rmorey
Rmorey thanks for the tip. the cord has 2 flat ends side by side and the third ground I thought this was a 15 amp plug.
If you go to the hardware store and find a corresponding receptacle to the cord plug, you will find its rated for 220 volts 20 amps. It will require a #12/2 wire and a 20 amp breaker. The other thing, electrical codes are state by state, but most will not allow more than one 220v receptacle on a circuit.
