Page 75 of 239 FirstFirst ... 25657273747576777885125175 ... LastLast
Results 741 to 750 of 2389
  1. #741
    Veteran Member pclausen's Avatar
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    JD 5085M, Ford 1700, JD GT235, JD LT166
    Default Re: Building a stick frame house in the woods in 90 days
    Thanks for the feedback on the skylights, and Ron, good point about cold weather ballasts for the garage.
    I like your idea about setting the deck posts back from the outside perimeter some. Unfortunately I don't think I can have both that AND not have posts in front of the basement windows. Will discuss with the builder, I talk to him 7 days a week anyway. Lol. He just dropped off stamped concrete patterns and colors, as well as color selections for the hardy plank. He is also leaning towards using block for the walls comming off the garage now.
    Nobody on site today because of the snow...
    The inspection scheduled for tomorrow and been pushed to Wednesday. That's the one that will trigger the power company coming out and installing the transformer and hooking it up to the meter base.
    JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
    2002 Silverado Duramax 3500 Crew Cab LT 4x4
    BigTex 22.5K 25' Gooseneck Trailer
  2. #742
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Quote Originally Posted by pclausen View Post
    Pete,
    I must not have been clear. Using a beam or 2 x joist bolted to the top of the post ( house side and woods side ) to support the underside of the frame that is now in place, gives infinite location of the posts position along the beam or post, except for the rule governing how many posts you must have ( how many feet apart). Within that parameter you should be able to space the posts so there is one in the space between the double door and window on each side, and then on toward the corner outside the window space, and on to the diagonal turn, etc. while maintaining even or at least balanced spacing. If the code says you must have a post at least every 10 feet you can have one every 9 ft. or 8 ft. or whatever works out; just not more than 10. Having the post closer to the house actually gives you a wider view from inside the windows.
    See attached with caption.
    Ron
  3. #743
    Super Member
    Join Date
    Apr 2000
    Posts
    5,673
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    Getting power is a BIG step, makes things easier for everyone. For what it is worth, I had two Velux skylights that I installed and lived with for over 10 years in my last house without any problems.
    MarkV
  4. #744
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    Ah, I got you now Ron. Lol on the caption. I actually added that pole barn extension to my shop 99% by myself. Setting those 6x6 16' posts by myself was a bit of a pain though.
  5. #745
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,095
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Always nice to work off of site power rather than a generator...
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  6. #746
    Gold Member Ranger Rick's Avatar
    Join Date
    Aug 2007
    Posts
    315
    Louisa, VA East of Charlottesville
    Kubota L3940
    Pete,
    Next time you have to set those 16' 6x6 by yourself, chain them to your pallet forks. It is a lot easier on the back. Rick
    Building a stick frame house in the woods in 90 days-img_1569-large-jpg
  7. #747
    Join Date
    Jun 2011
    Posts
    2,323
    CNH 4020
    Yes, I ended up looking at the entire thread. First look was just to positive ID your house so I could figure out where mom's new one is being built.
    I enjoyed your green rig for putting the roof panels up.
    Another point on garage lighting. I don't know if your mom has a car with a trunk or a hatchback, but this basically applies to both. The little lights that come on, on a double wide garage door opener are lousy. If she pulls in in the winter, shuts down the engine, and then closes the garage door, before getting out to get groceries or other packages from the trunk or hatchback, it is pretty dark back there.
    I would suggest having a light/lights in the ceiling back near the garage door as well as in the front near the entrance to the mudroom and basement stairs.
    You might even do a relay off the door opener that would energize a circuit to some of the lights to turn them on before she gets out of the car and stay latched after the remote times out, so the lights would stay on until until she turns the lights off with a push button or toggle switch by the mudroom door.
    At the very least, have the electrician put a two way or three way, toggle on the wall right to the left of her driver door, so she can turn on some lights
    w/o having to go to either end of the garage.
    Ron
  8. #748
    Platinum Member ustmd's Avatar
    Join Date
    May 2009
    Posts
    815
    Manor, TX (outside of Austin)
    Kioti CK27 HST
    Anyone have any experience with this type of skylight?
    Shop VELUX 47-1/4-in x 22-3/8-in x 3-3/8-in Tempered Skylight at Lowes.com
    The few reviews on Lowe's website seem very positive.
    I have 2 in my office since 2009, so far, so good.
  9. #749
    Super Member buckeyefarmer's Avatar
    Join Date
    Jun 2005
    Posts
    6,563
    MD
    Kubota L3940 L5030 MF205-4
    I've been looking all night to find out if my skylights are Velux, and I can't find my info. I bought them at HD in march 1997, and even have the faded receipt which just says skylight. I think they are Velux, and have been very good. Mine crank open and have a screen. I do have an occasional leak near one on a 4/12 pitch, but I can't claim it's due to the skylight, although my wife does. She does not like skylight in the bedroom, that one will have to go someday.
    I put in lots of 16' 6x6 posts by myself, found it to be pretty easy. pick them up about 3' with pallet forks, one end over the hole, lift the other end up, setting the other end in the hole, and walk it up.
    2010 - L3940HSTC, QA FEL, BH92
    2010 - Husqvarna YTH24V48LS (the other orange)
    2005 - L5030HST,QA,FEL
    198x - MF 205-4
    1990 - Wheelhorse 212H
    2017-ratchet rake, 2008-KK Tiller, 2006-Pallet forks, 2002-Carryall, 2000-PHD, 1999 - Trailer, 1999-6' rotary mower, 1999-cultivator, 1998-KK Finish Mower, 1998-Blade,1992 - Troybilt tiller, 2 wheel barrows, assorted gardening tools,
    http://www.tractorbynet.com/forums/r...life-farm.html
  10. #750
    Join Date
    Jun 2005
    Posts
    6,563
    MD
    198x - MF 205-4
Similar Threads
  1. Post frame building slab.....
    By Kenfyoozed in forum Projects
    Last Post: 02-13-2014, 08:04 PM
  2. What is a galvalume frame building?
    By DennisH in forum Projects
    Last Post: 08-18-2011, 06:56 PM
  3. Post Frame building Recommendation
    By scoutcub in forum Projects
    Last Post: 02-16-2011, 12:15 PM
  4. Replies: 0
    Last Post: 11-30-2005, 07:48 PM
  5. Building A Frame For Cab
    By NY_Yankees_Fan in forum Customization
    Last Post: 12-22-2002, 09:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
