor
- JD 5085M, Ford 1700, JD GT235, JD LT166
JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
2002 Silverado Duramax 3500 Crew Cab LT 4x4
BigTex 22.5K 25' Gooseneck Trailer
03-25-2013, 02:01 PM #736
- Join Date
- May 2008
- Posts
- 1,442
- Location
- Nelson County, VA
- Tractor
They are on order. Both are reinforced so that handles can be added if/when necessary. They are going to be heavy. They are expected next week.
Skylights will be 22" wide by something like 36" long. I'll do some looking around at ones that are highly rated and compare to that the builder is suggesting. He will insulate the interior walls in the sun room, bathroom and wall between kitchen and mudroom. He will also make sure the bath fans are vented to the outside through rigid pipes with a slight drop towards the outside.JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
03-25-2013, 03:21 PM #737
- Join Date
- May 2008
- Posts
- 1,442
- Location
- Nelson County, VA
- Tractor
Anyone have any experience with this type of skylight?
Shop VELUX 47-1/4-in x 22-3/8-in x 3-3/8-in Tempered Skylight at Lowes.com
The few reviews on Lowe's website seem very positive.JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
03-25-2013, 03:36 PM #738
- Join Date
- May 2008
- Posts
- 1,442
- Location
- Nelson County, VA
- Tractor
Thinking about these for the basement and garage:
Shop Metalux 48-in Fluorescent Troffer at Lowes.com
Looks decent. Any reason not to go with those?JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
03-25-2013, 05:57 PM #739
- Join Date
- Jun 2011
- Posts
- 2,323
- Tractor
- CNH 4020
Pete,
The skylights look good as long as you use their flashing kit and the contractor follows the instructions as to cutout size and installation.
Out in the garage you might want to get fluorescent fixtures with ballast for cold weather starting just to be sure they will come on and be full brightness on cold winter days/nights.
Back to the deck a moment.
Do you have the plan for final placement of the posts?
It looks to me, from the way they have framed it that "set-back" posts attached to a beam or bolted to two joist running across under the present frame would be the way to go. You certainly don't want any posts in front of the windows or doors.
A lot of folks, including your house, have the posts clear out next to the rim joist and/or attached to the back of it, which is fine, but having the posts set back a foot or two ( in accordance with any codes based on the framing size ) looks more classy, and in this case would be stronger. IN MY HUMBLE OPINION..
Ron
03-25-2013, 06:28 PM #740
- Join Date
- Apr 2009
- Posts
- 12,795
- Location
- nowhere, md
- Tractor
- Hanomag
Pete,
I had 3 Velux skylight windows that must have been very similar to those you linked, although mine were in 1995 and who knows where quality goes over time. They cranked open. I had Anderson casement windows, the Velux color and frame blended very well.
I only lived with them for 11 years, but in that time I had absolutely no issues. They were on a 6/12 south-facing shingle roof. So, they took a sun beating.
Similar Threads
Post frame building slab.....
By Kenfyoozed in forum ProjectsReplies: 13Last Post: 02-13-2014, 07:04 PM -
What is a galvalume frame building?
By DennisH in forum ProjectsReplies: 8Last Post: 08-18-2011, 05:56 PM -
Post Frame building Recommendation
By scoutcub in forum ProjectsReplies: 3Last Post: 02-16-2011, 11:15 AM -
Looking at U.S. Building Systems A frame buildings
By stevenf in forum ProjectsReplies: 0Last Post: 11-30-2005, 06:48 PM -
Building A Frame For Cab
By NY_Yankees_Fan in forum CustomizationReplies: 16Last Post: 12-22-2002, 08:24 AM
