Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
  1. #1
    Gold Member El Wood's Avatar
    Join Date
    Apr 2012
    Posts
    280
    Michigan
    JD 3320
    Default Log skidding chains
    What size and length of chain do you guys use for log skidding?
    In the next couple days, I'll be clearing a large area of trees. Tree size range from small to large oaks. I don't have a lot of experience doing this but thought I would head to Tractor Supple and get a couple different lengths / gauges. I was also thinking about picking up a set of tongs. And advice? Here are a couple pics of the job site. Thanks!
    Log skidding chains-image-1493898274-jpg
    Log skidding chains-image-3855086476-jpg
  2. #2
    Join Date
    Dec 2011
    Posts
    726
    nc PA.
    kubota rtv900: kubota mx5200
    Default Re: Log skidding chains
    i use either 3/8 chain or 5/16 chain for when i do firewood. i used the 3/8 chain in the past, but when i got my winch, it was all set up for 5/16. i was a little sceptical at first, but no problems with the 5/16 70 grade chain. mine are approx 8ft in length and i have slip hooks on the end. the tree diameters i winch/skid are between 8" to up to 36" diameter. i have no experience with tongs.
  3. #3
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    I use 5/16 grade 70 chain with a 44HP tractor. I have log tongs but rarely ever use them. I have a short chain I use as a choker and more than a few longer chains. Always best to pull with the draw bar because you can flip you tractor.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  4. #4
    Join Date
    Jun 2004
    Posts
    1,089
    Armstrong, BC
    Kioti DK35 SE HST (2011)
    Default
    Same here, a 5/16" chain is the better choice for moderate skidding like ours, and they are easier to handle. Mine are not grade 70 but are still plenty strong for my DK35. I keep 8' and 15' on the tractor and use the 8' if possible.
    The chains are kept in holders made from short lengths of vertical plastic pipe as shown in other threads.
  5. #5
    Platinum Member lutt's Avatar
    Join Date
    Dec 2010
    Posts
    657
    Pocahontas, Arkansas
    Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
    I also use 5/16 grade 70 chains for skidding, easier for me to manage. Skidded some good sized stuff and hadnt broke one yet. Most of what I skid is for firewood. LUTT
  6. #6
    Gold Member mvwicker's Avatar
    Join Date
    Sep 2009
    Posts
    325
    St Louis, MO
    2007 New Holland TC34DA
    Like others, I have multiple chains: 5/16 grade 70 and 3/8 grade 43, with a 35hp tractor and 6500lb skidding winch with 5/16 cable. The winch has a slip clutch. The short choke chains are all 5/16 gr70. There have been no problems so far in more than a year of dragging salvage timber out of my steep woods.
  7. #7
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    I have used 3/8 grade 70, because I use the same chains for tying down equipment. I agree with the other member regarding pulling from the Drawbar. Best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  8. #8
    Join Date
    Apr 2012
    Posts
    280
    Michigan
    JD 3320
    Default
    Thanks for the info guys! I appreciate your help. And I'll definitely only be using the drawbar.
  9. #9
    Join Date
    Oct 2010
    Posts
    578
    WI
    '13 Yanmar Lx4100
    I think 3/8 is a bit heavy for what it is your actually pulling, 5/16 should defiantly do the job and you'll probably enjoy the lighter weight of it. I use normal slip hooks so the chain can choke tight around the log, grab hooks work too just seem a little more tedious to get them to set into the log sometimes.
  10. #10
    Join Date
    May 2009
    Posts
    927
    South Mississippi
    2008 John Deere 5303 MFWD
    Default
    Watched a guy skid some logs this weekend after a tornado passed through our area. Looked like he had a draw bar between the lift arms with a set of tongs attached to it. He could back up over a log drop down to latch onto the log, lift to slightly raise the end and off he went. He could drop the log at his destination, back up slightly and the tongs would turn loose and then he was off to the next log. Very efficient way to move logs. As others have mentioned, have to becareful not to snag an immovable object and flip the tractor over. Found this thread while searching for information on tongs and draw bars.
Similar Threads
  1. Log skidding cone
    By Chilly807 in forum Welding
    Last Post: 04-15-2017, 06:31 AM
  2. LOG SKIDDING/GRAPPLE
    By flINTLOCK in forum Owning/Operating
    Last Post: 03-12-2007, 02:30 PM
  3. Log skidding
    By MikeBeers in forum Mahindra Owning/Operating
    Last Post: 03-25-2006, 11:37 AM
  4. Log Skidding with DK45
    By krazykioti in forum Kioti Owning/Operating
    Last Post: 04-22-2004, 12:21 AM
  5. Log Skidding
    By vongiese in forum Build-It Yourself
    Last Post: 12-27-2002, 11:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
