Page 2 of 10 FirstFirst 12345 ... LastLast
Results 11 to 20 of 98
  1. #11
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Default Re: building our retirement cabin
    Another house build for me to follow.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  2. #12
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Sounds like a fun project, I cant wait to see your sawmill in action.
    Dave
  3. #13
    Silver Member triangel's Avatar
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    new holland t1510, 730 case
    You can see the mill the first time we used it on youtube burgmill first time. July its been raining none stop for 2 months ,flooding all over the province and this is the time we are trying to build, I built a post hole auger hydraulic driven with a 10" auger bit. I used a similar design as wheatheart auger and borrowed an auger to fit from a friend. We drilled 19 holes 8' and put in cement tubes. I then acquired a frontend loader mounted cement mixer that could mix a bag of cement at a time, also hyd driven. I had to run hyd lines to the front of the tractor to run the auger and the mixer. Both worked well but the job was a nightmare as it simply would not quit raining. Also to compound this we were trying to get our second daughters wedding prepared for, a long month.building our retirement cabin-drilling-pile-holes-pngbuilding our retirement cabin-cement-mixing-cabin-pngbuilding our retirement cabin-cement-mixing2-png
  4. #14
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    The wedding is over,great time we have a new son in law. the rain keeps on and we are getting tired of playing in the mud. We are learning to use the mill but a nightmare to work in the mud. We got the cement poured and we are putting up the base logs and floor stringers. This is all we will accomplice for this year because of other commitments . I decided to run in civil politics and got elected as an RM councellor and do to the flooding at home this kept me busy for the rest of fall.building our retirement cabin-frame-cabin-0-pngbuilding our retirement cabin-frame-cabin-1-2-pngbuilding our retirement cabin-frame-cabin-2-pngbuilding our retirement cabin-frame-cabin-3-pngbuilding our retirement cabin-frame-cabin-4-pngbuilding our retirement cabin-frame-5-cabin-pngbuilding our retirement cabin-2010_0801logmilll0004-jpgbuilding our retirement cabin-2010_0801logmilll0005-jpg
  5. #15
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Looking forward to following your build.
  6. #16
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    I like the way you are doing the floor beams and scribe-ing them in with a chainsaw?...good work!
    It's hard to find the crown on two sided logs, so you might consider sawing all for slabs off.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  7. #17
    Join Date
    Apr 2011
    Posts
    775
    Jackson, NY
    none
    Looks like a fun project. I have a question, why build with no foundation? It would be a much better finished product with some protection from the critters, moisture and elements.
    Next time you are pouring Sona tubes, take a plastic big foot of the appropriate size and use it like a funnel.
  8. #18
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    We decided not to use a foundation because of the excess moisture. we plan to frame it after and close it in with panels that we can open to allow air to move under it.
  9. #19
    Join Date
    Nov 2012
    Posts
    115
    melville sk canada
    Spring 2011 is finally here and we got started again after 7 months of brutal winter. we had lots of help from friends and family to peel logs and we are milling them as they are peeling. we started the build and found out this was far more difficult than we thought.building our retirement cabin-camp-david-011-jpgbuilding our retirement cabin-camp-david-013-jpgbuilding our retirement cabin-camp-david-014-jpgbuilding our retirement cabin-camp-david-015-jpg
  10. #20
    Platinum Member lutt's Avatar
    Join Date
    Dec 2010
    Posts
    657
    Pocahontas, Arkansas
    Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
    I will be watching this also,love these kind of projects! LUTT
Similar Threads
  1. Building a Guest Room at the Cabin
    By GPintheMitten in forum Projects
    Last Post: 03-24-2016, 05:27 PM
  2. Building / Restoring an Old Cabin
    By pwt in forum Build-It Yourself
    Last Post: 02-01-2013, 04:30 PM
  3. Thanks for help! Building 32x48 barn/cabin
    By l8_apexer in forum Projects
    Last Post: 10-21-2010, 09:03 PM
  4. Any been there done thats on cabin...er house building??
    By TractorLegend in forum Rural Living
    Last Post: 02-14-2007, 10:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
