Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
  1. #11
    Platinum Member Army grunt's Avatar
    Join Date
    Dec 2009
    Posts
    792
    Georga
    TC 30 Newholland
    Default Re: Project cj-5 jeep 1971 225 v6
    IMG_8820-1.jpg Photo by falcon6667 | Photobucket
    Here are some more pics of the jeep
    "Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
  2. #12
    Join Date
    Dec 2009
    Posts
    792
    Georga
    TC 30 Newholland
    >>>>>>>bump<<<<<<
  3. #13
    Gold Member duroc's Avatar
    Join Date
    Feb 2012
    Posts
    340
    Michigan
    NH T1510 HST
    Quote Originally Posted by Army grunt View Post
    >>>>>>>>>>BUMP<<<<<<<<<<
    Oh man, does that bring back some memories. I used to race Jeeps back in the day. This is my 1966/67 Jeep that I built from ground up. The body tub is two bodies repaired and then welded together. The front end is f/glass. The original engine was a 225 V-6 and I changed that to a 231 and then to a 252, also V-6's. Had Hilborn fuel injection for it, and V-8 cylinder heads, along with lots of other goodies. Sure do miss that hobby! Good luck selling yours! I'm sure someone will be happy to take it home with them.
    "If con is the opposite of pro, is Congress the opposite of progress?"
  4. #14
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Quote Originally Posted by duroc View Post
    Oh man, does that bring back some memories. I used to race Jeeps back in the day. This is my 1966/67 Jeep that I built from ground up. The body tub is two bodies repaired and then welded together. The front end is f/glass. The original engine was a 225 V-6 and I changed that to a 231 and then to a 252, also V-6's. Had Hilborn fuel injection for it, and V-8 cylinder heads, along with lots of other goodies. Sure do miss that hobby! Good luck selling yours! I'm sure someone will be happy to take it home them.
    wow thought I was the only one, have a 1970 jeepster eventually going to build the buick 340 i picked up and swap out the 225v6
    Few years back, I built a 1969 Jeepster Commando and installed a fresh Pontiac 455 that was punched out to a 462, floor console shifted turbo 400, Tilt gm power steering painted it bright red, got to drive it around for a couple months before had to sell it for bills.
    You could tap the brake at about 45mph and floor it, it would smoke the tires to 70+, I miss that one!!! can't seem to find any pictures of that jeep but here's a picture of another engine swap car I still have- it's an 84 Mazda Rx7 with a 1969 Pontiac GTO 400 YS engine in it,dead stock other than the headers and 800 cfm Quadra jet,Project cj-5 jeep 1971 225 v6-rx7-8-jpg trans is a 200-4r
  5. #15
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    Quote Originally Posted by sd455dan View Post
    son found a couple pictures- not good quality but here they areProject cj-5 jeep 1971 225 v6-jeepster-red-jpg Project cj-5 jeep 1971 225 v6-jeepster-455-jpg old jeeps are just cool
  6. #16
    Join Date
    Feb 2012
    Posts
    340
    Michigan
    NH T1510 HST
    wow thought I was the only one, have a 1970 jeepster eventually going to build the Buick 340 i picked up and swap out the 225v6
    Yep, there's a few of us left. The Buick 340 V-8 is what I cut my V-6 cylinder heads from. I cut the front hole off the right bank and the rear hole off the left bank. I had to weld end-plates to the remaining head portions, made valve cover spacers/adapters so the V-6 covers would fit, welded the emission ports closed and turned them into water jackets. Made an external engine oil return for the left cylinder head and ran that to the oil pan. People always asked why I used the 340 heads...well, they were about the only head available at that time and they sported larger valves, larger ports and chambers, and they fit the V-6 block.
    Sounds like a nice combination. I think the Jeepster is pretty cool looking, and even more-so when it sports a big engine and roll cage. There were plenty of them to compete against in "my time". Had a buddy that built one with a MONSTER big block Ford, nitrous, spooled rear axle, etc, etc, that ran around 3 sec in 100 yds. Those were the days! I finally sold mine because the sport started getting too expensive. The last time I took mine out, it pulled a wheel-stand that put the front end straight up. I had already stretched the wheelbase, but my last motor had too much power for it to be controllable. It was time for it to go because I didn't want to throw any more money at it.
    My daughters were so upset that they cried for a week.
    I believe it! Sounds like you like "different things" too! Lol! I'll bet that was job stuffing that engine in a Mazda.
  7. #17
    Join Date
    Feb 2012
    Posts
    340
    Michigan
    NH T1510 HST
    Very nice! A friend of mine still has a Commando that he just uses around the house to plow snow. It's not as good of shape as yours, but it's still nice to see that it's still being used. Oh, and yes, Jeeps are very cool.
  8. #18
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    Wow that Jeep sounds like a real!! animal.. Never raced any of my Jeeps, but tried a small amount of drag racing at a small track in the early 80s As for the 340's think they maybe my personal favorite engine in that size feel they were not given their due...
    You'll have laugh at this-but the first Pontiac we put in was the same year wt 4 speed block with a Ram Air 4 cam in it. Cam developed a flat lobe, pulled it-still on a stand.
    then built a 1976 455 H.O. some port matched,6x 9.6 to one heads, put a new Crane -Ram Air 4 cam in it and Rhoads lifters.. Wiped 3 lobes, within 2000 miles, did have an opportunity to chase down a Ferarri Testarossa on a trip up to the ski resort ( they were putting on some kind of high dollar event that day) I think guy in the Testarossa was more than a little ticked off that he couldn't pull away from an old Mazda with peeling paint...anyway pulled that engine and my son had this 400 , he had replaced with an Olds 455. So this little RX-7 is now on its third Pontiac engine, going to replace the cam and lifters on the 455 and re install it... As far as the jeepster in the picture sold it years ago, but found another one, Green this time and it has the flanged 44 rear axle got behind on bills, sold it .
    Was driving by the house where the people lived who bought it and it was for sale again!! Got it back for a hundred less than I sold it to them for Now have to catch up on everything else, before I can fix it up.... Oh yea, one more thing the guy that bought the red one i painted and put the new 455 (Completely rebuilt) in- Whined and moaned for over 2 hours, kicking tires and negotiating A roll cage was part of the requirement for the purchaser to install-and no inexperienced drivers, that got me a Whopping cash price of $3200 Needed to make some house payments...
  9. #19
    Join Date
    Dec 2009
    Posts
    792
    Georga
    TC 30 Newholland
    >>>>>>>>>>>bump<<<<<<<<<<<
  10. #20
    Join Date
    Dec 2009
    Posts
    792
    Georga
    TC 30 Newholland
    >>>>>>>>>>>bump<<<<<<<<<<<<
Similar Threads
  1. 1971 Ford 4400?
    By tech141 in forum New Holland Buying/Pricing
    Last Post: 10-08-2011, 08:35 PM
  2. 1971 Gilson MW won't move. Looks Ok
    By Gilsonite in forum General Vintage Tractors
    Last Post: 09-20-2011, 08:38 PM
  3. 1971 Toro Proline will not start!!!!!
    By mogack1967 in forum Parts/Repairs
    Last Post: 06-16-2011, 05:46 PM
  4. JD Disk model 225 Restoration Project (pics)
    By pharmvet in forum Attachments
    Last Post: 02-03-2011, 10:10 PM
  5. 1971? Fiat no brakes?
    By Timaay in forum Owning/Operating
    Last Post: 08-30-2010, 11:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
