Page 1 of 12 123411 ... LastLast
Results 1 to 10 of 111
  1. #1
    Gold Member El Wood's Avatar
    Join Date
    Apr 2012
    Posts
    280
    Michigan
    JD 3320
    Default Let's See Your Workbench
    My pole barn is going to be built in the next couple months and I've been contemplating different work bench options. I was hoping you guys could give me some ideas. So let's see 'em!!!
  2. #2
    Join Date
    Apr 2012
    Posts
    280
    Michigan
    JD 3320
    Default
    Bueller...Bueller... Guess nobody has a unique cool workbench.
  3. #3
    Veteran Member Carl_NH's Avatar
    Join Date
    Apr 2002
    Posts
    2,181
    Coastal NH
    01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
    Default Re: Let's See Your Workbench
    OK - i have 24x36' barn and on one side, I had the builder (using his EWPine) make me 3 8' long (movable) work benches 28" deep for $50 each and in between 1 and 2 bench and level with the bench top is the radial arm saw and then table saw and drill press is on stored on one end I can pull out and use the saw but dont use the benches for material support.
    The frames are 2x6 rough pine, with plywood shelf 12" off the floor and 2x10 fir for bench top. They are nice but not picture worthy as I haven't cleaned up lately...
    Kubota B21TLB, Ferris IS2000, Cub Cadet 1811
  4. #4
    Platinum Member DutchHenryBrown's Avatar
    Join Date
    Aug 2009
    Posts
    907
    Tombstone, AT
    Mahindra 5010
    I would show you my workbench but there is so much junk on it I cannot even see it!! I used 2x4 for legs and frame some old flat slab doors for the top. Built it around the radial arm saw and drill press, ugly but it works for me?
  5. #5
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    No pics, but my workbench is made from the wooden frame of an old water bed . It is about 6' long, about 2' deep, has an 8" bench grinder on one end, and a vice on the other. There is an open storage shelf underneath.
    The wall the bench sits against is T&G pine, so it's easy to hang frequently used tools and stuff there. I have an outlet in the wall above the bench for easy power access.
    I don't do much wood butchery, er, wood work, but if I did, I would want a bench dedicated to that. It would be clean and smooth-topped to prevent stains and scratches, and I would never set my chainsaw on it.
    It depends on what sort of things you do I guess. Good lighting and power outlets always help.
  6. #6
    Join Date
    Jun 2008
    Posts
    1,892
    Arkansas!
    JD
    Default
    Here you go
  7. #7
    Join Date
    Apr 2000
    Posts
    1,815
    North Central Arkansas
    John Deere 4520,
    My Father when a teenager around 1910 worked for neighbor and wasn't paid then given a shop work bench made of cast iron.
    I saw it a couple of times growing up and still live on the place know it is there can only see the legs. when on knees digging out some piece of iron to repair stuff. some day will clean up the shop.
    The other day found a "T" model Ford frame in rafters. Remember he said he had a 1919 coupe wonder where the rest is.?
    ken
  8. #8
    Join Date
    Apr 2012
    Posts
    280
    Michigan
    JD 3320
    Default
    Thanks guys. I appreciate the info.
  9. #9
    Silver Member dakotagun's Avatar
    Join Date
    Jul 2012
    Posts
    129
    JD 2305
    Let's See Your Workbench-bench1-jpg
    first pic-post attempt, so we'll see...
    built this in my new outbuilding, now will try to do it again in the new garage. found some of the plan online, but improvised, too, which for me is pretty scary since my only other project has been a doghouse (they didn't seem to care, either). seems sturdy enough to land a plane on it.
  10. #10
    Elite Member
    Join Date
    Sep 2008
    Posts
    2,926
    Midwest
    Ford 1210 / Ford 1710
    No pics but one thing I like to do is leave about 2" overhang on 3 sides. This helps whenever you want to clamp something down when working on it. I just use 2x4 structure with 3/4 plywood top.
Similar Threads
  1. Workbench!
    By donb2 in forum Projects
    Last Post: 06-09-2014, 12:10 AM
  2. New workbench
    By sixdogs in forum Build-It Yourself
    Last Post: 04-24-2013, 12:44 PM
  3. Workbench top
    By ace10 in forum Projects
    Last Post: 02-02-2011, 12:37 AM
  4. New hole in my workbench.
    By dodge man in forum Trailers & Transportation
    Last Post: 11-02-2010, 09:31 PM
  5. Workbench for our kids
    By EddieWalker in forum Related Topics
    Last Post: 11-21-2006, 10:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
