Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Silver Member RxRatedZ71's Avatar
    Join Date
    Feb 2010
    Posts
    194
    Edmond, OK
    JD 3203
    Default
    They make a locking pin so its not as easy to just disconnect it. I know nothing is IMPOSSIBLE but some are more difficult than others to remove. These days, an 18V battery-powered grinder is cheaper and easily accessible to thiefs.
    Poor timing and lack of planning on your part do not constitute an emergency on my part!
    JD 3203, 300 series loader, Frontier rotary cutter, Frontier boxblade, quick-attach bucket, Polaris Sportsman 600, Cub Cadet lawn tractor
  2. #22
    Join Date
    Oct 2007
    Posts
    206
    Default Re: Automatic Gate Opener
    Don"t go making it impossible or difficult for you to disconnect.
    Say you get a foot of snow on the ground and want to make sure everything swings freely so you don't mess up the opener, the weather won't likely be the same as when you install.
    A regular lock works fine but a bolt rigged up to appear welded is a bigger obstacle to anyone that likely already has a set of bolt cutters.
  3. #23
    Join Date
    Nov 2003
    Posts
    1,248
    Tombstone Az
    BX 22
    Quote Originally Posted by jwmorris View Post
    Should not need to do that. Mine has a switch you just flick and it disconnects the motor brakes and it swings free.
  4. #24
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    Sooner or later im going to install an automatic opener on the gate i built. Its 14' and about 500#, but opens very smoothy. I dont want a piston opener. I plan on installing a pad mount unit also, but too many other expenses right now. \
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  5. #25
    Gold Member
    Join Date
    Nov 2011
    Posts
    422
    Central NH
    John Deere 4300
    Quote Originally Posted by grsthegreat View Post
    Some day ill get around to installing it.Click image for larger version.
    Neat gate! You do that yourself?
  6. #26
    Gold Member
    Join Date
    Nov 2011
    Posts
    422
    Central NH
    John Deere 4300
    Quote Originally Posted by TCJatko View Post
    Oops! Sometimes it pays to read the text, no just gawk at the pictures.
  7. #27
    Join Date
    Jan 2011
    Posts
    5,217
    north idaho
    dk45se hst cab
    yup...built it a few years ago. Had to make and install a 1/4" thick 5" x5" post and have it powder coated white to match the vinyl fence and still be able to hold the gate up without a wheel or a torsion wire. The gate swings freely.
    currently own
  8. #28
    Join Date
    Feb 2010
    Posts
    194
    Edmond, OK
    JD 3203
    Default
    Got the forms built and in place. Now ready to mix concrete tomorrow for the pad. Got a buddy that might stop by to help for a while. Heres a shot of my gate and my progress. You can see "little mans" shovel that i got him. We used his other one in our flower beds, that was until i backed over it with the tractor and bent it in two.
  9. #29
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,667
    East TN
    Kub - 2K6, B7800
    thanks for the pictures
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  10. #30
    Veteran Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    2,306
    South Central Iowa
    TYM 330 HST with FEL
    Quote Originally Posted by RxRatedZ71 View Post
    Attachment 305803
    Attachment 305804
    Attachment 305805
    The pad will be at least 24"x28"x16"+ deep. Ive thought about mounting the keypad to that tree along side the drive, but im not sold on that yet.
    We are required to have a KnoxLock on the outside for emergency personnel entrance. Ive heard stories where a house burned b/c a resident didnt pay their annual dues to the local fire district. The FD still came out to the fire (to keep it from burning the neighbor's house down.) I would think if you didnt follow code and get a permit and your house burned b/c the FD didnt put it out, your homeowners insurance might be a bit P.O.'d....
    I don't know what soil type you have at your place but I would make the pad significantly deeper than 16". In fact I would drill a hole below frost line under it and use few rebars to anchor the pad to it.
    My gate is light "farm gate" hinged on about 10-12" post that goes 5 feet in ground and the opener turned the post small angle with every opening or closing. I had to anchor the post to the next post to stop it.
    Wish you success with your project.
    Ladia
    Ladia
    TYM 330 HST with FEL, box blade, rotary mower, post digger, three point sprayer, homemade backhoe, Jinma chipper, Leinbach rake and Lincoln 255XT MIG.
    Tasker harrow disc, PTO driven 5 cuft concrete mixer. My wife Julie has Grasshopper 725K.
    We live in a barn (aircraft hanger) converted into a house. Our PV system: https://enlighten.enphaseenergy.com/...ems/h2eX136588
    http://pvoutput.org/intraday.jsp?id=20209&sid=18073
Similar Threads
  1. Gate opener
    By Eyecatcher in forum Build-It Yourself
    Last Post: 09-15-2012, 04:05 PM
  2. Automatic gate opener (solar powered)
    By jacobsdaddy06 in forum Buying/Pricing/Comparisons
    Last Post: 07-13-2012, 05:02 PM
  3. Solar powered gate opener and tube gate
    By Builder in forum Projects
    Last Post: 08-13-2011, 03:25 PM
  4. Automatic Chicken Door Opener
    By mjfox6 in forum Rural Living
    Last Post: 11-24-2009, 02:10 PM
  5. Automatic Gate Opener
    By Shimon in forum Rural Living
    Last Post: 10-06-2005, 10:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
