Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
  1. #11
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: New woods trailer for our RTV...
    Quote Originally Posted by Xfaxman View Post
    The wiring diagram will work to combine the two functions onto one light. But I don't think the resistor will dim the LED like a running light would be. The LED works on a lower voltage than the circuitry that drives it.
    I base this theory on my Led flashlight that runs on the same battery pack that my drill uses. As the battery gets weaker the Led never dims, it just goes out, then the battery recovers a little and the LED comes on then the battery dies again, and the LED goes off, so it just flashes.
    I have seen LEDs advertised to work from 5v to 30v, so I guess it depends on the circuit that drives it.
    I had similar thoughts. Perhaps I will call them and ask if their lights dim at lower voltages
    If you don't have a brake lights on the tractor, you don't need dimmer, as in not as bright, marker lights
    Let us know what you come up with.
    The tractor doesn't have brake lights per say, but it has 4 ways, turn signals and running lights. When you turn on (for example) the left turn signal the right turn signal goes on solid and looks like it would on a car with brakes and turn signal on at the same time.
    Thanks
    Aaron Z
    A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.
    ― Robert A. Heinlein, Friday
  2. #12
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    8,052
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Update??
  3. #13
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    Have the sides and the deck ready to cut out (3/4" pressure treated plywood), welded stake pockets on today, hoping to get some primer on it so that I can paint it next week (Monday?)
    Aaron Z
  4. #14
    Join Date
    Feb 2013
    Posts
    8,052
    Meridian, OK
    Quote Originally Posted by aczlan View Post
    Aaron Z
    Sounds good.
    What about the tail lights?
  5. #15
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    Sounds good.
    They are sitting on my desk. We ran out of gas for the MIG welder so the trailer hitch didnt go on and neither did the mounting plates for the lights. Sometime next week.
    Aaron Z
  6. #16
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    And next week turned into a couple of weeks... Got rust converter (3M Rust Reformer) on the rusty spots (mostly surface rust, plus a little on the welds from condensation). Next to put on kubota Orange (tomorrow?) and then some undercoating where the deck will sit on the frame.
    Pictures:
    From the side with the splitter hooked up:
    New woods trailer for our RTV...-imag0099-custom-jpg
    The view from the splitter's perspective:
    New woods trailer for our RTV...-imag0100-custom-jpg
    Rust Reformer drying (sorry about the fuzzyness on the right side, the back slipped partway off my phone):
    New woods trailer for our RTV...-imag0101-custom-jpg
    From the front:
    New woods trailer for our RTV...-imag0102-custom-jpg
    Tires: The current tires are old and leak down. If I get bored, I plan to pull them, perhaps try electrolysis to clean them off, repaint them and put on a couple of the mostly dead 13" snowtires that are currently taking up space in the shop. They are ~3/4" smaller in diameter and are ~1.5" wider, so they should level the trailer and "float" better in soft ground.
    Hitch: The receiver hitch on the back is just a piece of 2"x2" 1/4" angle with a piece of smaller (1.75"x1.75"?) angle welded inside it to make a box. I couldn't see paying $30 for a 8" piece of hitch tube at Tractor Supply. I used a removable hitch for 2 reasons:
    1. This way, I can turn the ball mount around and nothing sticks out of the back of the trailer
    2. I had a ball mount sitting around from my previous car
    Aaron Z
  7. #17
    Join Date
    Feb 2013
    Posts
    8,052
    Meridian, OK
    Looking good
    I like the hitch
  8. #18
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    Looking good
    I like the hitch
    Thanks. Couldn't see spending $30 on a piece of tube when I had all of the parts to make it and I would have needed a piece of angle to tie back to the 2nd crossmember anyway.
    Aaron Z
  9. #19
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    Everything is ready for paint now. Had a weld on one of the stake pockets for the back that didnt hold, and once I got the sides on, I realized that I needed something to keeping them from bowing out, so I added 2 tabs on each side. Here are some pictures:
    Walkaround:
    New woods trailer for our RTV...-img_2352-custom-jpg New woods trailer for our RTV...-img_2353-custom-jpg New woods trailer for our RTV...-img_2355-custom-jpg New woods trailer for our RTV...-img_2357-custom-jpg New woods trailer for our RTV...-img_2358-custom-jpg
    Looking into the box from the front:
    New woods trailer for our RTV...-img_2359-custom-jpg
    RR and RF corners showing brackets there to lock sides together at the top. Will eventually cut the bolts off flush, or add acorn nuts:
    New woods trailer for our RTV...-img_2360-custom-jpg New woods trailer for our RTV...-img_2361-custom-jpg
    Hitch closeup:
    New woods trailer for our RTV...-img_2356-custom-jpg
    Hitch stowed:
    New woods trailer for our RTV...-img_2354-custom-jpg
    Hitch out:
    Still need to paint it, but cold weather shouldn't be a problem going forward.
    Aaron Z
  10. #20
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,680
    To those who said that the tongue wasn't strong enough, you were right, but the problem was the vertical dimension, not the horizontal one. My brother was using it last week to move dirt and when i got home from work he told me that "The first load, I filled it all the way up, the second, I only filled it halfway and the tongue broke" . My guess is that the first load was filled all of the way back, while the 2nd only put dirt in front of the axle (causing more tongue weight, but less overall trailer weight).
    Adding diagonals wouldn't have helped much with this though as it bent vertically:
    Attachment 330784
    Need to hit up the local fab shop and get a heavier piece of c channel or tube to replace the tongue.
    Aaron Z
Similar Threads
  1. camper trailer frame to utility trailer project
    By nsmithnd in forum Trailers & Transportation
    Last Post: 11-15-2017, 12:27 PM
  2. New Trailer arrived, Econoling 25' GN TILT trailer
    By LoneCowboy in forum Trailers & Transportation
    Last Post: 04-17-2007, 08:18 PM
  3. Bx1500 and Trailer Length: Recommend Trailer Makes
    By AKFord in forum Trailers & Transportation
    Last Post: 05-07-2005, 09:47 PM
  4. Bx1500 and Trailer Length: Recommend Trailer Makes
    By AKFord in forum Kubota Owning/Operating
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
