Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 96
  1. #31
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    3,170
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Default Re: building our retirement cabin
    FB don't cut them until the sap is flowing, Dave is right, then peel immediately. The longer you wait the harder it gets. However if you let them sit for 6 months off the ground then they are again easy to peel but it's harder then because the bark will be stiff as a board. I could knock a lot of the bark with a pickaroon when I had them on the mill since they sat so long.
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  2. #32
    Bronze Member triangel's Avatar
    Join Date
    Nov 2012
    Posts
    72
    melville sk canada
    new holland t1510, 730 case
    You got that right we did work for it,and under tougher conditions than today still not as tough as our predecessors . I was a carman in Melville car shops as a welder mechanic for 25 years then I got on the road repair truck for the last 11 years. loved the job but Hunter made the rules unbearable so that at the end you could not make a move without Big Brother turning you in for any little thing. Glad to get out with my sanity . I have a friend who got axed in the 80's went to work for Cp he has my sympathy now that he both Hunter and Creell both. Hatchet men at their worst. Hope you have a good retirement, I working as hard now as when I had a job and a farm only doing the things we love now.
  3. #33
    Join Date
    Nov 2012
    Posts
    72
    melville sk canada
    Well we got the walls started finally and it is long process. We built spine boards in the window and door frames to allow for log shrinkage .We milled all the lumber for the frames and the logs as we go.building our retirement cabin-somme-013.jpgbuilding our retirement cabin-somme-014.jpgbuilding our retirement cabin-somme-020.jpg
  4. #34
    Elite Member
    Join Date
    Apr 2005
    Posts
    3,061
    nicholson, pa
    John Deer Lt160
    Quote Originally Posted by MotorSeven View Post
    Appreciate it I will work one at a time then. Thanks , Triangel sorry for hijacking!
    http://www.etsy.com/people/Forgeblast?ref=pr_profile
    Is where I have spoons, spreaders, spatuals, sometimes even bread bowls and cups (Kuksa)
  5. #35
    Join Date
    Nov 2012
    Posts
    72
    melville sk canada
    Our cabin is 26' by 30' with a 14x26 loft. When we cut the logs flat on both sides we sealed them with two strips of a seal called EM Seal. It compresses and expands with the movement of the logs. We are still dealing with lots of rain and are used to working in the mud. We fastened the logs every 3' with a 3/8 12" lag bolt which was countersunk in the top log about 5 to 6 inches. Lots of drilling with a 1" bit to allow for a socket wrench to fit. We welded a 10" extension on the socket so it would come out of the hole without falling off when the bolt was tightened. we used an electric impact run by our portable welder to tighten the bolts saved a lot of time and energy. We then built the bottom bedroom inside to support the loft and to tie the walls together.building our retirement cabin-inside-bedroom.pngbuilding our retirement cabin-working-water.pngbuilding our retirement cabin-bedroom-before-door-cut.pngbuilding our retirement cabin-loft-floor-joists.png
  6. #36
    Veteran Member rekees4300's Avatar
    Join Date
    Feb 2010
    Posts
    1,873
    Indiana
    JD4300 HST 4WD
    You guys don't mess around. Very few people now-a-days have the ambition to do what you are doing! How are you lifting the logs?
  7. #37
    Join Date
    Nov 2012
    Posts
    72
    melville sk canada
    we lifted most of the lower ones with my t1510 fitted with log forks. easy with this because of the hydro transmission but when we could not reach higher we had to depend on old reliable my 730 case with a du al loader. we built log forks on the bucket to which we attached a 4x4" box tube about 8' long and made a jib so to speak so we could make the long reaches, worked very well however shifting gears and riding a clutch were not the same as the hydro .Once we got the walls up we started with the loft joists 7x7 just because that was the size of the logs. when they were down we used 5/8 tongue and groove plywood for the subfloor.As you can see my wife is really at home with heights,still don't how I convinced her to go up there. This as far as we got for 2 weeks as our second daughter was getting married . two down and one to go.building our retirement cabin-cabin-inside-013.jpgbuilding our retirement cabin-cabin-inside-015.jpgbuilding our retirement cabin-cabin-inside-016.jpgbuilding our retirement cabin-cabin-roof-015.jpg
  8. #38
    Join Date
    Nov 2012
    Posts
    72
    melville sk canada
    Finally got the second wedding done, another son in law to help, and away we go again. Got the last of the logs in place and started on the loft floor and building the rafters. For the rafters we purchased 18' 2x4's and 3/8 strandboard. We used the sawmill to cut the sheets in 1x8' strips . then we used the 2x4's for the upper and lower edge to the rafter nailing and glueing the sheets to the side to make a rafter. Lots of nailing about 7000 nails with the power nailer, Mike my son in law did most of the nailing and at the end of the day he sure felt it.the day we did this it was very hot and humid so we had to build a canopy over us to keep the sun off of us. My dad who was 80 was helping us as a forman.building our retirement cabin-cabin-roof-042.jpgbuilding our retirement cabin-cabin-roof-028.jpgbuilding our retirement cabin-cabin-roof-033.jpgbuilding our retirement cabin-cabin-roof-041.jpgbuilding our retirement cabin-cabin-roof-029.jpg
  9. #39
    Platinum Member BoFuller's Avatar
    Join Date
    Feb 2011
    Posts
    625
    Arizona
    2008 Kubota L3400
    Default
    Just read your thread. Great building project! I hope to have my permit in about a month and then I'll be stacking logs also. My hat's off to you. Yes it is hard work!
    Bo Fuller
    "All that is necessary for the triumph of evil is for enough good men to do nothing"
  10. #40
    Join Date
    Nov 2012
    Posts
    72
    melville sk canada
    Finally got the rafters built and stacked on the loft floor. Could not have done it without the help of family and friends. We took a day off got on the quads and went looking in the forest for a ridge pole. After about 5 hrs of searching we finally found what we thought was the perfect tree. We had to take the quadrants back to the forestry branch get the okay and permits and back to the forest to cut it down. these are the pictures of cutting and hauling and peeling it.building our retirement cabin-ridge-pole-before-peeling.pngbuilding our retirement cabin-peeling-ridgepole.pngbuilding our retirement cabin-peeling-ridgepole01.pngbuilding our retirement cabin-ridge-pole-ready-lifted.pngbuilding our retirement cabin-cabin-roof-055.jpg
Similar Threads
  1. Building a Guest Room at the Cabin
    By GPintheMitten in forum Projects
    Last Post: 03-15-2013, 11:49 PM
  2. Building / Restoring an Old Cabin
    By pwt in forum Build-It Yourself
    Last Post: 02-01-2013, 04:30 PM
  3. Thanks for help! Building 32x48 barn/cabin
    By l8_apexer in forum Projects
    Last Post: 10-21-2010, 09:03 PM
  4. Any been there done thats on cabin...er house building??
    By TractorLegend in forum Rural Living
    Last Post: 02-14-2007, 10:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
