Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Platinum Member jwmorris's Avatar
    Join Date
    Oct 2007
    Posts
    705
    Default Re: Automatic Gate Opener
    We've chosen to use a Liftmaster Elite 240V pad-mount opener. It uses scissor action rather that the typical hydraulic arm.
    I don't know of any opener that uses hydraulics. The ones your are likely thinking about are a linear actuator. They work pretty much the same way a trailer jack works.
    I picked up lift master 3 button remotes and RX's and installed them to operate the garage, shop and gate with one remote. I also have a keypad mounted on a post outside the gate so you can drive up, roll down the window and enter code.
    Mount your solar panel so it gets good sun once there are leaves on the trees. one other thing I did was mount a side marker light so when the gate is operating I can tell, even in the dark.
  2. #12
    Join Date
    May 2005
    Posts
    2,156
    N. E. Florida
    I hope the pillars are reinforced!! That's a lot of weight for that masonry to handle.
    Quote Originally Posted by RxRatedZ71 View Post
    Attachment 305803
    Attachment 305804
    Attachment 305805
    The pad will be at least 24"x28"x16"+ deep. Ive thought about mounting the keypad to that tree along side the drive, but im not sold on that yet.
    We are required to have a KnoxLock on the outside for emergency personnel entrance. Ive heard stories where a house burned b/c a resident didnt pay their annual dues to the local fire district. The FD still came out to the fire (to keep it from burning the neighbor's house down.) I would think if you didnt follow code and get a permit and your house burned b/c the FD didnt put it out, your homeowners insurance might be a bit P.O.'d....
  3. #13
    Join Date
    Nov 2003
    Posts
    1,378
    Tombstone Az
    KIOTI LK30
    Wow a 240v solar package. That has got to be big and costly.
    I use an Apollo 3600 dual gate opener. It is a scissor system and runs on 12v solar.
    Apollo 3600ETL Solar Compatible Dual Swing Gate Opener
  4. #14
    Gold Member RxRatedZ71's Avatar
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    Quote Originally Posted by Jimbrown
    Ive noticed that all the nice, gated communities had one thing in common with their gates; they all used the Elite openers. The mfc says rated for 1million cycles plus and a 7 year residential warranty. We had checked into them last year but were compromising if we didnt go w/ the Elite. My quotes last year were upwards of $5k and it wasnt in solar. Now the quotes are lower this year and solar is an option.
    http://www.liftmaster.com/lmcv2/page...x?modelId=9713
    Poor timing and lack of planning on your part do not constitute an emergency on my part!
    JD 3203, 300 series loader, Frontier rotary cutter, Frontier boxblade, quick-attach bucket, Polaris Sportsman 600, Cub Cadet lawn tractor
  5. #15
    Gold Member Ranger Rick's Avatar
    Join Date
    Aug 2007
    Posts
    316
    Louisa, VA East of Charlottesville
    Kubota L3940
    I noticed on the MFC site that the solar version qualifies for a 30% federal tax credit. Good deal for you. Rick
  6. #16
    Gold Member
    Join Date
    Jun 2011
    Posts
    269
    So, I see these metal/steel gates with a coded entry. What's to keep the bad guy intruder from just driving through the wooden fence???
  7. #17
    Join Date
    Mar 2010
    Posts
    2,128
    Bad guys stay on the paved areas. I worked for a major garage door factory in the test lab at one time. The liftmaster was a heck of a long lasting opener. I would buy one of their old products in a minute. The problem is that many companies decide that the million opening standard is to costly to build. What can we do to reduce the cost and settle for 500,000 operations. Stanley used to make openers about 1mile from me. They followed this thinking and have been gone for 10 years or more.
  8. #18
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    what do these units cost?
    Murph
  9. #19
    Join Date
    Feb 2010
    Posts
    251
    Edmond, OK
    JD 3203
    Default
    Quote Originally Posted by edlegault
    In my case, the trees on either side make it difficult to navigate My 12 gauge pump makes sure they dont live to tell about it.
    These units start about $1700 online, solar package another $300, and the accessories.
  10. #20
    Join Date
    Oct 2007
    Posts
    705
    Dont know about the others but my fence is all steel. Guess if I were wanting in I would just disconnect the opener from the gate and open the gate.
    In gated communities you would just follow someone else in.
    I also have an infrared motion sensors that transmit back to the house so I know when someone or something is moving around. So if your an intruder or bad guy breaking into my property will only be the start of your problems.
    It's a deterrent, doesn't turn your property into Fort Knox. Good thing most crooked people are lazy.
Similar Threads
  1. Gate opener
    By Eyecatcher in forum Build-It Yourself
    Last Post: 09-15-2012, 04:05 PM
  2. Automatic gate opener (solar powered)
    By jacobsdaddy06 in forum Buying/Pricing/Comparisons
    Last Post: 07-13-2012, 05:02 PM
  3. Solar powered gate opener and tube gate
    By Builder in forum Projects
    Last Post: 08-13-2011, 03:25 PM
  4. Automatic Chicken Door Opener
    By mjfox6 in forum Rural Living
    Last Post: 11-24-2009, 02:10 PM
  5. Automatic Gate Opener
    By Shimon in forum Rural Living
    Last Post: 10-06-2005, 10:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
