Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default Ever feel like an idiot?
    I am putting a new electrical entrance in a barn I had built last summer and had the inspection on it this afternoon. This is not the first time I've done electrical work or the first entrance I've put in so I wasn't really worried about it, first mistake. I have the conduit coming into the bottom left side of the meter box and also have conduit exiting through the left side but on the side not the bottom. The inspector tells me that this will be unacceptable to the power company because they do not like the line & load wires to cross inside the meter box. Now I'm stuck because there are holes in the metal siding where the conduit goes onto the panel inside and where the meter box is screwed in. I'm going to call the power company tomorrow and see if I can talk them into allowing it as is, but the way this company is I'm not holding my breath. The worst part is the inspector told me there is absolutely nothing wrong with it the way it is but they just don't like it that way. Just a little frustrated right now and venting.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  2. #2
    Elite Member Code54's Avatar
    Join Date
    Aug 2005
    Posts
    3,284
    Putnam Co. West Virginia
    Kubota MX5100, Kubota BX25D, Kubota KX91-3, BCS 853, MULE FXT Pro
    Default Re: Ever feel like an idiot?
    Good luck - the companies can be fairly stick now a days
  3. #3
    Gold Member JBourquin's Avatar
    Join Date
    Jan 2013
    Posts
    282
    New York
    MF 1529L
    Just put the panel back in the box, tape it shut and return it to Home Depot. Just tell them you never opened it. That's what some jack ***** did in my local Home Depot. Luckily I like to open boxes and inspect things before I buy them. I would have been severely pi$$ed if I had gotten all the way home and opened the box to find that. (my local Home Depot is about 30-45min away)
    By the way, that was sarcasm. Please don't do it..
  4. #4
    Platinum Member yankeerider's Avatar
    Join Date
    May 2007
    Posts
    569
    North Central Connecticut
    Deere 755
    Default
    i do not see why the line and load wires must cross inside the box, although I have never wired a meter box. Can't the line leads enter the box, turn right, go up, turn left, then down to the meter receptacle? Then the load wires exit down, turn left (but still above the incoming line leads), and exit out the left side?
    Sent from my iPad using TractorByNet
    Jerry
    JD 755 w/70 loader, 60" MMM, LandPride FDR2560, Artillian Forks, Brush Bandit chipper, Woods RB60 blade, 48" KKII tiller, DR LeafVac
    Gator HPX 4x4 Gas,Cat 303c CR mini-ex
  5. #5
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    Default
    This is a quick sketch I made up of how the wires come into the meter box. It looks like a crayon drawing but the best i could do quickly on my iPad.
    Attached Thumbnails Attached Thumbnails Ever feel like an idiot?-image-1169619808-jpg
  6. #6
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    Default
    The picture needs rotated 90* counter clockwise to make sense.
    The blue is the box, green would be conduit, red is the wiring, and yellow is the meter lugs where the wire connects.
  7. #7
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,769
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by wmonroe View Post
    In my opinion, so don't take this to the bank, it is just an opinion.. but I think it is a bad idea to cross the wires.. a lightning strike could easily perforate the insulation of the crossed wires, and cause a connection between the wires. You could then pull the meter thinking you had de-energized the service to the house and it would not be the case. I would re-do it. I wonder if some of the actual electricians like Grsthegreat or Mace Canute would care to weigh in with their opinions.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  8. #8
    Join Date
    Oct 2008
    Posts
    1,186
    Mid. Coast Maine
    7610 hst
    Did you alter the divider that separates the utility wires from the load wires ???
  9. #9
    Join Date
    Feb 2013
    Posts
    107
    jax fl
    shibaura s1500/kuboto bx2200/
    inspection? what in the world does that mean
  10. #10
    Platinum Member Army grunt's Avatar
    Join Date
    Dec 2009
    Posts
    792
    Georga
    TC 30 Newholland
    Take it apart an fix it..It will short out, not may, but it will.Its just a learning thing.Patch the holes an get on with it
    "Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
Similar Threads
  1. Man, I feel like an idiot
    By Dogscape in forum Oil, Fuel & Lubricants
    Last Post: 01-27-2012, 05:42 PM
  2. I feel like an idiot.
    By N80 in forum Kubota Owning/Operating
    Last Post: 05-29-2006, 10:57 PM
  3. Help!! I am an idiot!!
    By Eric_Phillips in forum Attachments
    Last Post: 09-03-2005, 06:09 PM
  4. I'm an idiot again
    By widmn in forum Safety
    Last Post: 08-12-2005, 10:53 PM
  5. No, I'm the IDIOT!
    By Turfman in forum Owning/Operating
    Last Post: 07-23-2002, 08:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
