Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    6,941
    Default Re: Pole Barn Overhang...Or Not?
    Quote Originally Posted by quicksandfarmer View Post
    The big disadvantage of overhangs is they increase the wind uplift. I think it's crazy to have a building without them.
    Spot on as far as "lift" goes...(if it's an enclosed structure)....
    Sometimes the configuration of the truss members can make installing a "freeze board" or "bird blocking" a challenge...
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools or thin skinned neanderthals...in the immortal words of Popeye..."I yam what I yam"
  2. #12
    Elite Member Code54's Avatar
    Join Date
    Aug 2005
    Posts
    3,213
    Putnam Co. West Virginia
    Kubota MX5100, Kubota BX25D, Kubota KX91-3, BCS 853, MULE FXT Pro
    Have 2 foot overhangs and climate control my building - no issues at all. I sealed mine up without any issues (do have ridge vent I close in the winter and open in the spring) - no water, bug, bird or circulation issues at all. Seems to work great and if the door is open the rain doesn't blow in too easy
  3. #13
    Super Member
    Join Date
    Aug 2004
    Posts
    6,338
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    I built 2 ea 200 ft horse barns for a fussy show horse client.
    With the quantity of roofing and siding we were dealing directly with the factory so they made us a facia/soffit all in one piece that did the installation really easy to do.
    Solved all the problems!
    For doors I had the truss firm make square 'trusses' that I covered with siding outside and 3/8" plywood inside. These were mounted on standard door tracks. Worked great!
    Since all door panels were sized the same the delivered cost was less than what I would have paid for the 2x stock not counting my labor plus they used truss plates giving me super strong frames to mount the panels. (fitted 1 1/2 foam panels in spaces for heat retention)
  4. #14
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Mine is 54x44 and I have 18" overhangs with gutters. Would not do it any other way.
    Chris
  5. #15
    Platinum Member joeyd's Avatar
    Join Date
    Jul 2010
    Posts
    655
    North Idaho
    TYM 353HST
    Over hang shown here and all sealed, no problem for the builder.
    Pole Barn Overhang...Or Not?-p6130100-jpg
    Isa 43:2-3
  6. #16
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,406
    central Iowa
    JD 2720
    With overhangs and gutters, it looks like a nice building.
    Without them, its just a tin shed.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  7. #17
    Join Date
    Jul 2012
    Posts
    59
    northern il
    cub yanmar lx410 fel jd 850 cub cadet lt1038
    Quote Originally Posted by jmd4j View Post
    Hello all, I'm in the process of building a pole barn, 40x40x14 with steel trusses to be exact. I cannot stand the look of a pole barn without overhangs so I was set on having them. I plan on finishing the pole barn and turning it into an airplane hangar in about a year or two, but once the place I'm buying my materials from learned of this, they recommended to not build with overhangs. They said it is much harder to seal up with the metal if you have the overhangs sticking out. My question is, how much harder is it to seal? Is it really that big of a deal. I don't plan on having it climate controlled, so air tight it doesn't have to be. I just want to keep everything relatively dry. We plan on using it for other purposes this year, as a pavilion, and next year is when I plan to finish the sides. This is also in a field not close to houses, so me and family are the only ones going to be able to see it, so cosmetically I don't think it'd be that big of a deal trying to seal up either.
    I searched the site but didn't come up with any recommendations. I appreciate any help anyone can give! I would suggest that it's more important to have a gutter system installed especially without a overhang. With water running down the wall it will rot out the poles in a short time. My pole barn is 30 yr old and every pole is rotted off at ground level. We had a mini tornado here and mine held together because of the concrete floor. Next door the 40 x 70 barn, same condition, gravel floor lifted up and relocated to the middle of the road.
    Thanks!
  8. #18
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,034
    north idaho
    Kioti DK45SE hst cab
    All 3 of my pole barns have overhangs on the sides and on front and back. It adds so much to the overall look of the building. I have wired 100's of these structures over the past 28 years, and all the buildings without overhangs just look cheap. period.
    Like they just dont give a ^^%^ how the building looks. No one would build a house without overhangs.
    Id also rather have rain water wash over the roof and miss the walls then run down the walls year after year. That really wrecks the finish on the buildings.
    I dont see how an overhang would affect waterproofing or sealing the structure. does not make any sense.
    Also, have them finish the underside of the overhangs in metal just like the roof. looks nice and clean.
    Attached Thumbnails Attached Thumbnails Pole Barn Overhang...Or Not?-carriage-house-front-jpg
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  9. #19
    Elite Member
    Join Date
    Jun 2006
    Posts
    2,757
    West Cascades, Washington State USA
    PT 422
    Overhang is the only way to go in my opinion.
  10. #20
    Silver Member droptop's Avatar
    Join Date
    Jan 2012
    Posts
    218
    Western NY
    Massey Ferguson 1635 cab
    Quote Originally Posted by bigtiller View Post
    I'm a big fan of overhangs, it just makes the building look "finished", I had a 30x66 Morton built a few years ago and it has full venting under the overhang and on the ridge. Since it's not heated the venting keeps eveything from sweating and the temperature in the summer stays close to the outside temperature even on a sunny day when all of the doors are closed. Being tightly sealed may not always be a good thing.
Similar Threads
  1. Pole Barn vs Metal Barn....pros and cons?
    By markmc in forum Projects
    Last Post: 08-16-2015, 07:59 PM
  2. Pole Barn, Pole Question
    By HoustonBrama in forum Projects
    Last Post: 07-27-2008, 06:15 PM
  3. And Yet another Horse Barn/ Pole Barn
    By FL4400 in forum Projects
    Last Post: 05-05-2008, 07:39 PM
  4. pole barn pole problem..
    By mopower440 in forum Projects
    Last Post: 12-15-2003, 07:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
