Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: Projects i have been working on
    Quote Originally Posted by Tim Stuart View Post
    All the retaining wall lack to be complete is tie backs and dirt.
    Tim, what are you going to use for tie-backs? Something like mobile home anchors would work. You surely want that wall very strong before backfilling. It looks too good to take a chance on it bulging outward. Everything looks like it is coming together. I built my house over 10 years ago and everything is still evolving. It's always a work-in-progress.
    Jim
  2. #12
    Silver Member Tim Stuart's Avatar
    Join Date
    Jun 2007
    Posts
    124
    Coldspring, TX
    Mitsubishi bd2h dozer, Gradall G3WD, New Holland TC35a, Chevy Dump Truck
    Jinman, I was looking to several options for the tie backs including the mobile home tie downs. I think I am going to use my pto post hole digger to dig a hole about 2 foot deep and put a 10 foot 5/8 piece of rebar with a triangle bend on the end of it down in the drilled post hole and fill it with concrete, Than weld a 18 inch piece of 3/4 all-thread to the other end of the rebar. Drill a hole through the wall and post for the all-thread to go though with a washer and nut for adjustment. Than coat the rebar with roofing tar or a undercoating from where it comes out of the concrete to the wall to slow down the rusting process. Hope I explained it well . Any thoughts or opinions on this?
  3. #13
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Tim, that is similar to what they did in the "old day's" on large rock and brick walls. Except they used a "star" or other type decorative medallion on the exterior. I'd coat all the re-bar ,even the portion in the cement and double coat the weld joint.
    Dennis
    "Winter 2013 a majority of the country is setting new cold records, Colorado is setting new record HIGH's"
    "If at first you don't succeed, skydiving is not for you."
  4. #14
    Join Date
    Jun 2007
    Posts
    124
    Coldspring, TX
    Quote Originally Posted by Western View Post
    Thanks !!! Good thinking!!!
  5. #15
    Join Date
    Jun 2007
    Posts
    124
    Coldspring, TX
    what size post hole would you guys drill ? I have 6" or 12" auger bit.
  6. #16
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Depends how deep your going I would think, 2' with the 12" should get you around 150-200lbs of cement in the hole. I'd go 12"
    Dennis
  7. #17
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Bear in mind that a 12' x 2' deep hole will hold a little over 1.6 cu/ft of concrete when you take variables into consideration. That's a lot of mixing on a hot day, so pick a cool day with plenty of time and an electric mixer if you can rent/buy/borrow one. Some people pour concrete into post holes and put water on top, but that is probably not the safe solution on your tie-back anchors. I think your idea with rebar will work fine. The mobile home tie-downs often come with galvanized strips to go from the anchor to the mobile home. I would think those would deteriorate pretty quickly in direct ground contact. They are around $10-$12 each I think. Coated rebar is probably a better choice. I'm no expert on this, so don't take my word as 'bible.'
    Jim
  8. #18
    Join Date
    Jun 2007
    Posts
    124
    Coldspring, TX
    Default
    Had a good day going got half of the tie backs in. Than I broke a u joint on my post hole digger. So I have get a u joint to finish.
    Attached Thumbnails Attached Thumbnails Projects i have been working on-image-1170108082-jpg   Projects i have been working on-image-613660655-jpg   Projects i have been working on-image-2207902473-jpg
  9. #19
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Wow! I've never seen a u-joint bust a spider like that before.
    Jim
  10. #20
    Veteran Member MacLawn's Avatar
    Join Date
    Aug 2007
    Posts
    1,335
    Red Clay Country, GA & Mississippi Prarie
    JD 2210
    Tim, I am very interested in this project, especially your retaining wall, since I need to do something similar at my place. Right about that ground contact wood - it'll be there! Good idea too with that rebar tie back thingamabob! I'd paint it with that old fashioned red lead paint if it is still available. Or, some good rust stopping super duper miracle paint.
    "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive". Dirt, it's nothing but dirt, I tell ye...
    If idiots could fly, this place would be an airport.
    "I wouldn't want to be within 400 or 500 yards of one of them newfangled nuclear bombs when it went off!" WW1 Vet...
Similar Threads
  1. Replies: 96
    Last Post: 04-10-2013, 07:05 PM
  2. Other projects
    By Bigboyskioti in forum Customization
    Last Post: 08-06-2007, 11:19 PM
  3. Some more of my projects
    By MrJimi in forum Build-It Yourself
    Last Post: 11-15-2006, 03:18 PM
  4. projects
    By milkman in forum Kubota Owning/Operating
    Last Post: 12-28-2001, 06:59 PM
  5. projects
    By milkman in forum Photos
    Last Post: 12-28-2001, 06:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
