Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Sep 2009
    Posts
    219
    Default shade cloth..ever use it?
    Looking to make an inexpensive shade for Rv's at the ranch. Came across the shade cloth...anyone ever use it? Hard to work with? Suggestions on brands? I see that they use it for cattle shade also. I want to shade about 40' x 40' area for 2 RV's
  2. #2
    Gold Member
    Join Date
    Jan 2006
    Posts
    441
    Stone Mountain, GA
    Case 1210, Mitsubishi D2050
    Default Re: shade cloth..ever use it?
    Back in the 70s we sold bronze shade cloth, and people put it in screen porches typically. It worked great, but was somewhat pricy at 10x the cost of regular screen wire.
  3. #3
    Join Date
    Sep 2009
    Posts
    219
    This is what I am thinking about trying. I found a 40'x 40' with grommets for about 550.00
    Combating Heat Stress with Cattle Shades - YouTube
    Shade Cloth 60% Shade - GEMPLER'S
  4. #4
    Join Date
    Jan 2004
    Posts
    244
    Northern California
    TS1610
    I had some green sun screen material, unknown brand, on the side of a car port and on the side of a porch. It worked well but only lasted 2-3 years. It would be good to hear from others but I expect you have to replace the material or a regular basis as it deteriorates with sun exposure.
  5. #5
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Wish I could help you more. Back in the early 90's I bought about 2000' in 6'x100'rolls for Our Ostrich pens. All I can remember is the company mostly made shade cloth for automotive dealerships (hail cloth). consequently, the material I had was very strong and lasted over 10 years, but it was hung on 6' fence, not overhead. It took the abuse from the Male Ostriches in stride, (they fight between the fences, hence the "cloth")
    If it was me, I would ordered it pre-cut (cut to fit) with the grommets already set in at least a double fold edge, I would not want to have to add grommets no matter how easy they claim. Mine was Black, but for overhead I would look for a Blue or other light color, may add less wear from the sun.
    Dennis
    "Winter 2013 a majority of the country is setting new cold records, Colorado is setting new record HIGH's"
    "If at first you don't succeed, skydiving is not for you."
  6. #6
    Platinum Member GLyford's Avatar
    Join Date
    Feb 2009
    Posts
    925
    MA
    I have a green sail I put up over my beck deck every spring and take down every fall, I believe it's a "Coolaroo" brand. I want to say it's 4m (13ft) square or so, but it's not a perfect square, the sides are scalloped in about a foot on each side so it handles the tension better. It's got stainless hardware at the corners.
    It's lasted 8 or 9 years at this point, though I can see it's starting to get a little crispy from the sun on the top surface. Makes a big difference in how much heat comes in the house from the slider (faces WSW) and makes the deck usable. I try to take it down any time we have a big storm forecast, though I've missed a couple.
  7. #7
    Join Date
    Jan 2012
    Posts
    81
    Mountaindale, Oregon
    Allis Chalmers ACD19, ACG; Kubota BX2200 FEL, B2710 FEL, L355SS FEL; Cat D47U, Ford 4600SU FEL
    You need to consider the framing structure requirements to hold up the shade cloth, and a somewhat convenient method to get the cloth into position 12' up or more. Securely anchored so as to handle wind gusts.
    Dennis
  8. #8
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    2,022
    Columbia, SC
    Kubota L3830HST
    Here's a good link from where I order my heavy duty tarps...
    Shade Cloth
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  9. #9
    Join Date
    Apr 2012
    Posts
    91
    Culpeper, VA
    John Deere
    I've used a fair amount of shade cloth for different shading applications around koi ponds in the past. It is a great idea, but it is not always the easiest to put into practice. As stated above the mounting method is the most difficult consideration. It will have to be securely mounted and then drawn really tight to withstand the wind and weather. The best products are also rather pricey, but they hold up a lot better than the economy priced options. That is always the case, but "inexpensive" solution can add up quickly. By the times you figure out a way to suspend that much material and then put the idea into practice it might be the ideal solution you're looking for. It did help cut back on the UV as well as the heat, so it is effective if mounted properly.
  10. #10
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    2,332
    MO
    John Deere 1953-40S, 790, 755, 314, 70 I & Power King 2418
Similar Threads
  1. cloth door stop broke.
    By mlesniowski in forum Toolcat
    Last Post: 06-18-2013, 05:45 PM
  2. Replies: 6
    Last Post: 06-25-2012, 01:48 PM
  3. Cloth Seat Covers
    By bindian in forum Mahindra Owning/Operating
    Last Post: 07-26-2007, 11:19 AM
  4. Where can I buy 300 feet of geotextile cloth?
    By Kyle_in_Tex in forum Projects
    Last Post: 10-07-2004, 01:38 PM
  5. GeoTextile Cloth
    By MikePA in forum Rural Living
    Last Post: 05-13-2003, 03:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
